單片機矩陣鍵盤8位數碼管顯示鍵值
chengquan0216
2020-1-10 21:10
單片機矩陣鍵盤8位數碼管顯示鍵值
#include<reg52.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit a=P2^2;
sbit b=P2^3;
sbit c=P2^4;
uint8 smg[]={0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07,
0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71};
uint8 sum[8];
uint8 m,button;
void delay(uint16 i) //10ms
uint8 j,k;
for(;i>0;i--)
for(j=38;j>0;j--)
for(k=130;k>0;k--);
void delay1(uint8 i) //1.3ms
uint8 j,k;
for(;i>0;i--)
for(j=10;j>0;j--)
for(k=130;k>0;k--);
void keyscan()
uint8 value,h,l;
P1=0x0f;
l=P1&0x0f;
if(l!=0x0f)
delay(1);
if(l!=0x0f)
l=P1&0x0f;
l=l|0xf0;
P1=l;
h=P1&0xf0;
l=l&0x0f;
value=h+l;
button=1; //有按鍵按下
delay(50); //如果不加這條語句的話,其按鍵按下一下會顯示多個相同數字
switch(value)
case 0xe7: m=0;break;
case 0xeb: m=1;break;
case 0xed: m=2;break;
case 0xee: m=3;break;
case 0xd7: m=4;break;
case 0xdb: m=5;break;
case 0xdd: m=6;break;
case 0xde: m=7;break;
case 0xb7: m=8;break;
case 0xbb: m=9;break;
case 0xbd: m=10;break;
case 0xbe: m=11;break;
case 0x77: m=12;break;
case 0x7b: m=13;break;
case 0x7d: m=14;break;
case 0x7e: m=15;break;
default : break;
void display() //按鍵使數字向左移動
uint8 i;
for(i=0;i<8;i++)
switch(i)
case 0: a=1,b=1,c=1;break;
case 1: a=0,b=1,c=1;break;
case 2: a=1,b=0,c=1;break;
case 3: a=0,b=0,c=1;break;
case 4: a=1,b=1,c=0;break;
case 5: a=0,b=1,c=0;break;
case 6: a=1,b=0,c=0;break;
case 7: a=0,b=0,c=0;break;
P0=sum[i];;
delay1(1);
P0=0x00;
void display() //按鍵使數字向右移動
uint8 i;
for(i=0;i<8;i++)
switch(i)
case 0: a=0,b=0,c=0;break;
case 1: a=1,b=0,c=0;break;
case 2: a=0,b=1,c=0;break;
case 3: a=1,b=1,c=0;break;
case 4: a=0,b=0,c=1;break;
case 5: a=1,b=0,c=1;break;
case 6: a=0,b=1,c=1;break;
case 7: a=1,b=1,c=1;break;
P0=sum[i];;
delay1(1);
P0=0x00;
button=0;
keyscan();
if(button==1)
sum[7]=sum[6];
sum[6]=sum[5];
sum[5]=sum[4];
sum[4]=sum[3];
sum[3]=sum[2];
sum[2]=sum[1];
sum[1]=sum[0];
sum[0]=smg[m];
button=0;
display();
adc1254088
2021-4-28 20:02
為什么沒有電路圖呢?
