標(biāo)題: 用獨立按鍵的走馬燈動態(tài)顯示 單片機程序 [打印本頁]
作者: kscheang    時間: 2021-1-14 00:29
#include "reg52.h"
typedef unsigned int u16;
typedef unsigned char u8;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit K1=P1^0;
u8 i=0;
u8 j=0;
u8 code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                     0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(u16 i)
        while(i--);
void keypush()
        if (K1==0)
                delay(1000);
                if (K1==0)
                        j++;
        while(!K1);
void DigDisplay()
        switch(j)
            case(0):
                case(15):
                    LSA=0;LSB=0;LSC=0; break;
            case(1):
                case(14):
                    LSA=1;LSB=0;LSC=0; break;
            case(2):
                case(13):
                    LSA=0;LSB=1;LSC=0; break;
            case(3):
                case(12):
                    LSA=1;LSB=1;LSC=0; break;
            case(4):
                case(11):
                    LSA=0;LSB=0;LSC=1; break;
            case(5):
                case(10):
                    LSA=1;LSB=0;LSC=1; break;
            case(6):
                case(9):
                    LSA=0;LSB=1;LSC=1; break;
            case(7):
                case(8):
                    LSA=1;LSB=1;LSC=1; break;
    P0=smgduan[j];
    delay(5000);
    P0=0x00;
            DigDisplay();
                keypush();
                if (j>15)
                        j=0;
