MSP430控制的DDS輸出波形為正弦波和方波c語言程序
xueer
2013-7-14 16:19
// 子程序說明 //
//函數1: ad9850_reset()
// 復位ad9850,之后為并口寫入模式
//函數2: ad9850_reset_serial()
// 復位ad9850,之后為串口寫入模式
//函數3: ad9850_wr_parrel(unsigned char w0,double frequence)
// 并口寫ad9850數據,w0為ad9850中w0的數據,frequence
// 為寫入的頻率
//函數4: ad9850_wr_serial(unsigned char w0,double frequence)
// 串口寫ad9850數據,w0為ad9850中w0的數據,frequence
// 為寫入的頻率
//需定義的位:
//ad9850_w_clk ;
//ad9850_fq_up ;
//ad9850_rest ;
//ad9850_bit_data ;
//例:
//sbit ad9850_w_clk =P2^2;
//sbit ad9850_fq_up =P2^1;
//sbit ad9850_rest =P2^0;
//sbit ad9850_bit_data =P1^7;
// 寫數據說明 //
//寫數據例:
// ad9850_reset()
// wr_lcd02_data(unsigned char x)
// ad9850_wr_parrel(0x01,1000)
// ad9850_wr_serial(0x01,1000)
// 程序 //
# include <msp430f149.h>
# include <stdio.h>
#define ad9850_w_clk_High P2OUT|=0x04
#define ad9850_w_clk_Low P2OUT&=~0x04
#define ad9850_fq_up_High P2OUT|=0x02
#define ad9850_fq_up_Low P2OUT&=~0x02
#define ad9850_rest_High P2OUT|=0x01
#define ad9850_rest_Low P2OUT&=~0x01
#define ad9850_bit_data P1OUT
// ad9850復位(并口模式) //
void ad9850_reset()
ad9850_w_clk_Low;
ad9850_fq_up_Low;
ad9850_rest_Low;
ad9850_rest_High;
ad9850_rest_Low;
void ad9850_reset_serial()
ad9850_w_clk_Low;
ad9850_fq_up_Low;
//rest信號
ad9850_rest_Low;
ad9850_rest_High;
ad9850_rest_Low;
//w_clk信號
ad9850_w_clk_Low;
ad9850_w_clk_High;
ad9850_w_clk_Low;
//fq_up信號
ad9850_fq_up_Low;
ad9850_fq_up_High;
ad9850_fq_up_Low;
// 向ad9850中寫命令與數據(并口) //
void ad9850_wr_parrel(unsigned char w0,double frequence)
unsigned char w;
long int y;
double x;
//計算頻率的HEX值
x=4294967295/125;//適合125M晶振
//如果時鐘頻率不為125MHZ,修改該處的頻率值,單位MHz !!!
frequence=frequence/1000000;
frequence=frequence*x;
y=(double)frequence;
//寫w0數據
w=w0;
ad9850_bit_data=w; //w0
ad9850_w_clk_High;
ad9850_w_clk_Low;
//寫w1數據
w=(y>>24);
ad9850_bit_data=w; //w1
ad9850_w_clk_High;
ad9850_w_clk_Low;
//寫w2數據
w=(y>>16);
ad9850_bit_data=w; //w2
ad9850_w_clk_High;
ad9850_w_clk_Low;
//寫w3數據
w=(y>>8);
ad9850_bit_data=w; //w3
ad9850_w_clk_High;
ad9850_w_clk_Low;
//寫w4數據
w=(y>>=0);
ad9850_bit_data=w; //w4
ad9850_w_clk_High;
ad9850_w_clk_Low;
//移入始能
ad9850_fq_up_High;
ad9850_fq_up_Low;
// 測試程序1000Hz //
main()
WDTCTL=WDTPW+WDTHOLD;
P1DIR=0XFF;
P2DIR=0XFF;
//并行寫1000Hz程序
ad9850_reset();
ad9850_wr_parrel(0x00,1);
wuyutian51hei
2013-8-22 08:40
看了很不錯!可實用!
Vijay
2016-12-23 12:36
這要用到那幾個模塊
風蕭嘆
2017-4-27 21:22
非常不錯!謝謝樓主。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。!
