#define LEN 8 //緩沖區(qū)長度,建議大于5
unsigned int keyVal = 8;//按鍵的值,彈起不會變0(1-8)
unsigned int rockerVal = 521;//搖桿的值,停下變0xff 0xff(0-360)
unsigned int seekBarVal = 50;//滑塊的值(0-100)
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
void Uart_Receive(unsigned char cha)
static unsigned char str[8];
static unsigned char sta = 0;
if((sta & 0x80) == 0)
if(sta & 0x40)
if(cha != 0x0D)
sta = 0;
sta |= 0x80;
sta <<= 2;
sta >>= 2;
Rocker_Data_Analyze(str,sta);
sta = 0;
if(cha == 0x0A)
sta |= 0x40;
str[sta & 0x3F] = cha;
sta++;
if(sta > (LEN - 1))
sta = 0;
//函數(shù):step 功能:控制步進電機方向,步數(shù)。
//參數(shù):dir 方向控制, dirPin對應(yīng)步進電機的DIR引腳,stepperPin 對應(yīng)步進電機的step引腳, steps 步進的步數(shù)
//無返回值
void step(boolean dir, byte dirPin, byte stepperPin, unsigned long int steps,unsigned int TIME)
digitalWrite(dirPin,dir);//dir為true 則dirPin引腳輸出高電平,dir為false則dirPin引腳輸出低電平
//delay(50);
for (unsigned long int i = 0; i < steps; i++) //脈沖信號需<1kHz
judge();
digitalWrite(stepperPin, HIGH);//stepperPin引腳輸出高電平
delayMicroseconds(TIME);//延時300us
