STM32F407ZET6串口調試程序
douyuaabb
2020-4-3 09:13
STM32F407ZET6串口調試程序
使用到了串口123,并且可以和HC-05藍牙模塊進行通信,發送/接收數據
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f4xx.h"
#include "USART.h"
#include "usart3.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static __IO uint32_t uwTimingDelay;
RCC_ClocksTypeDef RCC_Clocks;
/* Private function prototypes -----------------------------------------------*/
static void Delay(__IO uint32_t nTime);
/* Private functions ---------------------------------------------------------*/
* @brief Main program
* @param None
* @retval None
int main(void)
char str3[] = "hahahahaha\r\n";
/*設置Systick為ms級*/
SysTick_Config(SystemCoreClock/1000-1);
/*設置中斷優先級占比*/
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/*配置調試串口*/
gec_debug(115200);
usart3_init(9600);
while (1)
usart3_send_string(str3);
* @brief Inserts a delay time.
* @param nTime: specifies the delay time length, in milliseconds.
* @retval None
uwTimingDelay = nTime;
while(uwTimingDelay != 0);
* @brief Decrements the TimingDelay variable.
* @param None
* @retval None
void TimingDelay_Decrement(void)
if (uwTimingDelay != 0x00)
uwTimingDelay--;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
STM32串口調試.7z
(94.41 KB, 下載次數: 38)
2020-4-3 14:00 上傳
