* linux/arch/arm/kernel/head.S
* Copyright (C) 1994-2002 Russell King
* Copyright (c) 2003 ARM Limited
* All Rights Reserved
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
* 所有32-bit CPU的內核啟動代碼
#include <linux/linkage.h>
#include <linux/init.h>
#if defined(CONFIG_ARCH_NETWINDER) || defined(CONFIG_ARCH_CATS)
* 如果我們在使用 NetWinder 或 CATS,我們也需要為調試信息映射
* 16550-type 串口
add r0, r4, #0xff000000 >> 18
orr r3, r7, #0x7c000000
str r3, [r0]
#endif
#ifdef CONFIG_ARCH_RPC
* Map in screen at 0x02000000 & SCREEN2_BASE
* Similar reasons here - for debug. This is
* only for Acorn RiscPC architectures.
add r0, r4, #0x02000000 >> 18
orr r3, r7, #0x02000000
str r3, [r0]
add r0, r4, #0xd8000000 >> 18
str r3, [r0]
#endif
#endif
mov pc, lr @頁表創建結束,返回
ENDPROC(__create_page_tables)
.ltorg
.align
__enable_mmu_loc:
.long .
.long __enable_mmu
.long __enable_mmu_end
#if defined(CONFIG_SMP)
__CPUINIT
ENTRY(secondary_startup)
* Common entry point for secondary CPUs.
* Ensure that we're in SVC mode, and IRQs are disabled. Lookup
* the processor type - there is no need to check the machine type
* as it has already been validated by the primary processor.
setmode PSR_F_BIT | PSR_I_BIT | SVC_MODE, r9
mrc p15, 0, r9, c0, c0 @ get processor id
bl __lookup_processor_type
movs r10, r5 @ invalid processor?
moveq r0, #'p' @ yes, error 'p'
THUMB( it eq ) @ force fixup-able long branch encoding
beq __error_p
* Use the page tables supplied from __cpu_up.
adr r4, __secondary_data
ldmia r4, {r5, r7, r12} @ address to jump to after
sub lr, r4, r5 @ mmu has been enabled
ldr r4, [r7, lr] @ get secondary_data.pgdir
add r7, r7, #4
ldr r8, [r7, lr] @ get secondary_data.swapper_pg_dir
adr lr, BSYM(__enable_mmu) @ return address
mov r13, r12 @ __secondary_switched address
ARM( add pc, r10, #PROCINFO_INITFUNC ) @ initialise processor
@ (return control reg)
THUMB( add r12, r10, #PROCINFO_INITFUNC )
THUMB( mov pc, r12 )
ENDPROC(secondary_startup)
* r6 = &secondary_data
ENTRY(__secondary_switched)
ldr sp, [r7, #4] @ get secondary_data.stack
mov fp, #0
b secondary_start_kernel
ENDPROC(__secondary_switched)
#ifdef CONFIG_SMP_ON_UP
__INIT
__fixup_smp:
and r3, r9, #0x000f0000 @ architecture version
teq r3, #0x000f0000 @ CPU ID supported?
bne __fixup_smp_on_up @ no, assume UP
mrc p15, 0, r0, c0, c0, 5 @ read MPIDR
and r0, r0, #0xc0000000 @ multiprocessing extensions and
teq r0, #0x80000000 @ not part of a uniprocessor system?
moveq pc, lr @ yes, assume SMP
/* __fixup_pv_table - patch the stub instructions with the delta between
* PHYS_OFFSET and PAGE_OFFSET, which is assumed to be 16MiB aligned and
* can be expressed by an immediate shifter operand. The stub instruction
* has a form of '(add|sub) rd, rn, #imm'.
__HEAD
__fixup_pv_table:
adr r0, 1f
ldmia r0, {r3-r5, r7}
sub r3, r0, r3 @ PHYS_OFFSET - PAGE_OFFSET
add r4, r4, r3 @ adjust table start address
add r5, r5, r3 @ adjust table end address
add r7, r7, r3 @ adjust __pv_phys_offset address
str r8, [r7] @ save computed PHYS_OFFSET to __pv_phys_offset
#ifndef CONFIG_ARM_PATCH_PHYS_VIRT_16BIT
mov r6, r3, lsr #24 @ constant for add/sub instructions
teq r3, r6, lsl #24 @ must be 16MiB aligned
#else
mov r6, r3, lsr #16 @ constant for add/sub instructions
teq r3, r6, lsl #16 @ must be 64kiB aligned
#endif
THUMB( it ne @ cross section branch )
bne __error
str r6, [r7, #4] @ save to __pv_offset
b __fixup_a_pv_table
ENDPROC(__fixup_pv_table)
