標(biāo)題: 單片機(jī)八路搶答器代碼+Proteus仿真 [打印本頁]
作者: luozhao    時(shí)間: 2019-11-23 08:49
基于數(shù)碼管的八路搶答器
    本程序是基于51單片機(jī)的8位搶答器,仿真軟件用proteus8.0以上的版本打開,若軟件版本過低,可參考PNG格式圖片繪制仿真圖。
    開機(jī)時(shí)數(shù)碼管顯示EA一段時(shí)間,然后顯示00。第一步,按K_3或者K_2設(shè)定思考時(shí)間(總時(shí)間),K_3按一次加5秒,K_2按一次減5秒。第二步,設(shè)定好時(shí)間后按K_1確認(rèn)開始。在3秒之后進(jìn)入總時(shí)間計(jì)時(shí),時(shí)間到后無人搶答自動(dòng)結(jié)束。按k1~k8搶答,數(shù)碼管顯示搶答號(hào)數(shù)。最后,按K_4清零……
單片機(jī)源程序如下:
  1. #include <reg51.H>
  2. sbit k1=P1^0;
  3. sbit k2=P1^1;
  4. sbit k3=P1^2;
  5. sbit k4=P1^3;
  6. sbit k5=P1^4;
  7. sbit k6=P1^5;
  8. sbit k7=P1^6;
  9. sbit k8=P1^7;
  10. sbit k_1=P3^0;
  11. sbit k_2=P3^1;
  12. sbit k_3=P3^2;
  13. sbit k_4=P3^3;
  14. sbit beep=P3^7;
  15. unsigned int ms;          //毫秒
  16. unsigned int s,t0;              //顯示值
  17. unsigned char biaozhi,buzhou=0;        //搶答標(biāo)志,步驟
  18. unsigned char led[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};
  19. void delay(unsigned int t)//延時(shí)
  20. {
  21.     unsigned int i,j;
  22.     for(i=0;i<t;i++)
  23.     for(j=0;j<110;j++);
  24. }
  25. void disp()//顯示
  26. {
  27.    unsigned int ge,shi;
  28.    ge=s%10;          //提取個(gè)位
  29.    shi=s/10;  //提取十位
  30.    P2=0xfe;
  31.    P0=led[ge];  //顯示個(gè)位
  32.    delay(5);
  33.    P2=0xfd;
  34.    P0=led[shi];        //顯示十位
  35.    delay(5);
  36. }
  37. void ea()//顯示開機(jī)界面
  38. {
  39.         unsigned char ci;
  40.         while(ci<200)//循環(huán)200次(持續(xù)一段時(shí)間)
  41.         {
  42.                 P2=0xfe;
  43.                 P0=0x77;  //顯示A
  44.                 delay(5);
  45.                 P2=0xfd;
  46.                 P0=0x79;        //顯示E
  47.                 delay(5);
  48.                 ci++;
  49.         }
  50. }
  51. void keys()        //搶答按鍵
  52. { /*搶答之后顯示數(shù)值,改變標(biāo)志終止搶答*/
  53.     if(k1==0&&biaozhi==0){s=1;biaozhi=1;beep=0;delay(500);beep=1;}
  54.     if(k2==0&&biaozhi==0){s=2;biaozhi=1;beep=0;delay(500);beep=1;}
  55.     if(k3==0&&biaozhi==0){s=3;biaozhi=1;beep=0;delay(500);beep=1;}
  56.     if(k4==0&&biaozhi==0){s=4;biaozhi=1;beep=0;delay(500);beep=1;}
  57.     if(k5==0&&biaozhi==0){s=5;biaozhi=1;beep=0;delay(500);beep=1;}
  58.     if(k6==0&&biaozhi==0){s=6;biaozhi=1;beep=0;delay(500);beep=1;}
  59.     if(k7==0&&biaozhi==0){s=7;biaozhi=1;beep=0;delay(500);beep=1;}
  60.     if(k8==0&&biaozhi==0){s=8;biaozhi=1;beep=0;delay(500);beep=1;}
  61. }
  62. void set_time()        //設(shè)置時(shí)間,一次5秒
  63. {
  64.    if(k_2==0&&biaozhi==0&&s>0)
  65.    {
  66.       while(k_2==0);
  67.           s-=5;
  68.    }
  69.    if(k_3==0&&biaozhi==0&&s<95)
  70.    {
  71.       while(k_3==0);
  72.              s+=5;
  73.    }
  74. }
  75. void main()
  76. {
  77. /*配置定時(shí)器*/
  78.   TMOD=0x01;
  79.   TH0=(65536-50000)/256;
  80.   TL0=(65536-50000)%256;
  81.   EA=1;
  82.   ET0=1;
  83.   ea();//開機(jī)顯示EA
  84.   while(1)
  85.   {
  86.      if(buzhou==0)         set_time();
  87.          if(k_1==0&&biaozhi==0&&P1==0xff&&s!=0)//開始搶答
  88.          {
  89.              while(k_1==0);
  90.                  for(t0=3;t0>0;t0--)
  91.          {
  92.                          P2=0xfe;
  93.                          P0=led[t0]; //3秒倒計(jì)時(shí)
  94.                          beep=0;delay(80);beep=1;
  95.                  delay(1000);
  96.          }
  97.                  P2=0xfc;
  98.                  P0=0x40;
  99.                  beep=0;delay(1000);beep=1;
  100.                  buzhou=1;
  101.              TR0=1;        //打開定時(shí)器開關(guān)
  102.          }
  103.          if(P1!=0xff&&buzhou==1&&t0==0) //搶答
  104.          {
  105.              TR0=0;//關(guān)閉定時(shí)器開關(guān)
  106.              keys();
  107.                  buzhou=3;
  108.          }
  109.          if(k_4==0)        //清除
  110.      {
  111.             beep=k_4;
  112.                 while(k_4==0);
  113.                 TR0=0;
  114.                 s=0;
  115.                 biaozhi=0;
  116.                 buzhou=0;
  117.                 beep=1;
  118.      }
  119.          disp(); //顯示
  120.   }
  121. }
  122. void zhongduan() interrupt 1
  123. { /*啟動(dòng)定時(shí)器*/
  124.   TH0=(65536-50000)/256;
  125.   TL0=(65536-50000)%256;//50000=50毫秒
  126.   ms++;
  127.   if(ms==20&&s>0)//50毫秒x20次=1秒
  128.   {
  129.         ms=0;
  130.     s--;  //倒計(jì)時(shí)
  131.         if(s==0)
  132.         {
  133.             TR0=0;
  134.                    biaozhi=0;
  135.                 buzhou=0;
  136.                 beep=0;
  137.         }
  138.   }
  139. }
仿真.zip (403.4 KB, 下載次數(shù): 22)
