求大佬看下單片機程序的問題,在實物中小車不動
我是靴子
2020-5-23 22:50
<避障小車的問題,在實物中小車不動
#include<reg52.h> //此文件中定義了單片機的一些特殊功能寄存器
#include"lcd.h"
#include<intrins.h>
#define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
#define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
/***************超聲波**I/O口******************/
sbit Trig = P2^3; //超聲波測距模塊Trig
sbit Echo = P2^4; //超聲波測距模塊Echo
/*****************蜂鳴器******************/
sbit beep = P2^7; //蜂鳴器
/*****************舵機******************/
sbit SG_PWM = P3^7; //舵機
/****************電機驅動**IO口******************/
/*使能端*/
sbit ENA = P2^5; //左下電機pwm信號端
sbit ENB = P2^6; //右下電機pwm信號端
sbit ENC = P3^0; //左上電機pwm信號端
sbit END = P3^1; //右上電機pwm信號端
/*電機口*/
sbit IN1 = P1^0;
sbit IN2 = P1^1;
sbit IN3 = P1^2;
sbit IN4 = P1^3;
sbit IN5 = P1^4;
sbit IN6 = P1^5;
sbit IN7 = P1^6;
sbit IN8 = P1^7;
/***************定義全局變量******************/
static unsigned char DisNum = 0; //顯示用指針
unsigned char table[]="Distance:";
unsigned char code ASCII[13] = {'0','1','2','3','4','5','6','7','8','9','.','-','M',};
unsigned int time=0; //用于存放定時器時間的值
unsigned long S=0; //用于存放距離的值
unsigned long S1=0;
unsigned long S2=0;
unsigned long S3=0;
unsigned int timer=10000; //延時基準變量
bit flag =0; //超聲波超出量程溢出標志位
unsigned char disbuff[4] = { 0,0,0,0,}; //用于存放距離的值0.1mm、mm、cm和m的值
unsigned char pwm_val_left1 = 0; //左下電機變量定義
unsigned char pwm_val_right1 =0; //右下電機變量定義
unsigned char pwm_val_left2 = 0; //左上電機變量定義
unsigned char pwm_val_right2 = 0; //右下電機變量定義
unsigned char push_val_left1 = 0; //左下電機占空比N/20
unsigned char push_val_right1 =0; //右下電機占空比N/20
unsigned char push_val_left2 = 0; //左上電機占空比N/20
unsigned char push_val_right2 = 0; //右下電機占空比N/20
unsigned char count=0; //0.2ms次數標識
unsigned char PWM_count=5; //舵機歸中
* 函 數 名 : Delay1ms
* 函數功能 : 延時函數,延時1ms
void Delay1ms(uint j)
uchar k;
while(j--)
for(k = 120; k > 0; k--);
* 函 數 名 : feng
* 函數功能 : 報警函數
void feng()
if(S<=40)
beep=~beep;
Delay1ms(50);
beep=1;
void StartModule() //啟動模塊
Trig=1; //啟動一次模塊
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
Trig=0;
//計算距離
void Conut(void)
TH0=0;
TL0=0;
while(!Echo); //當RX為零時等待
TR0=1; //開啟計數
while(Echo); //當RX為1計數并等待
TR0=0; //關閉計數
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.7)/100; //算出來是CM
if((S>=450)||flag==1) //超出測量范圍顯示“-”
flag=0;
DisplayOneChar(10, 0, ASCII[11]);
DisplayOneChar(11, 0, ASCII[10]); //顯示點
DisplayOneChar(12, 0, ASCII[11]);
DisplayOneChar(13, 0, ASCII[11]);
DisplayOneChar(14, 0, ASCII[12]); //顯示M
disbuff[0]=S%1000/100;
disbuff[1]=S%1000%100/10;
disbuff[2]=S%1000%10 %10;
DisplayOneChar(10, 0, ASCII[disbuff[0]]);
DisplayOneChar(12, 0, ASCII[disbuff[1]]);
DisplayOneChar(13, 0, ASCII[disbuff[2]]);
void Timer0() interrupt 1 //T0中斷用來計數器溢出,超過測距范圍
flag=1; //中斷溢出標志
void run(void) //前進
push_val_left1 = 10; //PWM 調節參數1-20 1為最慢,20是最快 改這個值可以改變其速度
push_val_right1 = 10;
push_val_left2 = 10;
push_val_right2 = 10;
IN1 = 1;
IN2 = 0;
IN3 = 1;
IN4 = 0;
IN5 = 1;
IN6 = 0;
IN7 = 1;
IN8 = 0;
void backrun(void) //后退
push_val_left1 = 8; //PWM 調節參數1-20 1為最慢,20是最快 改這個值可以改變其速度
push_val_right1 = 8;
push_val_left2 = 8;
push_val_right2 = 8;
IN1 = 0;
IN2 = 1;
IN3 = 0;
IN4 = 1;
IN5 = 0;
IN6 = 1;
IN7 = 0;
IN8 = 1;
void leftrun(void) //左轉
push_val_left1 = 7; //PWM 調節參數1-20 1為最慢,20是最快 改這個值可以改變其速度
push_val_right1 = 7;
push_val_left2 = 7;
push_val_right2 = 7;
IN1 = 0;
IN2 = 0;
IN3 = 1;
IN4 = 0;
IN5 = 0;
IN6 = 0;
IN7 = 1;
IN8 = 0;
void rightrun(void) //右轉
push_val_left2 = 7;
IN1 = 1;
IN2 = 0;
IN3 = 0;
IN4 = 0;
IN5 = 1;
IN6 = 0;
IN7 = 0;
IN8 = 0;
void stop(void) //停止
IN1 = 0;
IN2 = 0;
IN3 = 0;
IN4 = 0;
IN5 = 0;
IN6 = 0;
IN7 = 0;
IN8 = 0;
//pwm控制電機速度
void pwm_out_left1_moto(void) //左下電機
if(pwm_val_left1<=push_val_left1)
ENA=1;
ENA=0;
if(pwm_val_left1>=20)
pwm_val_left1=0;
ENA=0;
void pwm_out_right1_moto(void) //右下電機
if(pwm_val_right1<=push_val_right1)
ENB=1;
ENB=0;
if(pwm_val_right1>=20)
pwm_val_right1=0;
ENB=0;
void pwm_out_left2_moto(void) //左上電機
if(pwm_val_left2<=push_val_left2)
ENC=1;
ENC=0;
if(pwm_val_left2>=20)
pwm_val_left2=0;
ENC=0;
void pwm_out_right2_moto(void) //右上電機
if(pwm_val_right2<=push_val_right2)
END=1;
END=0;
if(pwm_val_right2>=20)
pwm_val_right2=0;
END=0;
void timer1 () interrupt 3 //中斷產生pwm信號
TH1=0xFC;
TL1=0x18; //1ms延時
pwm_val_left1++;
pwm_val_right1++;
pwm_val_left2++;
pwm_val_right2++;
pwm_out_left1_moto();
pwm_out_right1_moto();
pwm_out_left2_moto();
pwm_out_right2_moto();
//舵機控制方向函數
void COMM(void)
count=1; //舵機向左轉90度
Delay1ms(1000); //延時1000ms讓舵機轉到位置
StartModule(); //啟動測距
Conut();
S2=S; //得到左邊距離
count=9; //舵機右轉
Conut();
S3=S; //得到右邊距離
count=5; //舵機歸中
Conut();
S1=S; //得到中間距離
if((S2<10)||(S3<10)) //只要左右各有距離小于10CM小車后退
backrun();
Delay1ms(1000);
if(S2>S3) //車的左邊比車的右邊距離小右轉
rightrun();
Delay1ms(1000);
else //車的左邊比車的右邊距離大 左轉
leftrun();
Delay1ms(1000);
void Timer2() interrupt 5
TF2=0;
TH2=(65536-200)>>8;
TL2=(65536-200);
count=count+1;
if(count >100)
count = 0;
if(count<=compare)
SG_PWM=1;
SG_PWM=0;
} //次數始終保持為40即保持周期為20ms
/***************初始化定時器************/
void init_T0()
TMOD=0x01; //設T0為方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1; //允許T0中斷
EA=1; //開啟總中斷
void init_T1()
TMOD=0x11; //設T1為方式1,GATE=1;
TH1=0xFC;
TL1=0x18; //1ms延時
ET1=1; //允許T1中斷
EA=1; //開啟總中斷
TR1=1; //t1開啟及時
void init_T2()
T2CON=0;
TH2=0xfe;
TL2=0x0c; //0.5ms
ET2=1; //允許T1中斷
EA=1; //開啟總中斷
TR2=1; //t2開啟及時
init_T0();
init_T1();
init_T2();
LcdInit();
LcdShowStr(0,0,table);
Delay1ms(5);
count=5;
StartModule();
Conut();
feng();
if(S<=10)
stop();
COMM();
run();
