I2C控制xx+5檔調速直流電機 單片機源程序
msonah
2019-11-5 16:21
直流電機控制
程序功能
6檔調速直流電機,oled(IIC接口)顯示占空比
#include "reg52.h"
#include "i2c.h"
#include "SEEKFREE_OLED.h"
sbit PwmOut=P1^0;
sbit k1=P0^0;
sbit k2=P0^1;
unsigned int period=50000; //設置周期為50000us
unsigned int duty=0; //設置起始占空比值為0
void T0T1_Init(void) //定時器/計數器T0,T1初始化函數
EA=1;
ET0=1;
ET1=1;
TMOD|=0x11;
TR0=1;
TH0=(65536-period)>>8;
TL0=65536-period;
TH1=(65536-duty)>>8;
TL1=65536-duty;
void Delay10ms(void) //誤差 0us
unsigned char a,b,c;
for(c=1;c>0;c--)
for(b=38;b>0;b--)
for(a=130;a>0;a--);
void keypros() //按鍵處理函數,按K1加檔位,按K2減檔位,共6檔(0,1,2,3,4,5)
void numpro();
if(duty!=50000) //封邊,達到最5檔位不可再加
if(k1==0)
Delay10ms();
if(k1==0)
duty+=10000;
while(!k1);
numpro();
if(duty) //封邊,為0檔時不可再減
if(k2==0)
Delay10ms();
if(k2==0)
duty-=10000;
while(!k2);
numpro();
void numpro() //oled顯示處理函數,顯示占空比
switch(duty)
case 0:OLED_P8x16Str(90,3,"0% ");
OLED_P6x8Str(90,5,"min"); break;
case 10000:OLED_P8x16Str(90,3,"20% ");
OLED_P6x8Str(90,5," "); break;
case 20000:OLED_P8x16Str(90,3,"40% ");
case 30000:OLED_P8x16Str(90,3,"60% ");
case 40000:OLED_P8x16Str(90,3,"80% ");
case 50000:OLED_P8x16Str(90,3,"100%");
OLED_P6x8Str(90,5,"max"); break;
PwmOut=0;
T0T1_Init();
Delay10ms(); //等待oled上電完成
Initial_M096128x64_ssd1306();//oled初始化
OLED_P6x8Str(25,0,"hello world");//oled顯示"hello world"
OLED_P6x8Str(25,7,"---made by msonah");//oled顯示"made by msonah"
OLED_P8x16Str(0,3,"duty cycle:");
OLED_P6x8Str(90,5,"min"); //剛通電時顯示“duty cycle:0%”
keypros();
void T0_ISR(void) interrupt 1
TL0=65536-period;
if(duty<period&&(duty))
PwmOut=1;
TR1=1;
if(duty==0)
PwmOut=0;
PwmOut=1;
void T1_ISR(void) interrupt 3
TL1=65536-duty;
PwmOut=0;
TR1=0;
實驗14:I2C控制xx+5檔調速電機3.0.zip
(87.15 KB, 下載次數: 8)
2019-11-5 16:21 上傳
