單片機頻率檢測加PWM調速 lcd1602顯示
wangfushou
2019-11-11 11:18
51單片機頻率采集+lcd1602+按鍵控制PWM
(51.48 KB, 下載次數: 70)
2019-11-11 13:41 上傳
#include<reg52.h>
#include "lcd1602.h"
#define uchar unsigned char//宏定義
#define uint unsigned int//宏定義
sbit ji=P2^1;
sbit jia_key=P3^2;
sbit jian_key=P3^3;
uchar sw,w,q,b,s,g,num=0,gao_num=1;di_num=3;
void timer_init ();
void delay (unsigned int a);
unsigned long fre; //頻率
unsigned char time; //時間
unsigned long count=0; //計數
void delay(uint z) //延時子程序
uint x,y;
for(x = z;x > 0;x--)
for(y = 125;y > 0;y--);
void timer_init (void) //定時器初始化
TMOD = 0x06; //計數器0工作 工作方式2,自動重裝初值
TH0 = 0; //計數器初值為0
TL0 = 0;
TR0 = 1; //計數器開始計數
ET0 = 1; //打開計數器0中斷
RCAP2H = (65536 - 62500) / 256; //在程序初始化的時候給RCAP2H和RCAP2L賦值
RCAP2L = (65536 - 62500) % 256; //TH2與TL2將會在中斷產生時斷使TH2 = RCAP2H,TL2 = RCAP2L.
TH2 = RCAP2H; //12M晶振喜愛每次中斷 62.5ms
TL2 = RCAP2L;
ET2 = 1; //打開定時器2中斷
TR2 = 1; //定時器2開始計時
EA = 1; //打開總中斷
void timer2 (void) interrupt 5 //定時器2中斷62.5ms 服務函
time++;
TF2 = 0; //定時器2的中斷標志位TF2不能由硬件清零,所有要在中斷服務程序中將其清零
if (time == 16) //定時1s時間到
time = 0; //計時清零
EA = 0; //關閉中斷
fre =((long)count*256 + TL0); //count*256強制轉換為long型,否則將不產生進位
TL0 = 0; //清零計數器0計數
TH0 = 0;
count = 0; //清零計數器計數
EA = 1; //打開中斷
void timer0 (void) interrupt 1 //計數器0中斷
count++;
void display_frequency(unsigned long fre)
unsigned char bai,shi,ge,xiao,xiaoo;
bai=fre/10000;
shi=fre%10000/1000;
ge=fre%1000/100;
xiao=fre%100/10;
xiaoo=fre%10;
LCD1602_write_com(0x80+7); //??????????2??9? ???????1??+8??
LCD1602_write_data(0x30+bai); //bai????2??8? ???????,
LCD1602_write_com(0x80+8);
LCD1602_write_data(0x30+shi); //??????,?????1 ??shi?????
LCD1602_write_com(0x80+9);
LCD1602_write_data(0x30+ge); //ge???shi?
LCD1602_write_com(0x80+10);
LCD1602_write_data(0x30+xiao);
LCD1602_write_com(0x80+11);
LCD1602_write_data(0x30+xiaoo);
LCD1602_write_com(0x80+12);
LCD1602_write_word("hz");
void key()
if(jia_key==0)
delay(5);
if(jia_key==0)
num++;
if(num==4)
num=3;
while(jia_key==0);
if(jian_key==0)
delay(5);
if(jian_key==0)
if(num!=0)
num--;
num=0;
while(jian_key==0);
void dispose()
switch(num)
case 0:gao_num=1;di_num=3;break;
case 1:gao_num=2;di_num=2;break;
case 2:gao_num=3;di_num=1;break;
case 3:gao_num=4;di_num=0;break;
void qudong()
uchar i;
if(di_num!=0)
for(i=0;i<di_num;i++)
ji=0;
display_frequency(fre);
// delay(2);
for(i=0;i<gao_num;i++)
ji=1;
// delay(2);
void main ()
timer_init ();//定時/計數器初始化
Init_LCD1602();
while (1)
// ji=0;
// display_frequency(fre);
key();
dispose();
qudong();
51單片機.rar
(866.53 KB, 下載次數: 22)
2019-11-11 11:18 上傳
原理圖1.rar
(31.96 KB, 下載次數: 17)
2019-11-11 11:20 上傳
lhxtzlhxtz
2019-11-11 14:29
很好的程序,謝謝你。
