TX-1C 51單片機(jī)開發(fā)板外接12864無字庫液晶
AW416
2019-11-21 16:19
求助,自己買了一塊12864無字庫液晶插在開發(fā)板上調(diào)節(jié)12864可調(diào)電阻對比度絲毫沒有變化,網(wǎng)上搜集的資料都說要外接一個可調(diào)電阻,但不知道怎么接。程序如下,請論壇里的大佬看看有沒有錯誤,萬分感謝!!!
單片機(jī)源程序如下:
#include<reg52.h>
#define lcdrow 0xC0
#define lcdpage 0xb8
#define lcdcolumn 0x40
#define c_page_max 0x08
#define c_column_max 0x40
#define bus P0
sbit RST = P2^5;
sbit EN = P3^4;
sbit RW = P3^6;
sbit RS = P3^5;
sbit CS1 = P3^7;
sbit dula = P2^6;
sbit wela = P2^7;
void delayms(uint z)
uint x,y;
for(x = z;x > 0;x --)
for(y = 110;y > 0;y --);
void delayus(uint z)
uint x,y;
for(y = 110; y > 0;y --);
void ScreenChoose(uchar CS)
if(CS == 0)CS1 = 1;
else CS1 = 0;
void write_cmd(uchar cmd)
RS = 0;
RW = 0;
P0 = cmd;
delayus(10);
EN = 1;
EN = 0;
void write_data(uchar data)
RS = 1;
RW = 0;
P0 = dat;
delayus(10);
EN = 1;#include<reg52.h>
#include<intrins.h>
#include<stdlib.h>
#define LCD_data=P0
uint x,y;
sbit RW = P3^6;
sbit RS = P3^5;
sbit EN = P3^4;
sbit dula = P2^6;
sbit wela = P2^7;
sbit CS1 = P3^7;
RW = 0;
RS = 0;
EN = 0;
P0 = cmd;
delayms(5);
EN = 1;
delayms(5);
EN = 0;
void write_dat(uchar date)
RS = 1;
RW = 0;
EN = 0;
P0 = date;
delayms(5);
EN = 1;
delayms(5);
EN = 0;
uchar code picture[] ={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x02,
0x10,0x04,0x00,0x40,0xF1,0x02,0x10,0x01,
0xFE,0x0A,0x07,0xFE,0x11,0x07,0xBE,0x01,
0x83,0xED,0x80,0xF8,0x87,0xBE,0x23,0xC4,
0x82,0x11,0x04,0x02,0x52,0x89,0x48,0x01,
0x82,0xA5,0x00,0x81,0x88,0xAA,0x21,0x29,
0x7C,0x20,0x89,0x24,0x54,0x42,0x00,0x01,
0x80,0x85,0x00,0x80,0x88,0x08,0x31,0x2E,
0x00,0xDF,0x60,0xA0,0x5B,0xA2,0x7C,0x01,
0x80,0x82,0x3E,0xF0,0x86,0x08,0x51,0xC2,
0xFE,0x00,0x02,0x20,0xF0,0x0F,0xC4,0x01,
0x80,0x82,0x00,0x08,0x81,0x08,0x51,0x45,
0x10,0x00,0x01,0x20,0x15,0x42,0x7C,0x01,
0x80,0x85,0x00,0x08,0x80,0x88,0x79,0x2E,
0x58,0x3F,0x8F,0xFE,0x35,0x47,0x44,0x01,
0x80,0x85,0x00,0x88,0x88,0x88,0x49,0x21,
0x54,0x20,0x80,0x50,0xD5,0x4A,0x7C,0x01,
0x81,0xCD,0x80,0x71,0xCF,0x1C,0xCF,0xBE,
0x92,0x20,0x80,0x88,0x10,0x82,0x44,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x30,0x3F,0x87,0x04,0x6F,0xE2,0x7C,0x01,
0x80,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xFB,0x7C,0x00,0x70,0x38,
0x77,0xFA,0xBF,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xFA,0xFF,0xD7,0xF7,0xBF,
0x40,0x86,0xDF,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xF6,0x06,0x00,0xF0,0x3B,
0x5E,0xF6,0xFF,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xE5,0xF6,0xD6,0xF7,0xBB,
0x40,0x80,0x0F,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xD3,0xBE,0x00,0xF0,0x3B,
0x5F,0xF6,0xFF,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xF6,0xAF,0xDF,0xFF,0xF8,
0x40,0xF4,0xDF,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xF6,0xAC,0x00,0x00,0x0F,
0x4A,0xE2,0xBF,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xF5,0xB7,0xBB,0xED,0xFE,
0x40,0x97,0x7F,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xF3,0xB7,0x17,0xE4,0x19,
0x2A,0xF6,0x6F,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xF7,0xBF,0xE3,0xD9,0xFF,
0x6A,0xF1,0xAD,0xEF,0xBE,0xF7,0xE0,0x01,
0x80,0x03,0xFF,0xF6,0x3C,0x1C,0xBC,0x0C,
0x7C,0xC7,0xCF,0xFF,0xFF,0xFF,0xE0,0x01,
0x80,0x03,0xAB,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0x87,0xFF,0xF7,0xFF,0xE0,0x01,
0x80,0x03,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0x80,0xFF,0x73,0xFF,0xE0,0x01,
0x80,0x03,0x00,0xBF,0xFF,0xFF,0xCF,0xFF,
0xFF,0xFF,0xFE,0xF6,0x33,0xFF,0xE0,0x01,
0x80,0x03,0xC7,0xFF,0xFF,0xFF,0x1F,0xBF,
0xFF,0xF3,0xFE,0xE4,0x13,0xFF,0xE0,0x01,
0x80,0x03,0xA3,0xFF,0xFF,0xFC,0x1C,0x7D,
0xFF,0xFC,0xFF,0xC0,0x83,0xFF,0xE0,0x01,
0x80,0x03,0x6D,0xFF,0xFF,0xF0,0x30,0x71,
0xFD,0xFF,0x3F,0xB9,0xC7,0xFF,0xE0,0x01,
0x80,0x03,0xEF,0xDF,0x8F,0xE0,0x00,0x43,
0x7E,0x3F,0xCF,0xF9,0xF7,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xEF,0x07,0xC0,0x00,0x02,
0x5F,0x07,0xE3,0xFB,0xFF,0xBF,0xE0,0x01,
0x80,0x03,0xEF,0xAE,0x63,0x80,0x00,0xE4,
0x43,0xC0,0xF0,0xFF,0xFE,0xFF,0xE0,0x01,
0x80,0x03,0xFF,0xC6,0x93,0x80,0x00,0x10,
0x40,0x70,0x18,0x7E,0x3E,0x5F,0xE0,0x01,
0x80,0x03,0xFF,0x46,0x2B,0x00,0x00,0x00,
0xC0,0x00,0x04,0x3C,0x1E,0x3F,0xE0,0x01,
0x80,0x03,0xFF,0x82,0x28,0x00,0x00,0x00,
0xC0,0xE0,0x00,0x18,0xCC,0x6F,0xE0,0x01,
0x80,0x03,0xFE,0x81,0x10,0x00,0x00,0x01,
0x41,0x00,0x00,0x19,0x2C,0x5F,0xE0,0x01,
0x80,0x03,0xFF,0x01,0x80,0x00,0x3F,0x01,
0x20,0x00,0x00,0x0A,0x88,0x17,0xE0,0x01,
0x80,0x03,0xFD,0x01,0xC0,0x00,0xFF,0x82,
0x20,0x00,0x00,0x02,0x88,0x0F,0xE0,0x01,
0x80,0x03,0xFE,0x03,0xE0,0x00,0x03,0xC4,
0x10,0x1F,0x80,0x01,0x10,0x07,0xE0,0x01,
0x80,0x03,0xFA,0x07,0xA0,0x00,0x07,0x08,
0x11,0x3F,0xE0,0x00,0x3C,0x0F,0xE0,0x01,
0x80,0x03,0xFC,0x00,0x20,0x00,0x06,0x10,
0x08,0xF8,0x00,0x00,0x7E,0x0B,0xE0,0x01,
0x80,0x03,0xF4,0x00,0x40,0x00,0x02,0x20,
0x04,0x18,0x00,0x00,0x41,0x07,0xE0,0x01,
0x80,0x03,0xF8,0x07,0x80,0x04,0x4C,0x20,
0x02,0x1C,0x00,0x00,0x40,0x06,0xE0,0x01,
0x80,0x03,0xFC,0x18,0x80,0x02,0x20,0x40,
0x01,0x0C,0x00,0x00,0x40,0x04,0x60,0x01,
0x80,0x03,0xF4,0x28,0x40,0x05,0x10,0x40,
0x00,0x88,0x00,0x00,0x60,0x06,0xE0,0x01,
0x80,0x03,0xE0,0x44,0x40,0x02,0x00,0x40,
0x00,0x86,0x44,0x00,0x50,0x07,0xE0,0x01,
0x80,0x03,0xF0,0x42,0x21,0xC0,0x00,0x40,
0x00,0x40,0x88,0x0F,0x80,0x02,0xE0,0x01,
0x80,0x03,0xF8,0x82,0x11,0x30,0x00,0x80,
0x00,0x41,0x14,0x14,0xC4,0x03,0xE0,0x01,
0x80,0x03,0xD0,0x81,0x0E,0x2E,0x03,0x00,
0x00,0x40,0x08,0x22,0x22,0x02,0xE0,0x01,
0x80,0x03,0xF0,0x81,0x00,0x23,0xFC,0x00,
0x00,0x40,0x00,0x61,0x01,0x01,0xE0,0x01,
0x80,0x03,0xD8,0x81,0x00,0x22,0x00,0x00,
0x00,0x20,0x01,0xA1,0x00,0x03,0x60,0x01,
0x80,0x03,0xF0,0x81,0x00,0x22,0x00,0x00,
0x00,0x18,0x0E,0x40,0x80,0x81,0xA0,0x01,
uchar code Photo[] ={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x7F,0x00,0x00,0x00,0x03,0xFE,0x00,0x00,0x00,0x00,0x02,0x00,0x76,0x00,0x00,
0x00,0xC3,0xFF,0x00,0x00,0x3F,0xE7,0xE0,0x00,0x00,0x00,0x03,0x00,0xFF,0x80,0x00,
0x00,0x81,0xFF,0xFE,0x00,0x7C,0x03,0xF0,0x00,0x00,0x00,0x01,0xF7,0xCB,0xF8,0x00,
0x01,0x83,0xF8,0x7B,0x00,0x40,0x00,0x30,0x00,0x00,0x00,0x00,0x3F,0xC0,0xF8,0x00,
0x03,0x1E,0x3C,0x01,0x80,0x60,0x00,0x30,0x00,0x00,0x00,0x00,0x01,0x40,0x18,0x00,
0x03,0x30,0x0C,0x01,0xE0,0x6C,0x00,0x70,0x00,0x00,0x00,0x00,0x01,0x7C,0xCC,0x00,
0x03,0x24,0x6F,0x31,0x20,0x7C,0x40,0x60,0x00,0x00,0x00,0x00,0x01,0x97,0xFC,0x00,
0x01,0xBF,0xFB,0xF3,0xE0,0x3F,0xE7,0xC0,0x00,0x00,0x00,0x00,0x01,0xFB,0x1C,0x00,
0x00,0x9B,0xC2,0x1F,0x00,0x00,0x7F,0x80,0x00,0x00,0x00,0x00,0x00,0x0C,0xFE,0x00,
0x00,0xCC,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xB8,0x00,
0x00,0x7E,0x7E,0x00,0x00,0x00,0x00,0x00,0x1F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,0xE0,0x03,0xFF,0xE0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1F,0x00,0x00,0x78,0x01,0xC0,0x00,0x00,0x70,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x20,0x80,0x00,0xF8,0x01,0x80,0x00,0x00,0x30,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x2E,0x80,0x00,0xD8,0x03,0x60,0x00,0x01,0xF8,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x2A,0x80,0x00,0x98,0x02,0x60,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x2E,0x80,0x01,0x98,0x03,0xE0,0xC0,0x00,0x60,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x20,0x83,0xFF,0x8C,0x07,0xE1,0xC8,0x00,0x30,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1F,0x7F,0x07,0x8C,0x0F,0xFF,0x8C,0x00,0x18,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xB8,0x0F,0xCC,0x1F,0x83,0x8F,0x00,0x18,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x39,0xC0,0x38,0xFE,0x1E,0x00,0x8F,0xC0,0x0C,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x3B,0x80,0x70,0x1E,0x00,0x00,0xCC,0xF0,0x0C,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x76,0x00,0xC0,0x00,0x00,0x00,0x6E,0x3C,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x7E,0x01,0x80,0x00,0x00,0x00,0x3F,0x0E,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xDC,0x03,0x00,0x00,0x00,0x00,0x1F,0x03,0x82,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xD8,0x06,0x00,0x00,0x00,0x00,0x00,0x01,0xC2,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0xC2,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x80,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x62,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x66,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x26,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x80,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x6C,0x00,0x00,0x00,0x00,
0xFF,0xFF,0xFF,0x80,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEF,0xFF,0xFF,0xFE,0x00,
0x00,0x00,0x01,0x80,0x30,0x00,0x00,0x00,0x00,0x00,0x3F,0xD8,0x00,0x00,0x00,0x00,
0x3E,0x00,0x01,0x80,0x60,0x00,0x00,0x00,0x07,0xE0,0x3D,0xF0,0x01,0xF0,0x0C,0x00,
0xFF,0x80,0x01,0x80,0x6C,0x00,0x00,0x00,0x3E,0xF0,0x2C,0x60,0x07,0xFF,0xFC,0x00,
0x81,0xF8,0x71,0x01,0xDC,0x03,0xFC,0x00,0xF3,0xFF,0x87,0xE0,0x06,0x07,0xE0,0x00,
0x00,0x3F,0xE1,0x03,0xFC,0x0F,0x1F,0x87,0xC2,0x00,0x04,0xE0,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0x00,0x0C,0x1C,0x03,0xFF,0x00,0x00,0x01,0xE0,0x7F,0x03,0xF0,0x00,
0x00,0x00,0x03,0x00,0x18,0x10,0x00,0x00,0x00,0x00,0x01,0xC1,0xF3,0xF7,0x3C,0x00,
0xFF,0xC0,0x0F,0x02,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x80,0x7E,0x0E,0x00,
0xE1,0xFF,0xFF,0x03,0xF0,0x00,0x00,0x00,0x00,0x03,0xF8,0x7C,0x00,0x00,0x02,0x00,
0x00,0x01,0xE3,0x03,0xC0,0x00,0x03,0xFF,0x00,0x0F,0x1F,0xE0,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0x01,0x00,0x00,0x0F,0x03,0xF0,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,
0x03,0xFC,0x03,0x01,0x0F,0x00,0x0C,0x00,0x7F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
0x0F,0x0F,0x8D,0x01,0x3F,0xE0,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x1C,0x01,0xFD,0x81,0x30,0x7C,0x03,0xC0,0xFE,0x00,0x00,0x00,0x04,0x00,0x00,0x00,
0x18,0x00,0x01,0xBF,0x00,0x0F,0xFF,0x07,0xC7,0xE0,0x00,0x00,0x1C,0x00,0x00,0x00,
0x00,0x00,0x00,0xFF,0x80,0x01,0xF8,0x3E,0x00,0x78,0x0F,0xF0,0x78,0x00,0x00,0x00,
0x00,0x0F,0x00,0x7F,0x83,0x80,0x3F,0xF1,0xF8,0x1E,0x1C,0x7F,0xE0,0x07,0xE0,0x00,
0x00,0x1F,0xE0,0x3F,0xDF,0xFE,0x00,0x07,0x9F,0x83,0xF0,0x00,0x00,0x1C,0x7C,0x00,
0x00,0x78,0x70,0x1F,0xD0,0x07,0xC0,0x3C,0x01,0xF8,0x03,0xC0,0x00,0x18,0x00,0x00,
0xFF,0xE0,0x1F,0x73,0xE0,0x00,0xFF,0xE0,0x00,0x1F,0xFF,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x07,0xE1,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x0F,0x80,0x00,0xE1,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x7F,0xE0,0x00,0x07,0x9E,0x00,0x7F,0xC0,0x60,0x0F,0xC0,0x0F,0x00,0x00,0x00,
0x00,0xE0,0x7C,0x00,0x03,0xF7,0xC7,0xE0,0xFF,0xE0,0x3F,0xFF,0xFC,0x00,0x00,0x00,
0x01,0xC0,0x0F,0x00,0x03,0xBD,0xFE,0xFC,0x00,0x00,0xF0,0x1F,0xF0,0x00,0xC6,0x00,
void lcd_init()
CS1 = 1;
write_cmd(0x3f);
write_cmd(0xC0);
write_cmd(0x01);
write_cmd(0x06);
void photodisplay(uchar *bmp)
uchar p,z;
write_dat(0x34);
for(p=0;p<32;p++)
write_dat(0x80+p);
write_dat(0x80);
for(p=0;p<16;p++)
write_dat(*bmp++);
delayms(1);
for(z=0;z<32;z++)
write_dat(0x80+z);
write_dat(0x88);
for(p=0;p<16;p++)
write_dat(*bmp++);
delayms(1);
write_cmd(0x36);
dula = 0;
wela = 0;
lcd_init();
photodisplay(Photo);
delayms(1000);
write_cmd(0x3f);
write_cmd(0x01);
photodisplay(picture);
delayms(1000);
write_cmd(0x3f);
write_cmd(0x01);
}EN = 0;
yzwzfyz
2019-11-21 21:47
先看LCD的說明!!
man1234567
2019-11-22 12:50
看硬件手冊。
1、需外接可調(diào)電阻,如何接什么參數(shù)的電阻,看手冊;
2、電調(diào)的,通過指令操作,如何實(shí)現(xiàn)要看手冊;
3、不提供調(diào)節(jié)功能的,也需要看手冊確認(rèn)。
