標(biāo)題: ADC實(shí)驗(yàn) [打印本頁(yè)]
作者: dori    時(shí)間: 2020-12-8 15:12
新建工程,在HARDWARE目錄下新建adc.c和adc.h文件。編輯adc.h文件:
//初始化ADC
//這里我們僅以規(guī)則通道為例
//我們默認(rèn)將開(kāi)啟通道0~3
void  Adc_Init(void)
ADC_InitTypeDef ADC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |
RCC_APB2Periph_ADC1, ENABLE );//使能ADC1通道時(shí)鐘
RCC_ADCCLKConfig(RCC_PCLK2_Div6);  //設(shè)置ADC分頻因子6
//72M/6=12,ADC最大時(shí)間不能超過(guò)14M
//PA1 作為模擬通道輸入引腳
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//模擬輸入
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.1
ADC_DeInit(ADC1);  //復(fù)位ADC1,將外設(shè)ADC1 的全部寄存器重設(shè)為缺省值
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC獨(dú)立模式
ADC_InitStructure.ADC_ScanConvMode = DISABLE;//單通道模式
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;//單次轉(zhuǎn)換模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//轉(zhuǎn)換由
//軟件而不是外部觸發(fā)啟動(dòng)
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//ADC數(shù)據(jù)右對(duì)齊
ADC_InitStructure.ADC_NbrOfChannel = 1;//順序進(jìn)行規(guī)則轉(zhuǎn)換的ADC通道的數(shù)目
ADC_Init(ADC1, &ADC_InitStructure);//根據(jù)指定的參數(shù)初始化外設(shè)ADCx
ADC_Cmd(ADC1, ENABLE);//使能指定的ADC1
ADC_ResetCalibration(ADC1);//開(kāi)啟復(fù)位校準(zhǔn)
while(ADC_GetResetCalibrationStatus(ADC1));//等待復(fù)位校準(zhǔn)結(jié)束
ADC_StartCalibration(ADC1);//開(kāi)啟AD校準(zhǔn)
while(ADC_GetCalibrationStatus(ADC1));//等待校準(zhǔn)結(jié)束
//獲得ADC
//ch:通道值0~3
u16 Get_Adc(u8 ch)
//設(shè)置指定ADC的規(guī)則組通道,設(shè)置它們的轉(zhuǎn)化順序和采樣時(shí)間
ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 );
//通道1,規(guī)則采樣順序值為1,采樣時(shí)間為239.5周期
ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能軟件轉(zhuǎn)換功能
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待轉(zhuǎn)換結(jié)束
return ADC_GetConversionValue(ADC1);//返回最近一次ADC1規(guī)則組的轉(zhuǎn)換結(jié)果
u16 Get_Adc_Average(u8 ch,u8 times)
u32 temp_val=0;
u8 t;
for(t=0;t<times;t++)
temp_val+=Get_Adc(ch);
delay_ms(5);
return temp_val/times;
編輯main.c文件:
int main(void)
u16 adcx;
float temp;
delay_init();//延時(shí)函數(shù)初始化
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設(shè)置NVIC中斷分組2
uart_init(115200);//串口初始化波特率為115200
LED_Init();//LED端口初始化
LCD_Init();//LCD初始化
Adc_Init();//ADC初始化
POINT_COLOR=RED;//設(shè)置字體為紅色
LCD_ShowString(60,50,200,16,16,"WarShip STM32");
LCD_ShowString(60,70,200,16,16,"ADC TEST");
LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
LCD_ShowString(30,110,200,16,16,"2015/1/14");
//顯示提示信息
POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
LCD_ShowString(60,130,200,16,16,"ADC_CH0_VAL:");
LCD_ShowString(60,150,200,16,16,"ADC_CH0_VOL:0.000V");
adcx=Get_Adc_Average(ADC_Channel_1,10);
LCD_ShowxNum(156,130,adcx,4,16,0);//顯示ADC的值
temp=(float)adcx*(3.3/4096);
adcx=temp;
LCD_ShowxNum(156,150,adcx,1,16,0);//顯示電壓值
temp-=adcx;
temp*=1000;
LCD_ShowxNum(172,150,temp,3,16,0X80);
LED0=!LED0;
delay_ms(250);
此部分代碼,在TFTLCD模塊上顯示一些提示信息后,將每隔250ms讀取一次ADC通道0的值,并顯示讀到的ADC值(數(shù)字量),以及其轉(zhuǎn)換成模擬量后的電壓值。同時(shí)控制LED0閃爍,以提示程序正在運(yùn)行。
