單片機uln2003按鍵控制步進電機正反轉Proteus仿真程序
Mfb971016
2020-12-9 18:20
(17.83 KB, 下載次數: 55)
2020-12-9 22:52 上傳
#include "reg51.h"
#define out P2
sbit pos=P0^0;
sbit neg=P0^1;
void delayms(uint);
uchar code turn[]={0x07,0x06,0x0e,0x0c,0x0d,0x09,0x0b,0x03};
uchar code turn1[]={0x02,0x06,0x04,0x0c,0x08,0x09,0x01,0x03};
void main(void)
uchar i;
out=0x03;
if(!pos)
//i = i < 8 ? i+1 : 0;
if(i<8)
i=i+1;
i=0;
out=turn[i];
delayms(1000);
else if(!neg)
i = i > 0 ? i-1 : 7;
out=turn[i];
delayms(1000);
void delayms(uint j)
uchar i;
for(;j>0;j--)
i=250;
while(--i);
i=249;
while(--i);
JINBU.zip
(52.94 KB, 下載次數: 53)
2020-12-9 18:19 上傳
步進電機仿真
