單片機雙機通信程序和仿真
2228048982
2019-12-25 20:06
單片機雙機通信程序和仿真
程序和仿真
#include<reg51.h>
sbit LED1=P1^0;
sbit LED2=P1^3;
sbit K1=P1^7;
uchar Operation_No=0; //操作代碼
//數碼管代碼
uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
//延時
void DelayMS(uint ms)
uchar i;
while(ms--) for(i=0;i<120;i++);
//向串口發送字符
void Putc_to_SerialPort(uchar c)
SBUF=c;
while(TI==0);
TI=0;
//主程序
LED1=LED2=1;
P0=0x00;
SCON=0x50; //
TMOD=0x20; //T1 工作模式 2
PCON=0x00; //
TH1=0xfd;
TL1=0xfd;
TI=RI=0;
TR1=1;
IE=0x90; //允許串口中斷
DelayMS(100);
if(K1==0) //按下 K1 時選擇操作代碼 0,1,2,3
while(K1==0);
Operation_No=(Operation_No+1)%4;
switch(Operation_No) //A/B/C
case 0: Putc_to_SerialPort('X');
LED1=LED2=1;
break;
case 1: Putc_to_SerialPort('A');
LED1=~LED1;LED2=1;
break;
case 2: Putc_to_SerialPort('B');
LED2=~LED2;LED1=1;
break;
case 3: Putc_to_SerialPort('C');
LED1=~LED1;LED2=LED1;
break; }
//甲機串口接收中斷函數
void Serial_INT() interrupt 4
if(RI)
RI=0;
if(SBUF>=0&&SBUF<=9) P0=DSY_CODE[SBUF];
else P0=0x00;
雙機通信.zip
(88.27 KB, 下載次數: 30)
2019-12-25 20:05 上傳
單片機雙機通信
