基于51單片機的數字鍵盤模塊+Protues仿真
954544619
2020-3-12 10:28
(26.5 KB, 下載次數: 53)
2020-3-12 10:26 上傳
部分代碼:
#include<AT89X52.h>
#include <intrins.h>
#define Delaynop(){_nop_();_nop_();_nop_();_nop_();}
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
void Delayms(unsigned int ms);
bit LCD_Busy();
void LCD_Pos(unsigned char);
void LCD_Wcmd(unsigned char);
void LCD_Wdat(unsigned char);
char code Title_Text[]={"--Phone Code-- "};
unsigned char code Key_Table[]={'1','2','3','4','5','6','7','8','9','*','0','#'};
unsigned char Dial_Code_Str[]={" "};
unsigned char KeyNo=0xff;
int tCount=0;
//毫秒級延時函數
void Delayms(unsigned int x)
unsigned char i;
while(x--)
for(i=0;i<120;i++);
//顯示字符串
void Display_String(unsigned char *str,unsigned char LineNo)
unsigned char k;
LCD_Pos(LineNo);
for(k=0;k<16;k++)
LCD_Wdat(str[k]);
//檢查1602是否處于忙裝填
bit LCD_Busy_Check()
bit Result;
RS=0;
RW=1;
EN=1;
Delaynop();
Result=(bit)(P0 & 0x80);
EN=0;
return Result;
//向1602寫入指令的函數
void LCD_Write_Command(unsigned char cmd)
while(LCD_Busy_Check()); //檢查是否處于忙狀態
RS=0;
RW=0;
EN=0;
_nop_();
_nop_();
P0=cmd; //寫入指令
Delaynop();
EN=1;
Delaynop();
EN=0;
//向1602寫數據
void LCD_Wdat(unsigned char dat)
RS=1;
RW=0;
EN=0;
P0=dat; //寫入數據
Delaynop();
EN=1;
Delaynop();
EN=0;
//初始化1602
void Init_LCD()
LCD_Write_Command(0x38);Delayms(5);
LCD_Write_Command(0x01);Delayms(5);
LCD_Write_Command(0x06);Delayms(5);
LCD_Write_Command(0x0c);Delayms(5);
//設置顯示位置
void LCD_Pos(unsigned char pos)
LCD_Write_Command(pos|0x80);
//T0的中斷服務子函數
void T0Deal()interrupt 1
TH0=-600/256;
TL0=-600%256;
if(++tCount==200)
tCount=0;
TR0=0;
//按鍵掃描函數,返回值為對應的按鍵編碼
unsigned char GetKey()
unsigned char i,j,k=0;
unsigned char KeyScanCode[]={0xef,0xdf,0xbf,0x7f}; //行列掃描的行列碼
unsigned char KeyCodeTable[]={
0xee,0xed,0xeb,0xde,0xdd,0xdb,0xbe,0xbd,0xbb,0x7e,0x7d,0x7b};
P3=0x0f;
if(P3!=0x0f) //如果有按鍵被按下
for(i=0;i<4;i++) //依次進行掃描
P3=KeyScanCode[i];
for(j=0;j<3;j++)
k=i*3+j; //計算對應的按鍵編碼
if(P3==KeyCodeTable[k])
return k; //返回按鍵編碼
return 0xff; //或者返回0xff
全部資料51hei下載地址:
新建文件夾.zip
(75.13 KB, 下載次數: 22)
2020-3-12 10:27 上傳
