這個是什么意思FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
happyjh1
2020-8-7 20:53
Build target 'Target 1'
linking...
BL51 BANKED LINKER/LOCATER V6.22.2.0 - SN: Eval Version
COPYRIGHT ARM Germany GmbH 1987 - 2017
"lcd.obj",
"main.obj",
"key.obj",
"i2c.obj",
"KeyScan.obj"
TO "template"
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
SEGMENT: ?PR?_KEYSCAN_DELAY1MS?KEYSCAN
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 0A85H BYTE (131%) *
Program Size: data=9.4 xdata=63 code=2944
LINK/LOCATE RUN COMPLETE. 1 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
MODULE: E:\KEIL_V51\C51\LIB\C51L.LIB (-----)
LIMIT: 0800H BYTES
Target not created.
Build Time Elapsed: 00:00:00
wulin
2020-8-8 06:27
貌似編輯軟件沒有授權
TTQ001
2020-8-8 09:27
您的C51編譯器具有代碼大小限制。
angmall
2020-8-8 10:32
請支持正版。
還在為2020年時間到期而煩惱嗎?不用怕
