標(biāo)題: 基于單片機(jī)的電子萬(wàn)歷的設(shè)計(jì)與制作 [打印本頁(yè)] 作者: zzy789p2 時(shí)間: 2019-11-12 09:53 標(biāo)題: 基于單片機(jī)的電子萬(wàn)歷的設(shè)計(jì)與制作 ABSTRACT
As the rapid development of Single-chip Microcomputer Applicationtechnology, from the navigation device of missile to the various instruments onthe aircraft control and from computer communication network and data transmissionto industrial real-time automation process control and data processing, as wellas the extensive use of the smart card and electronic pets in live, All of thisis inseparable from the microcontroller. SCM is set to CPU, RAM, ROM, timing,counting and multiple interfaces in one microcontroller. It has the advantagesof small volume, low cost, strong function, widely used in smart industries,and industrial automation.
This paper designed a electronic clock which canachieve calendar function based on microcontroller, the system consists of maincontroller STC89C52, clock circuit, display circuit, DS12C887circuit, and areset circuit components, the main control system as the control center,DS12C887 generates a clock, DS18B20 generates temperature, a 12864 LCD displaythe date and time, the key can set the time, alarm clock, achieved the clockcalendar and time display function.
In the future, the calendar will be more accurate,look more beautiful; more affordable prices of the direction of development,and will appear more auxiliary function.
