STM32F103C8T6-I2C-1602A程序
[打印本頁(yè)]
AaronHuang1228
時(shí)間:
2021-3-6 09:30
使用STM32F103C8T6單片機(jī)驅(qū)動(dòng)I2C-1602A模塊
單片機(jī)源程序如下:
#include <stm32f10x.h>
#include "delay.h"
#include "IIC_1602.h"
extern unsigned char LCD_data;
* @brief I2C_Configuration,初始化硬件IIC引腳
* @param 無(wú)
* @retval 無(wú)
void I2C_Configuration(void)
I2C_InitTypeDef I2C_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
/*STM32F103C8T6芯片的硬件I2C: PB6 -- SCL; PB7 -- SDA */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;//I2C必須開(kāi)漏輸出
GPIO_Init(GPIOB, &GPIO_InitStructure);
I2C_DeInit(I2C1);//使用I2C1
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = 0x30;//主機(jī)的I2C地址,隨便寫(xiě)的
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = 400000;//400K
I2C_Cmd(I2C1, ENABLE);
I2C_Init(I2C1, &I2C_InitStructure);
* @brief I2C_WriteByte,向OLED寄存器地址寫(xiě)一個(gè)byte的數(shù)據(jù)
* @param addr:寄存器地址
* data:要寫(xiě)入的數(shù)據(jù)
* @retval 無(wú)
void I2C_WriteByte(unsigned char data)
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
I2C_GenerateSTART(I2C1, ENABLE);//開(kāi)啟I2C1
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));/*EV5,主模式*/
I2C_Send7bitAddress(I2C1, LCD_ADDR, I2C_Direction_Transmitter);//器件地址 --
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
// I2C_SendData(I2C1, addr);//寄存器地址
// while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_SendData(I2C1, data);//發(fā)送數(shù)據(jù)
I2C_GenerateSTOP(I2C1, ENABLE);//關(guān)閉I2C1總線
void LCD_EN()
LCD_data |= 1<<2;
I2C_WriteByte(LCD_data);//1 讀取數(shù)據(jù)
DelayUs(25);//延時(shí)
LCD_data ^= 1<<2;
I2C_WriteByte(LCD_data);//1→0 執(zhí)行指令
void LCD_WriteCMD(unsigned char cmd)
DelayUs(25);
LCD_data &=~(1<<(1-1));//RS=0;
LCD_data &=~(1<<(2-1));//RW=0;
LCD_data &= 0X0f; //清高四位
LCD_data |= cmd & 0xf0; //寫(xiě)指令高四位
LCD_EN();
cmd = cmd<<4;
LCD_data |= cmd & 0xf0; //寫(xiě)指令低四位
LCD_EN();
void LCD_WriteDAT(unsigned char dat)
DelayUs(25);
LCD_data |= (1<<(1-1));//RS=0;
LCD_data |= dat & 0xf0; //寫(xiě)數(shù)據(jù)高四位
LCD_EN();
dat = dat<<4;
LCD_data |= dat & 0xf0; //寫(xiě)數(shù)據(jù)低四位
LCD_EN();
void Set_Position(unsigned char x,unsigned char y)
unsigned char x_pos;
x_pos = x%0x10;
if(y==0)
LCD_WriteCMD(0x80+x_pos);
LCD_WriteCMD(0xc0+x_pos);
void LCD_ShowStr(unsigned char x,unsigned char y,unsigned char * str)
Set_Position(x,y);
while(*str)
LCD_WriteDAT(*str);
str++;
void LCD_Init()
LCD_WriteCMD(0x28);//4線操作模式
LCD_WriteCMD(0x0c);//
LCD_WriteCMD(0x80);
LCD_WriteCMD(0x01);
DelayMs(5);
void LCD_DispConf(unsigned char DispON,unsigned char CursorON,unsigned char GlareON)
unsigned char x = 0x08;
if(DispON!=0)
x = x|(DispON<<2);
if(CursorON!=0)
x = x|(CursorON<<1);
if(GlareON!=0)
x = x|GlareON;
LCD_WriteCMD(x);
所有程序51hei提供下載:
IIC_1602A.7z
(21.31 KB, 下載次數(shù): 106)
2021-3-6 15:52 上傳
點(diǎn)擊文件名下載附件
wifingtta
時(shí)間:
2022-2-9 17:32
用STM32F103C6T6測(cè)試過(guò),可以顯示,但液晶背光不受控制,背光會(huì)一直關(guān)閉。
