標(biāo)題: STM32簡(jiǎn)單的步進(jìn)電機(jī)動(dòng)作程序 [打印本頁(yè)]
作者: KIKI123    時(shí)間: 2019-11-2 12:34
  1. #include "motor.h"
  2. #include "delay.h"
  3. int motor_speed;
  4. int motor_route;
  5. int motor_time;
  6. void motor_init(void)
  7. {
  8.   GPIO_InitTypeDef GPIO_InitStructure;
  9.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC , ENABLE);  //使能GPIO外設(shè)時(shí)鐘使能
  10.
  11.    //設(shè)置該引腳為復(fù)用輸出功能,輸出TIM1 CH1的PWM脈沖波形
  12.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11; //TIM_CH1
  13.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //復(fù)用推挽輸出
  14.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  15.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  16. }
  17. //PWM輸出初始化
  18. //arr:自動(dòng)重裝值
  19. //psc:時(shí)鐘預(yù)分頻數(shù)
  20. void motor_pwm(u16 arr,u16 psc)
  21. {
  22.          GPIO_InitTypeDef GPIO_InitStructure;
  23.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  24.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  25.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//
  26.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);  //使能GPIO外設(shè)時(shí)鐘使能
  27.
  28.    //設(shè)置該引腳為復(fù)用輸出功能,輸出TIM1 CH1的PWM脈沖波形
  29.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //TIM_CH1
  30.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //復(fù)用推挽輸出
  31.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  32.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  33.
  34.         TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值         80K
  35.         TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來(lái)作為T(mén)IMx時(shí)鐘頻率除數(shù)的預(yù)分頻值  不分頻
  36.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
  37.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
  38.         TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
  39.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1
  40.
  41.         ; //選擇定時(shí)器模式:TIM脈沖寬度調(diào)制模式2
  42.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  43.         TIM_OCInitStructure.TIM_Pulse = 0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
  44.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //輸出極性:TIM輸出比較極性高
  45.         TIM_OC1Init(TIM1, &TIM_OCInitStructure);  //根據(jù)TIM_OCInitStruct中指定的參數(shù)初始化外設(shè)TIMx
  46.   TIM_CtrlPWMOutputs(TIM1,ENABLE);        //MOE 主輸出使能
  47.         TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1預(yù)裝載使能
  48.
  49.         TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的預(yù)裝載寄存器
  50.
  51.         TIM_Cmd(TIM1, ENABLE);  //使能TIM1
  52.
  53. }
  54. int motor_spe(void)
  55. {
  56.   int i;
  57.         int n;
  58.         n=motor_speed*3/57.6;   //電機(jī)轉(zhuǎn)輪是皮帶輪的三分之一,所以*3
  59.         i=72000000/(3200*n);
  60.         return i;
  61. }
  62. void motor_set(int sp,int re)
  63. {
  64.
  65.     motor_speed=sp;
  66.           motor_route=re;
  67.           motor_time=re*1000/sp;
  68.                   delay_ms(10);
  69.
  70. }
  71. void motor_run()
  72. {
  73.             int i;
  74.       int n;
  75.             n=motor_spe();
  76.             motor_EN=1;
  77.                                 for(i=19999;i>n;i=i-100)//
  78.                         {
  79.
  80.                              TIM1->ARR=i;
  81.                                 delay_us(500);
  82.                                 TIM_SetCompare1(TIM1,i/2);
  83.
  84.                         }
  85. }
  86. void motor_stop()
  87. {
  88.          int i;
  89.                int n;
  90.                n=motor_spe();
  91.                                 for(i=n;i<19999;i=i+100)
  92.                         {
  93.
  94.                              TIM1->ARR=i;
  95.                                 delay_us(100);
  96.                                 TIM_SetCompare1(TIM1,i/2);
  97.
  98.                         }
  99.                                         for(i=n;i<15999;i=i+100)
  100.                         {
  101.
  102.                              TIM1->ARR=i;
  103.                                 delay_us(100);
  104.                                 TIM_SetCompare1(TIM1,i/2);
  105.
  106.                         }
  107.                         motor_EN=0;
  108. }
  109. void motor_fwd(void)
  110. {
  111.    motor_EN=0;
  112.         delay_us(100);
  113.         motor_DIR=1;
  114.         delay_us(100);
  115. }
  116. void motor_rev(void)
  117. {
  118.    motor_EN=0;
  119.         delay_us(100);
  120.         motor_DIR=0;
  121.         delay_us(100);
  122. }
motor.zip
1.84 KB, 下載次數(shù): 17, 下載積分: 黑幣 -5
c和h文件
