標題: 單片機控制DAC0832產生各種波形Proteus仿真程序 [打印本頁]
作者: @YGP    時間: 2020-12-18 12:20
單片機控制DAC0832產生各種波形,實質就是單片機把波形的采樣點數據送至DAC0832,經D/A轉換后輸出模擬信號。改變送出的函數波形采樣點后的延時時間,就可改變函數波形的頻率。產生各種函數波形的原理如下。
(1)正弦波產生原理。單片機把正弦波的256個采樣點的數據送給DAC0832。正弦波采樣數據可采用軟件編程或MATLAB等工具計算。
(2)方波產生原理。方波只有高、低電平的兩個采樣點的數據。單片機采用定時器定時中斷,時間常數決定方波高、低電平的持續時間。
(3)三角波產生原理。單片機把初始化數字量0送給DAC0832后,不斷增1,增至0xff后,在把送給DAC0832的數字量不斷減1,減至0后,再重復上述過程。
要求實現按下正弦波鍵,波形發生器輸出正弦波且數碼管顯示為1;按下方波鍵,波形發生器輸出方波且數碼管顯示為;按下三角波鍵,波形發生器輸出三角波且數碼管顯示為3。
#include<reg51.h>
sbit wr=P3^6;
sbit rd=P3^2;
sbit key0=P1^0;                  //定義P1.0腳的按鍵為正弦波鍵key0
sbit key1=P1^1;                  //定義P1.1腳的按鍵為方波鍵key1
sbit key2=P1^2;                  //定義P1.2腳的按鍵為三角波鍵key2
unsigned char flag;          //flag為1、2、3是對應的正弦波、方波、三角波
unsigned char const code        //為正弦波采樣點數組的256個數據
SIN_code[256]={0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,
0xa5,0xa8,0xab,0xae,0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,
0xd1,0xd3,0xd5,0xd8,0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,
0xf0,0xf2,0xf3,0xf4,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,
0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,
0xe3,0xe1,0xde,0xdc,0xda,0xd8,0xd6,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,
0xbc,0xb9,0xb6,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x92,0x8f,
0x8c,0x89,0x86,0x83,0x80,0x7d,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x64,0x61,
0x5e,0x5b,0x58,0x55,0x52,0x4f,0x4c,0x49,0x46,0x43,0x41,0x3e,0x3b,0x39,0x36,
0x33,0x31,0x2e,0x2c,0x2a,0x27,0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,
0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,0x3,0x3,0x2,0x1,0x1,0x0,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,0x7,
0x8,0x9,0xa,0xc,0xd,0xe,0x10,0x12,0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,
0x25,0x27,0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,0x3d,0x40,0x43,0x46,0x48,
0x4b,0x4e,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x73,0x76,0x79,0x7c};
unsigned char keyscan()                                  //鍵盤掃描函數
         unsigned char keyscan_num,temp;
        P1=0xff;                                                         //P1口輸入
        temp=P1;                                                         //從P1口讀入鍵值,存入temp中
        if(~(temp&0xff))                                         //判斷是否有鍵按下,即鍵值不為0xff,則有鍵按下
        if(key0==0)                                                         //產生正弦波的按鍵按下,P1.0=0
                P0=0xf9;                                                 //數碼管顯示1
                keyscan_num=1;                                         //得到的鍵值為1,表示產生正弦波
        else if(key1==0)                                         //產生方波的按鍵按下,P1.1=0
                  P0=0xa4;                                                 //數碼管顯示2
                keyscan_num=2;                                                 //得到的鍵值為2,表示產生方波
        else if(key2==0)                                         //產生三角波的按鍵按下,P1.2=0
                   P0=0xb0;                                                 //數碼管顯示3
                keyscan_num=3;                                             //得到的鍵值為3,表示產生三角波
        keyscan_num=0;                                                 //沒有按鍵按下,鍵值為0
        return keyscan_num;                                         //得到的鍵值返回
void init_DAC0832()                                                 //DAC0832初始化函數
        rd=0;
        wr=0;
void SIN()        //正弦函數
        unsigned int i;
        do{
                P2=SIN_code[ i];                                         //由P2口輸出給DAC0832正弦波數據
                i=i+1;                                                         //數組數據指針加1
                }while(i<256);                                         //判斷是否已輸出完256個波形數據,未完就繼續輸出數據
void Square()                                                         //方波函數
        EA=1;        //總中斷允許
        ET0=1;        //允許T0中斷
        TMOD=1;        //T0工作在方式1
        TH0=0xff;                                                         //給T0高8位裝入時間常數
        TL0=0x83;                                                         //給T0低8位裝入時間常數
        TR0=1;        //啟動T0
仿真圖
仿真圖
正弦波
正弦波
方波
方波
三角波
三角波
單片機控制DAC0832產生各種波形.zip
89.59 KB, 下載次數: 36, 下載積分: 黑幣 -5
程序+proteus仿真
