Arduino 1602時(shí)鐘計(jì)數(shù)器程序+接線(xiàn)照片
[打印本頁(yè)]
xcdzm
時(shí)間:
2020-9-9 22:59
1602時(shí)鐘計(jì)數(shù)器接線(xiàn)照片見(jiàn)附件。程序代碼:在Mixly1.1.5軟件編譯通過(guò)。
(311.42 KB, 下載次數(shù): 69)
2020-9-9 23:50 上傳
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
volatile int hour;
volatile int min2;
volatile int second;
String number;
LiquidCrystal_I2C mylcd(0x27,16,2);
String conversion(int x) {
number = x;
if (x < 10) {
number = String("0") + String(x);
return number;
void setup(){
hour = 0;
min2 = 0;
second = 0;
number = "";
mylcd.init();
mylcd.backlight();
void loop(){
delay(1000);
second = second + 1;
if (second == 60) {
min2 = min2 + 1;
second = 0;
if (min2 == 60) {
hour = hour + 1;
min2 = 0;
if (hour == 24) {
hour = 0;
min2 = 0;
second = 0;
mylcd.setCursor(0, 0);
mylcd.print("CLOCK :");
mylcd.setCursor(0, 1);
mylcd.print(String(String((conversion(hour))) + String(":")) + String(String((conversion(min2))) + String(":")) + String(conversion(second)));
ziba108
時(shí)間:
2023-7-30 12:36
喜歡算法,做實(shí)驗(yàn)驗(yàn)證
