標題: 八位數碼管電子時鐘 protues模擬 [打印本頁]
作者: AllenWei    時間: 2020-12-2 21:41
八位數碼管電子時鐘
代碼
#include <reg51.h>
sbit key1 = P1^0;
bit flag1s = 0;
bit KeySta = 1;
unsigned char hour = 8;
unsigned char minute = 31;
unsigned char second = 59;
unsigned char mode = 0;
void FreshTime();
void TimeInit();
void IntInit();
void InitLedBuff();
void keyscan();
unsigned char code LedChar[] = {  //共陰數碼管顯示字符轉換表
    0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
    0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x00};
unsigned char LedBuff[8] = {  //數碼管顯示緩沖區
    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
    TimeInit();
    IntInit();
    InitLedBuff();
  while(1)//顯示內容處理
   if(flag1s&&!mode) //時間顯示模式
      flag1s = 0;
                  FreshTime();
     else if(mode == 1)  //校準分鐘
      LedBuff[0] = 17;
      LedBuff[1] = 17;
      LedBuff[4] = 17;
      LedBuff[5] = 17;//不顯示
          LedBuff[6] = 17;
      LedBuff[7] = 17;
      LedBuff[2] = minute/10;
      LedBuff[3] = minute%10;
    else if(mode == 2)  //校準小時
      LedBuff[2] = 17;
      LedBuff[3] = 17;
      LedBuff[4] = 17;
           LedBuff[6] = 17;
      LedBuff[7] = 17;
      LedBuff[0] = hour/10;
      LedBuff[1] = hour%10;
    else if(mode == 3)  //校準完成重新顯示
      InitLedBuff();
      mode = 0;
    keyscan();
void InitLedBuff()//初始化時間到顯示緩沖區
  LedBuff[4] = second/10;
  LedBuff[5] = second%10;
void FreshTime()//刷新時間到顯示緩沖區
  second++;
  if(second == 60)//進位
    second = 0;
    minute++;
    if(minute==60)//進位
      minute=0;
      hour++;
      if(hour == 24)
        hour = 0;
void TimeInit()//定時器初始化
  TMOD = 0X11;    //設置定時器為模式1
  TL0 = 0xB0;
  TH0 = 0x3C;     //定時初值 50ms
  TL1 = 0x18;                //
TH1 = 0xFC;                //定時初值 1ms
  TR0 = 1;    //定時器0開始計時
  TR1 = 1;    //定時器1開始計時
  ET1 = 1;    //使能定時器1
  ET0 = 1;    //使能定時器0
  PT0 = 1;    //提高計時準確性,提高定時器0中斷優先級
  EA = 1;     //打開總中斷
void IntInit()//外部中斷初始化
  IT0 = 1;     //下降沿觸發
  EX0 = 1;    //使能外部中斷0
void keyscan() //按鍵掃描及處理
  static bit backup = 1;
  if (KeySta != backup)  //當前值與前次值不相等說明此時按鍵有動作
    if (backup == 0)   //如果前次值為0,則說明當前是彈起動作
      if(mode == 1)   //校準分鐘時,分鐘加一
        minute++;
        if(minute==60)
          minute = 0;
      else if(mode == 2)    //校準小時,小時加一
        hour++;
        if(hour==24)
          hour = 0;
    backup = KeySta;   //更新備份為當前值,以備進行下次比較
void Int0() interrupt 0
  mode++;
  if(mode == 4)
    mode = 0;
void Ledfresh() //數碼管顯示刷新
  static unsigned char i = 0;
  switch(i)
    case 0 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[0]];i++;break;
    case 1 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[1]];i++;break;
    case 2 : P2 = ~(0x01<<i);P0 = 0x40;i++;break;//時分間隔線
    case 3 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[2]];i++;break;
    case 4 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[3]];i++;break;
    case 5 : P2 = ~(0x01<<i);P0 = 0x40;i++;break;//分秒間隔線
    case 6 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[4]];i++;break;
    case 7 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[5]];i=0;break;
void Time0() interrupt 1 // 50ms
  static unsigned char n = 0;
  TL0 = 0xB0;
  TH0 = 0x3C;
  n++;
  if(n==20)
    n=0;
    flag1s = 1;//1s標志位
void Time1() interrupt 3  // 1ms
  static unsigned char keybuff = 0xff;
  TL1 = 0x18;                //
  Ledfresh();
  keybuff = (keybuff<<1)|key1;
  if (keybuff == 0x00)
  {   //連續8次掃描值都為0,即16ms內都只檢測到按下狀態時,可認為按鍵已按下
      KeySta = 0;
  else if (keybuff == 0xFF)
  {   //連續8次掃描值都為1,即16ms內都只檢測到彈起狀態時,可認為按鍵已彈起
      KeySta = 1;
  {}  //其它情況則說明按鍵狀態尚未穩定,則不對KeySta變量值進行更新
八位數碼管電子時鐘.zip
18.14 KB, 下載次數: 64, 下載積分: 黑幣 -5
作者: 王企鵝    時間: 2022-10-8 23:59
程序寫的非常不錯的
作者: abslearn    時間: 2023-2-10 15:42
我是來拿程序看看的··謝謝分享···
