STC15W408AS0-10V電壓測(cè)量 LCD1602顯示
czhaii
時(shí)間:
2020-1-3 20:48
/****LCD1602 *********電壓表測(cè)量0-1024PAST*******/
/*************2018 12 28 CODE1844 L283**********/
#include <REG52.H> //按鍵加減輸入數(shù)字
#include <intrins.H> //輸出0-10電壓
sfr P1ASF=0x9D; //P1口第2功能控制寄存器
#define ADC_SPEEDLL 0x00 //540個(gè)時(shí)鐘
#define Lcd_Bus P3
sbit RS=P5^4; //LCD PIN4
sbit RW=P1^7; //LCD PIN5
sbit E=P1^6; //LCD PIN6
sbit OUT1=P1^5;
float ADvalue; //存放AD轉(zhuǎn)換返回的結(jié)果
uint val;
uint aa=0; /****RUN FLAG****/
uchar code disdt[10]={0X30,0X31,0X32,0X33,0X34,0X35,0X36,0X37,0X38,0X39};
/*------------------延時(shí)子程序------------------------*/
void delay(uint ms)
uint i,j;
for(i=0;i<ms;i++)
for(j=0;j<2000;j++)
void delay_1ms(uint x)
int i, j;
for (i=0; i<x; i++)
for (j=0; j<1500; j++);
void chk_busy()
RS=0;
RW=1;
E=1;
Lcd_Bus=0xff;
while((Lcd_Bus&0x80)==0x80);
E=0;
/*------------------寫命令到LCD-----------------------*/
void write_com(uchar cmdcode)
chk_busy();
RS=0;
RW=0;
E=1;
Lcd_Bus=cmdcode;
delay(5); /*在數(shù)據(jù)寫入的時(shí)候加入適當(dāng)?shù)难訒r(shí)*/
E=0;
delay(5);
/*-------------------寫數(shù)據(jù)到LCD----------------------*/
void write_data(uchar Dispdata)
chk_busy();
RS=1;
RW=0;
E=1;
Lcd_Bus=Dispdata;
delay(5); /*在數(shù)據(jù)寫入的時(shí)候加入適當(dāng)?shù)难訒r(shí) */
E=0;
delay(5);
/*------------------初始化LCD屏-----------------------*/
void lcd_init()
write_com(0X38); /**/
delay_1ms(100);
write_com(0X0E);
delay_1ms(100);
write_com(0X06);
void dis_play1(uint val) /*顯示A函數(shù)*/
uint Data_a,Data_b,Data_c,Data_d;
Data_a=val/1000;
Data_b=(val-Data_a*1000)/100;
Data_c=(val-Data_a*1000-Data_b*100)/10;
Data_d=val-Data_a*1000-Data_b*100-Data_c*10;
write_com(0X80); /*地址*/
write_data(0X50); /*P*/
write_com(0X81); /*地址*/
write_data(0X31); /*1*/
write_com(0X82); /*地址*/
write_data(0X3A); /*1*/
write_com(0X83); /*地址*/
write_data(disdt[Data_b]); /*十位*/
write_com(0X84); /*地址*/
write_data(disdt[Data_c]); /*個(gè)位*/
write_com(0X85); /*地址*/
write_data(0X2E); /*.*/
write_com(0X86); /*地址*/
write_data(disdt[Data_d]); /*個(gè)位*/
write_com(0X87); /*地址*/
write_data(0X56); /*V*/
void dis_play2(uint val) /*顯示A函數(shù)*/
Data_a=val/1000;
write_com(0X88); /*地址*/
write_data(0X53); /*S*/
write_com(0X89); /*地址*/
write_com(0X8A); /*地址*/
write_com(0X8B); /*地址*/
write_com(0X8C); /*地址*/
write_com(0X8D); /*地址*/
write_com(0X8E); /*地址*/
write_com(0X8F); /*地址*/
void dis_play3(uint val) /*顯示A函數(shù)*/
Data_a=val/1000;
write_com(0XC0); /*地址*/
write_com(0XC1); /*地址*/
write_data(0X32); /*2*/
write_com(0XC2); /*地址*/
write_com(0XC3); /*地址*/
write_com(0XC4); /*地址*/
write_com(0XC5); /*地址*/
write_com(0XC6); /*地址*/
write_com(0XC7); /*地址*/
void dis_play4(uint val) /*顯示A函數(shù)*/
Data_a=val/1000;
write_com(0XC8); /*地址*/
write_com(0XC9); /*地址*/
write_com(0XCA); /*地址*/
write_com(0XCB); /*地址*/
write_com(0XCC); /*地址*/
write_com(0XCD); /*地址*/
write_com(0XCE); /*地址*/
write_com(0XCF); /*地址*/
unsigned int ADC_P10() //
uint i;
uchar status=0; //AD轉(zhuǎn)換結(jié)束標(biāo)志
uint AD_Dat=0; //10位AD轉(zhuǎn)換值
ADC_CONTR|=0X80; //打開ADC轉(zhuǎn)換電源,第一次使用時(shí)要打開內(nèi)部電源
for(i=0;i<10000;i++) //等待電源穩(wěn)定1ms
P1ASF|=0X00; //0000 0000
ADC_CONTR=0XE0; //1110 0000 通道P1.0
for(i=0;i<1000;i++) //如果多通道測(cè)量,更換通道后延時(shí)200us
ADC_CONTR|=0X08; //啟動(dòng)AD轉(zhuǎn)換 0000 1000ADC_START
while(status==0) //等待AD轉(zhuǎn)換結(jié)束
status=ADC_CONTR&0X10; //判斷ADC_FLAG是否等于1,
ADC_CONTR&=0XE7; //將ADC_FLAG清零
AD_Dat=(ADC_RES<<2)|(ADC_RESL&0X03); //
return AD_Dat; //
unsigned int ADC_P11() //
uint i;
P1ASF|=0X02; //0000 0010
ADC_CONTR=0XE1; //1110 0001
return AD_Dat; //
unsigned int ADC_P13() //
uint i;
P1ASF|=0X08; //0000 1000
ADC_CONTR=0XE3; //1110 0011 P1.3
return AD_Dat; //
unsigned int ADC_P14() //
uint i;
P1ASF|=0X10; //0001 0000
ADC_CONTR=0XE4; //1110 0100
return AD_Dat; //
/*------------------主循環(huán)程序----------------*/
void main( ) /*主程序開始*/
P1M0=0X00;
P1M1=0X1B;
P5M0=0X00;
P5M1=0X00;
OUT1=0;
delay(500);
OUT1=1;
lcd_init() ; /*液晶復(fù)位*/
OUT1=~OUT1;
ADvalue=ADC_P11()/9; //采樣P1.1口模擬輸入電壓 9根據(jù)輸入電壓,芯片電壓測(cè)試得出
dis_play1(ADvalue);
delay(10); //1023/12 V輸入
ADvalue=ADC_P10()/9; //采樣P1.1口模擬輸入電壓 9根據(jù)輸入電壓,芯片電壓測(cè)試得出
dis_play2(ADvalue);
delay(10);
ADvalue=ADC_P13()/9; //采樣P1.1口模擬輸入電壓 9根據(jù)輸入電壓,芯片電壓測(cè)試得出
dis_play3(ADvalue);
delay(10);
ADvalue=ADC_P14()/9; //采樣P1.1口模擬輸入電壓 9根據(jù)輸入電壓,芯片電壓測(cè)試得出
dis_play4(ADvalue);
delay(10);
} //主循環(huán)
版權(quán)聲明:本文為CSDN博主「czhaii」的原創(chuàng)文章,遵循 CC 4.0 BY-SA 版權(quán)協(xié)議,轉(zhuǎn)載請(qǐng)附上原文出處鏈接及本聲明。
原文鏈接:
https://blog.csdn.net/czhaii/article/details/89790529
oohoh
時(shí)間:
2020-1-4 14:03
請(qǐng)問基準(zhǔn)電壓怎么設(shè)置
czhaii
時(shí)間:
2020-1-7 10:20
看STC官方手冊(cè)
