標題: Proteus 8代編寫可控跑馬燈遇到問題,求大神解答! [打印本頁]
作者: jueno    時間: 2020-3-4 22:24
用Keil uVision5編寫的C語言代碼如下畫的原件圖在附件里
不懂哪里有問題
#include<regx51.h>
#define uint  unsigned int
uint code unm[]={0,1,3,5,7,9,15,60,100,200,300,400,500,600,700,800,900,1000,1100,1200,1300,1400,1500};
uchar unm1[]={0xff,0xef,0xc7,0xab,0xef,0xef,0xef,0xff};
uchar m,n,j,y;
uint  l,g;
void delay(uint i)
  uchar j;
  while(i--)
  for(j=0;j<120;j++);
void init()
  TMOD = 0x11;
  TH0 = 0x00;
  TL0 = 0x00;
  TH1 = 0xaa;
  TL1 = 0xbb;
  EA = 1;
  ET0 = 1;
  ET1 = 1;
  TR0 = 1;
  TR1 = 1;
bit ce_anjian ( )
  bit key=0;
  P1=0xf3;
  if(P1!=0xf3)
      key=1;
      key=0;
  return(key);
void ce_jianzhi ( )
   uchar i,j,p;
   do
      while(ce_anjian()==0);
      delay(50);
   }while(ce_anjian()==0);
   for(i=0;i<2;i++)
      P1=(0xfe<<i)|i;
     for(j=0;j<2;j++)
           p=P1&0x0c;
           if(p==0x08>>j)
              y=i*2+j+1;
                  goto D1;
D1:  delay(50);
   do
      while(ce_anjian()==1);
      delay(50);
   }while(ce_anjian()==1);
void mingjiao()
  uchar t;
  for(t=0;t<50;t++)
    P1_7=0;
    P1_7=1;
  init();
  n=5;
    l=unm[n];
        if(ce_anjian()==1)
          ce_jianzhi();
          switch(y)
            case 1: {m=1;j=0x7f;mingjiao();}break;
            case 2:        {m=2;j=0xfe;mingjiao();}break;
            case 3:        {n=n+1;if(n==24)n=23;mingjiao();}break;
            case 4:        {n=n-1;if(n==0)n=1;mingjiao();}break;
        default: break;
void t_1()interrupt 3
  uchar a,k;
  TH1 = 0xaa;
  TL1 = 0xbb;
  switch(m)
     case 1:
          a=0x01;
      for(k=0;k<8;k++)
            P2=a;
            P3=unm1[k];
        delay(2);
            a=a<<1;
            if(a==0)a=0x01;
            P0=j;
        }break;
         case 2:
          a=0x80;
      for(k=0;k<8;k++)
            P2=a;
            P3=unm1[k];
        delay(2);
            a=a>>1;
            if(a==0)a=0x80;
            P0=j;
void t_0()interrupt 1
  uchar b1,b2,b3,b4,b5,b6,b7,b8;
  if(++g<l) return;
  g=0;
  switch(m)
    case 1:{ j=(j>>1)|0x80;
                 if(j==0xff)j=0x7f;}break;
        case 2:{ j=(j<<1)|0x01;
                 if(j==0xff)j=0xfe;}break;
  b1=unm1[0];
  b2=unm1[1];
  b3=unm1[2];
  b4=unm1[3];
  b5=unm1[4];
  b6=unm1[5];
  b7=unm1[6];
  b8=unm1[7];
  unm1[0]=b2;
  unm1[1]=b3;
  unm1[2]=b4;
  unm1[3]=b5;
  unm1[4]=b6;
  unm1[5]=b7;
  unm1[6]=b8;
  unm1[7]=b1;
這是C語言代碼
師傅也不懂
師傅也不懂
這是畫的圖
這是畫的圖
作者: lovexulu    時間: 2020-3-5 15:19
bit ce_anjian ( )
  bit key=0;
  P1=0xf3;
  if(P1!=0xf3)
      key=1;
      key=0;
  return(key);
沒太仔細看,你這段有錯誤,每次調用函數返回結果key始終是0,且P1被賦值0xf3;
每次進入按鍵函數,key被定義為0,P1被賦值0xf3; if選擇函數表達式結果均為0,即key=0,函數返回0
作者: taotie    時間: 2020-3-5 20:40
p1_7替換為BUZZ
可以運行
作者: taotie    時間: 2020-3-5 21:48
/* Main.c file generated by New Project wizard
* Created:   周四 3月 5 2020
* Processor: AT89C52
* Compiler:  Keil for 8051
#include <reg51.h>
#include <stdio.h>
//#include<regx51.h>
sbit buzz=P1^7;    //定義單片機I/O口 P1.7的偽名稱叫buzz
uchar m,n,j,y;
uint  l,g;
void delay(uint i)
  uchar j;
  while(i--)
  for(j=0;j<120;j++);
void init()
  TMOD = 0x11;
  TH0 = 0x00;
  TL0 = 0x00;
  TH1 = 0xaa;
  TL1 = 0xbb;
  EA = 1;
  ET0 = 1;
  ET1 = 1;
  TR0 = 1;
  TR1 = 1;
bit ce_anjian ( )
  bit key=0;
  P1=0xf3;
  if(P1!=0xf3)
      key=1;
      key=0;
  return(key);
void ce_jianzhi ( )
   uchar i,j,p;
   do
      delay(50);
   for(i=0;i<2;i++)
      P1=(0xfe<<i)|i;
     for(j=0;j<2;j++)
           p=P1&0x0c;
           if(p==0x08>>j)
              y=i*2+j+1;
                  goto D1;
D1:  delay(50);
   do
      delay(50);
void mingjiao()
  uchar t;
  for(t=0;t<50;t++)
    buzz=0;        //P1_7被替換
    buzz=1;         //P1_7被替換
  init();
  n=5;
    l=unm[n];
        if(ce_anjian()==1)
          ce_jianzhi();
          switch(y)
        default: break;
  uchar a,k;
  TH1 = 0xaa;
  TL1 = 0xbb;
  switch(m)
     case 1:
          a=0x01;
      for(k=0;k<8;k++)
            P2=a;
            P3=unm1[k];
        delay(2);
            a=a<<1;
            if(a==0)a=0x01;
            P0=j;
        }break;
         case 2:
          a=0x80;
      for(k=0;k<8;k++)
            P2=a;
            P3=unm1[k];
        delay(2);
            a=a>>1;
            if(a==0)a=0x80;
            P0=j;
  if(++g<l) return;
  g=0;
  switch(m)
  b1=unm1[0];
  b2=unm1[1];
  b3=unm1[2];
  b4=unm1[3];
  b5=unm1[4];
  b6=unm1[5];
  b7=unm1[6];
  b8=unm1[7];
  unm1[0]=b2;
  unm1[1]=b3;
  unm1[2]=b4;
  unm1[3]=b5;
  unm1[4]=b6;
  unm1[5]=b7;
  unm1[6]=b8;
  unm1[7]=b1;
作者: 優雅的刺猬    時間: 2020-3-6 17:30
運行了之后什么樣,亮都不亮嗎
