標題: stm32f103紅外遙控的main.c函數 [打印本頁]
作者: ~綠色夏天~    時間: 2020-12-17 21:42
#include "led.h"
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "lcd.h"
#include "usart.h"
#include "remote.h"
int main(void)
    u8 key;
    u8 t=0;
     u8 *str=0;
    delay_init();             //延時函數初始化
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置中斷優先級分組為組2:2位搶占優先級,2位響應優先級
    uart_init(115200);         //串口初始化為115200
     LED_Init();                 //LED端口初始化
    LCD_Init();
    KEY_Init();
    Remote_Init();            //紅外接收初始化
     POINT_COLOR=RED;        //設置字體為紅色
    LCD_ShowString(30,50,200,16,16,"WarShip STM32");
    LCD_ShowString(30,70,200,16,16,"REMOTE TEST");
    LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
    LCD_ShowString(30,110,200,16,16,"2015/1/15");
       LCD_ShowString(30,130,200,16,16,"KEYVAL:");
       LCD_ShowString(30,150,200,16,16,"KEYCNT:");
       LCD_ShowString(30,170,200,16,16,"SYMBOL:");
        key=Remote_Scan();
        if(key)
            LCD_ShowNum(86,130,key,3,16);        //顯示鍵值
            LCD_ShowNum(86,150,RmtCnt,3,16);    //顯示按鍵次數
            switch(key)
                case 0:str="ERROR";break;
                case 162:str="POWER";break;
                case 98:str="UP";break;
                case 2:str="PLAY";break;
                case 226:str="ALIENTEK";break;
                case 194:str="RIGHT";break;
                case 34:str="LEFT";break;
                case 224:str="VOL-";break;
                case 168:str="DOWN";break;
                case 144:str="VOL+";break;
                case 104:str="1";break;
                case 152:str="2";break;
                case 176:str="3";break;
                case 48:str="4";break;
                case 24:str="5";break;
                case 122:str="6";break;
                case 16:str="7";break;
                case 56:str="8";break;
                case 90:str="9";break;
                case 66:str="0";break;
                case 82:str="DELETE";break;
            LCD_Fill(86,170,116+8*8,170+16,WHITE);    //清楚之前的顯示
            LCD_ShowString(86,170,200,16,16,str);    //顯示SYMBOL
        }else delay_ms(10);
        t++;
        if(t==20)
            t=0;
            LED0=!LED0;
