標題: 100000秒以內(nèi)的計時單片機程序+Proteus仿真 [打印本頁]
作者: dong12    時間: 2020-5-11 10:49
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. uchar Count;
  6. sbit Dot = P0^7;
  7. uchar code DSY_CODE[]=
  8. {
  9.         0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
  10. };
  11. uchar Digits_of_6DSY[]={0,0,0,0,0,0};
  12. void DelayMS(uint x)
  13. {
  14.         uchar i;
  15.         while(--x)
  16.         {
  17.                  for(i=0;i<120;i++);
  18.         }
  19. }
  20. void main()
  21. {
  22.         uchar i,j;
  23.         P0 = 0x00;
  24.         P3 = 0xff;
  25.         Count =0;
  26.         TMOD = 0x01;
  27.         TH0  = (65535-50000)/256;
  28.         TL0  = (65535-50000)%256;
  29.         IE = 0x82;
  30.         TR0 = 1;
  31.         while(1)
  32.         {
  33.                  j = 0x7f;
  34.                 for(i=5;i!=-1;i--)
  35.                 {
  36.                          j=_crol_(j,1);
  37.                         P3 = j;
  38.                         P0 = DSY_CODE[Digits_of_6DSY[i]];
  39.                         if(i==1) P0 |= 0x80;
  40.                         DelayMS(2);
  41.                 }
  42.         }
  43. }
  44. void Time0() interrupt 1
  45. {
  46.         uchar i;
  47.         TH0  = (65535-50000)/256;
  48.         TL0  = (65535-50000)%256;
  49.         if(++Count !=2) return;
  50.         Count = 0;
  51.         Digits_of_6DSY[0]++;
  52.         for(i=0;i<=5;i++)
  53.         {
  54.                  if(Digits_of_6DSY[i] == 10)
  55.                 {
  56.                          Digits_of_6DSY[i] = 0;
  57.                         if(i != 5) Digits_of_6DSY[i+1]++;
  58.                 }
  59.                 else break;
  60.         }
  61. }
100000秒以內(nèi)的計時程序.zip (50.33 KB, 下載次數(shù): 12)
作者: xiaodong11    時間: 2020-5-14 11:01
不錯的資料
