標題: LCD1602顯示+仿真 [打印本頁]
作者: dxm1215225    時間: 2019-12-11 10:40
標題: LCD1602顯示+仿真
#include<reg52.h>
#define LCD_DB  P0
sbit LCD_RS = P2^6;
sbit LCD_RW = P2^5;
sbit LCD_EN = P2^7;
unsigned char Zh1[]="  Dian Zi 1801  ";
unsigned char Zh2[]="  Xue Hao:  18  ";
void Busy()                 //檢忙
    unsigned char sta;
    LCD_DB = 0xff;
    LCD_RS = 0;
    LCD_RW = 1;
    do
    LCD_EN = 1;
    sta = LCD_DB;
    LCD_EN = 0;
    while(sta&0x80);
void Lcd_Write_Cmd(unsigned char cmd)      //命令
    Busy();
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_DB = cmd;
    LCD_EN = 1;
    LCD_EN = 0;
void Lcd_Write_Data(unsigned char dat)     //數據
    Busy();
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_DB = dat;
    LCD_EN = 1;
    LCD_EN = 0;
void InitLcd()                            //初始化
    Lcd_Write_Cmd(0x38);
    Lcd_Write_Cmd(0x08);
    Lcd_Write_Cmd(0x01);
    Lcd_Write_Cmd(0x06);
    Lcd_Write_Cmd(0x0c);
void LcdSetCursor(unsigned char x,unsigned char y)   //坐標
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd_Write_Cmd(addr|0X80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *s)  //字符串
    LcdSetCursor(x,y);
    while(*s)
        Lcd_Write_Data(*s);
        s++;
void main(void)
P1=0xf0;
InitLcd();
LcdShowStr(0,0,Zh1);
    LcdShowStr(0,1,Zh2);
while(1);
LCD1602仿真圖
LCD1602仿真圖
LCD顯示屏.zip
79.93 KB, 下載次數: 28, 下載積分: 黑幣 -5
所有文件
