標(biāo)題: 單片機(jī)16X192點(diǎn)陣Proteus仿真程序 [打印本頁]
作者: 1551531584    時(shí)間: 2020-6-8 12:01
單片機(jī)驅(qū)動(dòng)16✘192仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源程序如下:
  1. #include<AT89X52.H>
  2. sbit ST=P3^5;
  3. sbit E1=P3^4;
  4. sbit MR=P3^7;
  5. char cashe[12];
  6. char code wd[12][16]={
  7. {0xFF,0xC0,0xFE,0xFE,0xFE,0xFE,0x80,0xFE,0xFD,0xFD,0xFB,0xF7,0xEF,0xDF,0x3F,0xFF},
  8. {0xFF,0x03,0xFF,0xFF,0xFF,0xFF,0x01,0x7F,0x7F,0x7F,0x7F,0x7F,0x7D,0x7D,0x81,0xFF},/*"無",0*/
  9. /* (16 X 16 , 宋體 )*/
  10. {0xDF,0xDF,0xDF,0xCF,0x57,0x58,0x5F,0xDF,0xDE,0xDE,0xDE,0xDD,0xDD,0xDB,0xDB,0xD7},
  11. {0x7F,0x6F,0x73,0x77,0x7F,0x01,0x5F,0x5F,0xDF,0xDF,0xDF,0xDF,0xDD,0xDD,0xE1,0xFF},/*"憂",1*/
  12. /* (16 X 16 , 宋體 )*/
  13. {0xFE,0xFE,0xFE,0xC0,0xDE,0xDE,0xC0,0xDE,0xDE,0xDE,0xC0,0xDE,0xFE,0xFE,0xFF,0xFF},
  14. {0xFF,0xFF,0xFF,0x07,0xF7,0xF7,0x07,0xF7,0xF7,0xF7,0x07,0xF7,0xFD,0xFD,0x01,0xFF},/*"電",2*/
  15. /* (16 X 16 , 宋體 )*/
  16. {0xFF,0xC0,0xFF,0xFF,0xFF,0xFE,0xFE,0xFE,0x00,0xFE,0xFE,0xFE,0xFE,0xFE,0xFA,0xFD},
  17. {0xFF,0x0F,0xDF,0xBF,0x7F,0xFF,0xFF,0xFB,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/*"子",3*/
  18. /* (16 X 16 , 宋體 )*/
  19. {0xFF,0x83,0xBB,0xAB,0xAA,0xAA,0xA9,0xAB,0xAB,0xAA,0xEE,0xD7,0xDB,0xBB,0x7F,0xFF},
  20. {0x7F,0x3F,0x7F,0x01,0xFD,0xFD,0xBD,0xBD,0x5D,0xED,0x05,0xED,0xFD,0xFD,0xEB,0xF7},/*"購",4*/
  21. /* (16 X 16 , 宋體 )*/
  22. {0xEF,0xEF,0xAF,0xAE,0x82,0xAD,0x6B,0xEB,0xE6,0xCD,0x2B,0xEF,0xEE,0xED,0xEB,0xFF},
  23. {0x7F,0x7F,0x7F,0x03,0xAB,0xAB,0x6B,0x6B,0xDB,0xDB,0xBB,0x7B,0xFB,0xFB,0xD7,0xEF},/*"物",5*/
  24. /* (16 X 16 , 宋體 )*/
  25. };
  26. void del(int i)//============================//延時(shí)程序
  27. {while(i--);}
  28. aline()        ////=======================發(fā)送一行的顯示程序
  29. {
  30. char i=0;
  31. TI=0;
  32. for(i=0;i<12;i++)
  33. {SBUF=cashe[i];while(~TI);TI=0;} //將緩存中的信息轉(zhuǎn)存入595的存儲(chǔ)器中,到此不顯示
  34. }
  35. main()
  36. {
  37. int m=0,n=0;
  38.         TI=0;
  39.         SM0=0;
  40.         SM1=0;
  41. E1=0;
  42. while(1)
  43. for(m=0;m<16;m++)      //共有16行  循環(huán)16次顯示這16行  串行的595送出行的數(shù)據(jù)
  44.         {                                        //由74hc154選中要顯示的行
  45.         for(n=0;n<12;n++)         //這個(gè)for循環(huán)用來向緩存數(shù)組中裝載要顯示的內(nèi)容
  46.                 {cashe[11-n]=wd[n][m];}  //將第m個(gè)字的第n行信息裝載  ,因?yàn)?95串接 數(shù)據(jù)第一個(gè)進(jìn)去的會(huì)在最后一個(gè)595中,最后進(jìn)去的會(huì)在第一個(gè)595中
  47.     aline();     //將緩存中的一行信息載入595緩存中
  48.         ST=0;ST=1; //595產(chǎn)生上升沿 輸出595鎖存的數(shù)據(jù)
  49.         P2=m;  //選中要顯示的行輸出數(shù)據(jù)
  50.
  51.         del(100);//延時(shí)一段時(shí)間,以造成視覺暫存效應(yīng)
  52.           }
  53. }
16X192.zip (1.03 MB, 下載次數(shù): 21)
作者: songxia8013    時(shí)間: 2020-6-9 08:14
樓主,您這是16*192嗎?我怎么看著是16*96啊!
作者: 537224    時(shí)間: 2020-10-8 03:54
仿真打不開啊。為什么呢?
作者: 51hei團(tuán)團(tuán)    時(shí)間: 2020-10-8 03:58
537224 發(fā)表于 2020-10-8 03:54
仿真打不開啊。為什么呢?
_dsn改為.dsn就可以了,作者不知道什么原因改了文件名
