如下程序我想實(shí)現(xiàn)串口發(fā)不同的字符后,單片機(jī)P0口高電平驅(qū)動(dòng)三極管工作。但是發(fā)現(xiàn)沒(méi)有辦法動(dòng)作!求助!!!
#include <reg51.h>
#include <string.h>
#define INBUF_LEN 4 //數(shù)據(jù)長(zhǎng)度
unsigned char inbuf1[INBUF_LEN];
unsigned char checksum,count3;
bit read_flag= 0;
sbit keypad1=P0^0;
sbit keypad2=P0^1;
sbit keypad3=P0^2;
sbit keypad4=P0^3;
sbit keypad5=P0^4;
sbit keypad6=P0^5;
void delay_ms(unsigned int ms)
unsigned int i;
unsigned char j;
for(i=0;i<ms;i++)
for(j=0;j<200;j++);
for(j=0;j<102;j++);
void init_serialcomm( void )
SCON = 0x50 ; //SCON: serail mode 1, 8-bit UART, enable ucvr
TMOD |= 0x20 ; //TMOD: timer 1, mode 2, 8-bit reload
PCON |= 0x80 ; //SMOD=1;
TH1 = 0xF4 ; //Baud:4800 fosc=11.0592MHz
IE |= 0x90 ; //Enable Serial Interrupt
TR1 = 1 ; // timer 1 run
//TI=1;
//向串口發(fā)送一個(gè)字符
void send_char_com(unsigned char ch)
SBUF=ch;
while (TI== 0 );
TI= 0 ;
//向串口發(fā)送一個(gè)字符串,strlen為該字符串長(zhǎng)度
void send_string_com( unsigned char *str, unsigned int strlen)
unsigned int k= 0 ;
do
send_char_com(*(str + k));
k++;
while (k < strlen);
//串口接收中斷函數(shù)
void serial () interrupt 4 using 3
if (RI)
unsigned char ch;
RI = 0 ;
ch=SBUF;
if (ch> 127 )
count3= 0 ;
inbuf1[count3]=ch;
checksum= ch- 128 ;
count3++;
inbuf1[count3]=ch;
checksum ^= ch;
if ( (count3==(INBUF_LEN- 1 )) && (!checksum) )
read_flag= 1 ; //如果串口接收的數(shù)據(jù)達(dá)到INBUF_LEN個(gè),且校驗(yàn)沒(méi)錯(cuò),就置位取數(shù)標(biāo)志
void main(void)
unsigned char relay;
relay='A';
P0=0x00;
init_serialcomm(); //初始化串口
while ( 1 )
if (read_flag) //如果取數(shù)標(biāo)志已置位,就將讀到的數(shù)從串口發(fā)出
read_flag= 0 ; //取數(shù)標(biāo)志清0
//send_string_com(inbuf1,INBUF_LEN);
send_char_com(relay);
switch(relay)
case 'B':
delay_ms(500);
keypad1=1;//氣缸1 Close
delay_ms(2500);
keypad2=1;//氣缸2 Close
break;
case 'C':
delay_ms(500);
keypad3=1;//氣缸3 Close
delay_ms(1000);
keypad3=0;//氣缸3 Open
break;
case 'D':
delay_ms(500);
keypad1=0;//氣缸1 Open
keypad2=0;//氣缸1 Open
break;
case 'E':
delay_ms(500);
keypad4=1;//氣缸4 Close
delay_ms(2500);
keypad5=1;//氣缸5 Close
break;
case 'F':
delay_ms(500);
keypad6=1;//氣缸6 Close
delay_ms(1000);
keypad6=0;//氣缸6 Open
break;
case 'G':
delay_ms(500);
keypad4=0;//氣缸4 Open
keypad5=0;//氣缸5 Open
break;
default:
P0=0x00;
break;
p0口高電平驅(qū)動(dòng)繼電器?你用的是什么型號(hào)的單片機(jī)?
普通的P0口需要加上拉電阻才有可能輸出高電平。
P0 口是高電平驅(qū)動(dòng)繼電器,用的是AT89S51單片機(jī)!驅(qū)動(dòng)是沒(méi)有問(wèn)題!
問(wèn)題是串口控制的部分,無(wú)法實(shí)現(xiàn)!
