單片機(jī)+LCD12864一級(jí)菜單顯示源程序
時(shí)間:
2020-4-22 18:35
#include <reg52.h>
#include<stdio.h>
uchar lcd_x,lcd_y,data_byte=0,count;
uint TH_data,TL_data,RH_data,RL_data,CK_data;
uint TH_temp,TL_temp,RH_temp,RL_temp,CK_temp;
uchar num,ldata=0,lold=1;
sbit RS = P2^0;//并行指令,數(shù)據(jù)選擇信號(hào)
sbit RW = P2^1;//讀寫信號(hào)
sbit EN = P2^2;//并行使能信號(hào)
sbit PSB = P2^3;//并串口選擇信號(hào)
sbit RST = P2^5;//復(fù)位信號(hào)
sbit key1 = P2^6; //定義按鍵1
sbit key2 = P2^7; //定義按鍵2
void delay(uint a);//延時(shí)函數(shù)
void delay0(unsigned int time);//延時(shí)函數(shù)
void LCD_init();//LCD初始化程序
void write_cmd(uchar cmd);//寫指令
void write_data(uchar dat);//寫數(shù)據(jù)
bit check_busy();//檢測LCD忙信號(hào)
void delay1();//10us延時(shí)
void lcd_dis_code(uint cmd_addr,uchar num,uchar dis[]);//顯示函數(shù)
uchar code lcd0[]={" 科協(xié)菜單"};
uchar code lcd1[]={"1:攝像頭"};
uchar code lcd2[]={"2:傳感器"};
uchar code lcd3[]={"3:液晶顯示"};
uchar code lcd4[]={"4:單片機(jī)"};
uchar code lcd5[]={"5:紅外傳感器"};
uchar code lcd6[]={"6:MAX232"};
uchar code lcd7[]={"7:晶振"};
uchar code lcd8[]={"8:單片機(jī)"};
uchar code lcd9[]={"9:紅外傳感器"};
uchar code lcd10[]={"10:MAX232"};
uchar code lcd11[]={"11:晶振"};
LCD_init();
{ //循環(huán)掃描按鍵及顯示
if(key1==0)
{ //按鍵1按下
delay(5);
if(key1==0)
{ //是否是剛按下,是執(zhí)行,否則不執(zhí)行
ldata=ldata+1; //顯示數(shù)據(jù)加1
//lold=0; //處理完,將按鍵視為按下
else if(key2==0)
{ //按鍵2按下
delay(5);
if(key2==0){ //是否是剛按下,是執(zhí)行,否則不執(zhí)行
ldata--; //顯示數(shù)據(jù)減1
// lold=0; ////處理完,將按鍵視為按下
switch(ldata)
case 0:{
lcd_dis_code(0x80,10,lcd0);
lcd_dis_code(0x90,8,lcd1);
lcd_dis_code(0x88,8,lcd2);
lcd_dis_code(0x98,12,lcd3);
break;
case 1:{
lcd_dis_code(0x80,8,lcd4);
lcd_dis_code(0x90,12,lcd5);
lcd_dis_code(0x88,8,lcd6);
lcd_dis_code(0x98,5,lcd7);
break;
case 2:{
lcd_dis_code(0x80,8,lcd8);
lcd_dis_code(0x90,12,lcd9);
lcd_dis_code(0x88,9,lcd10);
lcd_dis_code(0x98,12,lcd11);
break;
void delay1()//延時(shí)10us
unsigned char i;
for(i=0; i<3; i++);
/**********************12864模塊程序**********************/
uint i;
write_cmd(cmd_addr);
for(i=0; i<num; i++)
write_data(dis[i]);
void LCD_init()
PSB = 1;
RST = 0;
delay(5);
RST = 1;
//write_cmd(0x34);//擴(kuò)充指令
delay(5);
write_cmd(0x30);//基本指令
//delay(5);
//write_cmd(0x0f);//顯示開關(guān)光標(biāo)
delay(5);
write_cmd(0x0c);
delay(10);
write_cmd(0x01);//清屏
delay(5);
write_cmd(0x06);
delay(20);
bit check_busy()
bit temp;
RS = 0;
RW = 1;
EN = 1;
delay(5);
temp = (bit)(P0&0x80); //按位與操作
EN = 0;
return (temp);
while(check_busy());
RS = 0;
RW = 0;
EN = 0;
delay(5);
P0 = cmd;
delay(5);
EN = 1;
delay(5);
EN = 0;
RS = 1;
RW = 0;
EN = 0;
P0 = dat;
delay(5);
EN = 1;
delay(5);
EN = 0;
void delay(uint a)
uchar i;
while(a--)
for(i=0; i<113; i++);
while(time--);
柯柯柯
時(shí)間:
2020-5-16 16:13
不錯(cuò),謝謝分享
