標題: 藍橋杯單片機開發第3屆溫度監控器及源代碼 [打印本頁]
作者: 我是怪人    時間: 2020-3-24 19:01
#include <stc15f2k60s2.h>
sbit S7 = P3^0;
sbit S6 = P3^1;
sbit S5 = P3^2;
sbit S4 = P3^3;
sbit dianji = P3^4;
unsigned char code LedChar[] = {
  0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,
        0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F
unsigned char LedBuff[8] = {
  0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned char temp_min = 23;  //溫度下限
unsigned char temp_max = 30;  //溫度上限
unsigned char get_temp = 0;   //獲取電機溫度
void InitSystem();
void ScanSMG();
void Timer0Init(void);                //10微秒@12.000MHz
void Timer1Init(void);                //1毫秒@12.000MHz
void ConfigWorking();
void ConfigSMG();
void ScanKeys();
extern void I2CWrite(unsigned char addr,unsigned char dat); //I2C寫操作
extern unsigned char I2CRead(unsigned char addr);          //I2C讀操作
extern bit Init18B20();     //18B20初始化
extern unsigned char Get18B20Temp();  //獲取18B20溫度
  Timer0Init();
        Timer1Init();
        InitSystem();
        temp_min = I2CRead(0x01);  //讀取溫度下限
        temp_max = I2CRead(0x00);  //讀取溫度上限
          ConfigWorking();
                ConfigSMG();
                ScanKeys();
/******HC573選擇函數*******/
void SeceltHC573(unsigned char channel)
  switch(channel)
          case 4:P2 = (P2&0x1F)|0x80;break;
                case 5:P2 = (P2&0x1F)|0xA0;break;
                case 6:P2 = (P2&0x1F)|0xC0;break;
                case 7:P2 = (P2&0x1F)|0xE0;break;
                default:P2 = (P2&0x1F)|0x00;break;
/*******關閉LED和蜂鳴器、繼電器******/
void InitSystem()
  SeceltHC573(5);
        P0 = 0x00;
        SeceltHC573(4);
        P0 = 0xFF;
        SeceltHC573(0);
/******工作模式配置*******/
  Init18B20();
        get_temp = Get18B20Temp();
        if(get_temp<temp_min)
          EA = 0;        //存儲的溫度下限數據, 繼電器打開
                SeceltHC573(5);
                P0 = 0x10;
                SeceltHC573(0);
                EA = 1;
                SeceltHC573(5);
                P0 = 0x00;
                SeceltHC573(0);
                EA = 1;
/******數碼管的動態顯示******/
void ConfigSMG()
  LedBuff[0] = LedChar[temp_max/10];
        LedBuff[1] = LedChar[temp_max%10];
        LedBuff[2] = LedChar[temp_min/10];
        LedBuff[3] = LedChar[temp_min%10];
        LedBuff[4] = 0xFF;
        LedBuff[5] = 0xFF;
        LedBuff[6] = LedChar[get_temp/10];
        LedBuff[7] = LedChar[get_temp%10];
/******按鍵處理相關函數******/
void Delay1ms()                //@12.000MHz
        unsigned char i, j;
        i = 12;
        j = 169;
        do
                while (--j);
        } while (--i);
void ScanKeys()
        if(S7==0)         //溫度下限減一
          Delay1ms();
                if(S7==0)
                        if(temp_min>0)
                                temp_min--;
                                temp_min = 0;
                        I2CWrite(0x01,temp_min);   //存儲溫度下限
                        Delay1ms();
                  while(S7==0)
                          ConfigSMG();
  if(S6==0)         //溫度上限減一
          Delay1ms();
                if(S6==0)
                        if((temp_max>temp_min)&&(temp_max>0))
                          temp_max--;
                          temp_max = temp_min;
                        I2CWrite(0x00,temp_max);   //存儲溫度上限
                        Delay1ms();
                  while(S6==0)
                          ConfigSMG();
        if(S5==0)         //溫度下限加一
          Delay1ms();
                if(S5==0)
                        if((temp_min<temp_max)&&(temp_min<99))
                          temp_min++;
                          temp_min = temp_max;
                        Delay1ms();
                  while(S5==0)
                          ConfigSMG();
        if(S4==0)         //溫度上限加一
          Delay1ms();
                if(S4==0)
                        temp_max++;
                        if(temp_max>=99)
                                temp_max = 99;
                        Delay1ms();
                  while(S4==0)
                          ConfigSMG();
/******數碼管動態刷新*****/
void ScanSMG()
  static unsigned char i = 0;
        P0 = 0xFF;
        SeceltHC573(6);
        P0 = 0x01<<i;
        SeceltHC573(7);
        P0 = LedBuff[i++];
        if(i>=8)
                i = 0;
        SeceltHC573(0);
/******定時器0初始化函數******/
void Timer0Init(void)                //10微秒@12.000MHz
        AUXR &= 0x7F;                //定時器時鐘12T模式
        TMOD &= 0xF0;                //設置定時器模式
        TL0 = 0xF6;                //設置定時初值
        TH0 = 0xFF;                //設置定時初值
        TF0 = 0;                //清除TF0標志
        TR0 = 1;                //定時器0開始計時
        ET0 = 1;
        EA = 1;
void InterruptTimer0()  interrupt 1
  static unsigned char pwn= 0;
        pwn++;
        if(pwn<=30)
          dianji = 0;
        else if(pwn>100)
          dianji = 0;
                pwn = 0;
          dianji = 1;
void Timer1Init(void)                //1毫秒@12.000MHz
        AUXR &= 0xBF;                //定時器時鐘12T模式
        TMOD &= 0x0F;                //設置定時器模式
        TL1 = 0x18;                //設置定時初值
        TH1 = 0xFC;                //設置定時初值
        TF1 = 0;                //清除TF1標志
        TR1 = 1;                //定時器1開始計時
        ET1 = 1;
        EA = 1;
void InterruptTimer1()  interrupt 3
  ScanSMG();   //數碼管動態刷新
省賽試題-第3屆-溫度監控儀.pdf
154.82 KB, 下載次數: 16, 下載積分: 黑幣 -5
第3屆溫度監控器_1.rar
52.11 KB, 下載次數: 16, 下載積分: 黑幣 -5
