標題: 關于單片機proteus仿真74HC138控制8 X 8點陣屏問題,麻煩大佬解答一下。 [打印本頁]
作者: 1061175125    時間: 2020-8-26 13:02
我現在用138譯碼器輸出一個低電平。8三極管的基極也是正常顯示7個高電平,一個低電平導通。但是又三個三極管的集電極仍然正常導通輸。麻煩大佬們解答一下。
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
    ENLED = 0;
    ADDR3 = 1;
    ADDR2 = 0;
    ADDR1 = 0;
    ADDR0 = 0;
    P0 = 0x00;
    while(1);
作者: 1061175125    時間: 2020-8-26 13:43
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code image[] = {
    0xFF, 0x99, 0x00, 0x00, 0x00, 0x81, 0xC3, 0xE7
    EA = 1;
    ENLED = 0;
    ADDR3 = 1;
    TMOD = 0x01;
    TH0  = 0xFC;
    TL0  = 0x67;
    ET0  = 1;
    TR0  = 1;
    while (1);
void InterruptTimer0() interrupt 1
    static unsigned char i = 0;
    TH0 = 0xFC;
    TL0 = 0x67;
    P0 = 0xFF;
    switch (i)
        case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=image[0]; break;
        case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=image[1]; break;
        case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=image[2]; break;
        case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=image[3]; break;
        case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=image[4]; break;
        case 5: ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=image[5]; break;
        case 6: ADDR2=1; ADDR1=1; ADDR0=0; i++; P0=image[6]; break;
        case 7: ADDR2=1; ADDR1=1; ADDR0=1; i=0; P0=image[7]; break;
        default: break;
用這個程序點陣的燈全部都是亮。。。。不知道為什么
作者: xianfajushi    時間: 2020-8-26 15:13
點陣為何要添加三極管?
作者: 1061175125    時間: 2020-8-26 18:25
xianfajushi 發表于 2020-8-26 15:13
點陣為何要添加三極管?
用的138譯碼器控制的。。低電平讓PNP三極管導通。
作者: 1061175125    時間: 2020-8-26 18:26
點陣為何要添加三極管?
我就想著用C138譯碼器去控制。有替代方案嘛。除了74HC595
作者: xianfajushi    時間: 2020-8-26 19:45
三極管電阻用74HC04多簡單
作者: wulin    時間: 2020-8-26 21:03
程序沒有什么問題,是仿真軟件的缺陷,把消隱代碼P0 = 0xFF;去掉試試。
  1. #include <reg52.h>
  2. sbit ADDR0 = P1^0;
  3. sbit ADDR1 = P1^1;
  4. sbit ADDR2 = P1^2;
  5. sbit ADDR3 = P1^3;
  6. sbit ENLED = P1^4;
  7. unsigned char code image[] = {
  8.     0xFF, 0x99, 0x00, 0x00, 0x00, 0x81, 0xC3, 0xE7
  9. };
  10. void main()
  11. {
  12.     EA = 1;
  13.     ENLED = 0;
  14.     ADDR3 = 1;
  15.     TMOD = 0x01;
  16.     TH0  = 0xFC;
  17.     TL0  = 0x67;
  18.     ET0  = 1;
  19.     TR0  = 1;
  20.     while (1);
  21. }
  22. void InterruptTimer0() interrupt 1
  23. {
  24.     static unsigned char i = 0;
  25.     TH0 = 0xFC;
  26.     TL0 = 0x67;
  27. //   P0 = 0xFF;
  28.     switch (i)
  29.     {
  30.         case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=~image[0]; break;
  31.         case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=~image[1]; break;
  32.         case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=~image[2]; break;
  33.         case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=~image[3]; break;
  34.         case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=~image[4]; break;
  35.         case 5: ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=~image[5]; break;
  36.         case 6: ADDR2=1; ADDR1=1; ADDR0=0; i++; P0=~image[6]; break;
  37.         case 7: ADDR2=1; ADDR1=1; ADDR0=1; i=0; P0=~image[7]; break;
  38.         default: break;
  39.     }
  40. }
作者: ty417502873    時間: 2020-8-26 21:47
1061175125 發表于 2020-8-26 18:26
max7219了解下
作者: xianfajushi    時間: 2020-8-27 08:24
巧了上次有做過點陣,就用16*16改一下
針對138修改代碼如下
138編碼器使用很簡單送入數據從0-7即可輸出8個引腳對應的低電平,從擺渡獲得真值表進行編寫;當然我這里做了相應的修改控制了E1,從代碼和電路圖中可看到。
源代碼地址http://www.raoushi.com/bbs/dpj-191849-1.html
作者: xianfajushi    時間: 2020-8-27 09:43
另外245也是可以使用04替代的,這樣可使用3片74HC04,比起使用電阻三極管元件就少了很多。
作者: xianfajushi    時間: 2020-8-27 09:53
也就是說如果套用我控制138的代碼的話,就可以實現對138的對應腳的控制。
作者: xianfajushi    時間: 2020-8-27 10:17
作者: 1061175125    時間: 2020-8-27 12:44
xianfajushi 發表于 2020-8-27 10:17
好的,我用74HC04。謝謝解答。
作者: xianfajushi    時間: 2020-8-28 19:12
138也算易用電路,同753一樣都屬于易用高速電路相比串口而言,753應用更廣適合用于數據擴展,而138只適用于控制單個數據。用1組IO按我這樣電路接法可控制5片138,而同樣用1組IO則可控制8片753,由此可比優劣,當然這要看電路需求確定適用哪種芯片更適合,另外選擇不同的點陣型號可節省使用反相器。
