標題: ESK32-360開發板的BMP085氣溫氣壓檢測 [打印本頁]
作者: jinglixixi 時間: 2020-8-23 08:46
本帖最后由 jinglixixi 于 2020-8-23 08:48 編輯
BMP085是一款基于I2C接口的數字式傳感器,主要用于測量氣溫、氣壓及海拔高度等,我們可以通過模擬I2C接口的方式來驅動該傳感器,以進行測量。
2020-8-23 08:44 上傳
整體構成
BMP085與MCU的連接關系如下:
SDA --- PC12
SCL --- PC11
定義引腳輸出高低電平的語句為:
#define SCL_Set() HT_GPIOC->SRR = GPIO_PIN_11
#define SCL_Clr() HT_GPIOC->RR = GPIO_PIN_11
#define SDA_Set() HT_GPIOC->SRR = GPIO_PIN_12
#define SDA_Clr() HT_GPIOC->RR = GPIO_PIN_12
BMP085的初始化函數為:
- void Init_BMP085()
- ac1 = Multiple_read(0xAA);
- ac2 = Multiple_read(0xAC);
- ac3 = Multiple_read(0xAE);
- ac4 = Multiple_read(0xB0);
- ac5 = Multiple_read(0xB2);
- ac6 = Multiple_read(0xB4);
- b1 = Multiple_read(0xB6);
- b2 = Multiple_read(0xB8);
- mb = Multiple_read(0xBA);
- mc = Multiple_read(0xBC);
- md = Multiple_read(0xBE);
讀取氣溫與氣壓的函數為:
- void bmp085Convert()
- unsigned int ut;
- unsigned long up;
- long x1, x2, b5, b6, x3, b3, p;
- unsigned long b4, b7;
- ut = bmp085ReadTemp();
- up = bmp085ReadPressure();
- x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
- x2 = ((long) mc << 11) / (x1 + md);
- b5 = x1 + x2;
- temperature = ((b5 + 8) >> 4);
- b6 = b5 - 4000;
- x1 = (b2 * (b6 * b6)>>12)>>11;
- x2 = (ac2 * b6)>>11;
- x3 = x1 + x2;
- b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
- x1 = (ac3 * b6)>>13;
- x2 = (b1 * ((b6 * b6)>>12))>>16;
- x3 = ((x1 + x2) + 2)>>2;
- b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
- b7 = ((unsigned long)(up - b3) * (50000>>OSS));
- if (b7 < 0x80000000)
- p = (b7<<1)/b4;
- else
- p = (b7/b4)<<1;
- x1 = (p>>8) * (p>>8);
- x1 = (x1 * 3038)>>16;
- x2 = (-7357 * p)>>16;
- pressure = p+((x1 + x2 + 3791)>>4);
獲取海拔高度的函數為:
- long BMP085_Get_Altitude(long Pressure)
- long altitude;
- altitude=44330.0*(1-pow((double)Pressure/101325,1/5.255));
- altitude*=100;
- return altitude;
檢測的主程序為:
- int main(void)
- SYSTICK_ClockSourceConfig(SYSTICK_SRC_STCLK);
- SYSTICK_SetReloadValue(SystemCoreClock / 8 / 1000);
- SYSTICK_IntConfig(ENABLE);
- UxART_Configuration();
- IIC_Init();
- Init_BMP085();
- while(1)
- bmp085Convert();
- ConvTemperature();
- ConvPressure();
- ConvAltitude();
- Delayms(1000);
2020-8-23 08:44 上傳
檢測值輸出顯示
