stm32f103RCt6 驅動HMI X5系列7寸LCD 串口驅動
medeng
2020-1-15 09:24
//頭文件定義
#ifndef _HMIX5_7_H
#define _HMIX5_7_H
#include "stm32f10x.h"
#include <stdio.h>
// 串口1-USART1
#define HMI_USARTx USART1
#define HMI_USART_CLK RCC_APB2Periph_USART1
#define HMI_USART_APBxClkCmd RCC_APB2PeriphClockCmd
#define HMI_USART_BAUDRATE 115200
// USART GPIO 引腳宏定義
#define HMI_USART_GPIO_CLK (RCC_APB2Periph_GPIOA)
#define HMI_USART_GPIO_APBxClkCmd RCC_APB2PeriphClockCmd
#define HMI_USART_TX_GPIO_PORT GPIOA
#define HMI_USART_TX_GPIO_PIN GPIO_Pin_9
#define HMI_USART_RX_GPIO_PORT GPIOA
#define HMI_USART_RX_GPIO_PIN GPIO_Pin_10
#define HMI_USART_IRQ USART1_IRQn
#define HMI_USART_IRQHandler USART1_IRQHandler
void HMI_USART_Config(void);
void Usart_SendByte( USART_TypeDef * pUSARTx, uint8_t ch);
void Usart_SendString( USART_TypeDef * pUSARTx, char *str);
void Usart_SendHalfWord( USART_TypeDef * pUSARTx, uint16_t ch);
#endif
//下面是對應.c文件
#include "hmix5_7.h"
* @brief 配置嵌套向量中斷控制器NVIC
* @param 無
* @retval 無
static void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); /* 嵌套向量中斷控制器組選擇 */
NVIC_InitStructure.NVIC_IRQChannel = HMI_USART_IRQ; /* 配置USART為中斷源 */
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; /* 搶斷優先級*/
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; /* 子優先級 */
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; /* 使能中斷 */
NVIC_Init(&NVIC_InitStructure); /* 初始化配置NVIC */
* @brief USART GPIO 配置,工作參數配置
* @param 無
* @retval 無
USART_InitTypeDef USART_InitStructure;
HMI_USART_GPIO_APBxClkCmd(HMI_USART_GPIO_CLK, ENABLE); // 打開串口GPIO的時鐘
HMI_USART_APBxClkCmd(HMI_USART_CLK, ENABLE); // 打開串口外設的時鐘
// 將USART Tx的GPIO配置為推挽復用模式
GPIO_InitStructure.GPIO_Pin = HMI_USART_TX_GPIO_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(HMI_USART_TX_GPIO_PORT, &GPIO_InitStructure);
// 將USART Rx的GPIO配置為浮空輸入模式
GPIO_InitStructure.GPIO_Pin = HMI_USART_RX_GPIO_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(HMI_USART_RX_GPIO_PORT, &GPIO_InitStructure);
// 配置串口的工作參數
USART_InitStructure.USART_BaudRate = HMI_USART_BAUDRATE; // 配置波特率
USART_InitStructure.USART_WordLength = USART_WordLength_8b; // 配置 針數據字長
USART_InitStructure.USART_StopBits = USART_StopBits_1; // 配置停止位
USART_InitStructure.USART_Parity = USART_Parity_No ; // 配置校驗位
USART_InitStructure.USART_HardwareFlowControl = // 配置硬件流控制
USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; // 配置工作模式,收發一起
USART_Init(HMI_USARTx, &USART_InitStructure); // 完成串口的初始化配置
NVIC_Configuration(); // 串口中斷優先級配置
USART_ITConfig(HMI_USARTx, USART_IT_RXNE, ENABLE); // 使能串口接收中斷
USART_Cmd(HMI_USARTx, ENABLE); // 使能串口
/***************** 發送一個字節 **********************/
/* 發送一個字節數據到USART */
USART_SendData(pUSARTx,ch);
/* 等待發送數據寄存器為空 */
while (USART_GetFlagStatus(pUSARTx, USART_FLAG_TXE) == RESET);
/****************** 發送8位的數組 ************************/
void Usart_SendArray( USART_TypeDef * pUSARTx, uint8_t *array, uint16_t num)
uint8_t i;
for(i=0; i<num; i++)
Usart_SendByte(pUSARTx,array[i]);
/* 等待發送完成 */
while(USART_GetFlagStatus(pUSARTx,USART_FLAG_TC)==RESET);
/***************** 發送字符串 **********************/
unsigned int k=0;
do
Usart_SendByte( pUSARTx, *(str + k) );
k++;
} while(*(str + k)!='\0');
/* 等待發送完成 */
/***************** 發送一個16位數 **********************/
uint8_t temp_h, temp_l;
/* 取出高八位 */
temp_h = (ch&0XFF00)>>8;
/* 取出低八位 */
temp_l = ch&0XFF;
/* 發送高八位 */
USART_SendData(pUSARTx,temp_h);
/* 發送低八位 */
USART_SendData(pUSARTx,temp_l);
