標(biāo)題: Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_48_Remote_Light [打印本頁]
作者: kaillen    時(shí)間: 2020-10-16 12:10
一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
圖1
二,調(diào)整原理圖大小,適合可視,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點(diǎn)擊Source Code標(biāo)簽。(如下圖5所示)
圖5
四,編輯main.py Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_48_Remote_Light (如下圖6所示)
五,Main.py 代碼:
# !/usr/bin/env python3
# Generated by Proteus Visual Designer for Raspberry Pi
# Modules
from goto import with_goto
from stddef import *
import var
import pio
import resource
from datetime import datetime
# Peripheral Configuration Code (Do Not Edit)
#---CONFIG_BEGIN---
import cpu
import FileStore
import VFP
import Ports
import Generic
import Controls
def peripheral_setup () :
# Peripheral Constructors
pio.cpu=cpu.CPU ()
pio.storage=FileStore.FileStore ()
pio.server=VFP.VfpServer ()
pio.uart=Ports.UART ()
pio.LED1=Generic.LED (pio.GPIO20)
pio.IotBtn1=Controls.PushButton ("IotBtn1", )
pio.IotLED1=Controls.Indicator ("IotLED1", )
pio.IotBtn2=Controls.PushButton ("IotBtn2", )
pio.storage.begin ()
pio.server.begin (0)
# Install interrupt handlers
pio.IotBtn1.attachEventHandler(chart_OnIotBtn1)
pio.IotBtn2.attachEventHandler(chart_OnIotBtn2)
def peripheral_loop () :
pass
#---CONFIG_END---
def variables_setup () :
# Flowchart Variables
pass
# Flowchart Routines
@with_goto
def chart_SETUP () :
pio.uart.setup (9600)
pio.uart.println ("Remote Light: \r\n")
return
@with_goto
def chart_LOOP () :
return
@with_goto
def chart_OnIotBtn1 () :
pio.IotLED1.setState (True)
pio.IotBtn1.setLamp (True)
pio.LED1.on ()
pio.uart.println ("Light on.")
return
@with_goto
def chart_OnIotBtn2 () :
pio.IotBtn1.setLamp (False)
pio.IotBtn2.setLamp (False)
pio.IotLED1.setState (False)
pio.uart.println ("Light off.")
return
# Main function
def main () :
# Setup
variables_setup ()
peripheral_setup ()
chart_SETUP ()
# Infinite loop
while True :
  peripheral_loop ()
  chart_LOOP ()
# Command line execution
if __name__ == '__main__' :
   main()
六,點(diǎn)擊構(gòu)建工程按鈕,編譯工程。(如下圖6所示)
圖6
七,點(diǎn)擊窗口左下方仿真按鈕,可見虛擬LED Light顯示。 (如下圖7,8,9所示)
圖7
圖8
圖9
八,選擇release,點(diǎn)擊構(gòu)建工程按鈕,編譯工程生成Hex文件。(如下圖10所示)
圖10
附件Proteus8.10 VSM Studio python編譯器仿真Raspberry_系列_48_Remote_Light在已安裝Proteus8.10的計(jì)算機(jī)文件夾中打開即可
需要進(jìn)一步了解,請(qǐng)加入QQ群:976235464
Raspberry_48_Remote_Light01.rar
192.46 KB, 下載次數(shù): 6, 下載積分: 黑幣 -5
作者: wjcxy3166    時(shí)間: 2021-2-1 13:23
謝謝樓主,下載好好學(xué)習(xí)下
