我的這個單片機程序為什么按鍵按下后沒有作用?
wqd0829
2019-10-19 20:33
Keil4編寫環境:A/D數模轉換和按鍵應用操作顯示到Lcd1602上,子程序Lcd1602.c,keyboard.c,I2C.c程序略,跪求主程序
程序要求實現:按上鍵查詢設定的電壓值上下限
按下鍵查詢當前的電壓值(當前電壓值是滑動變阻器所配置的電壓值)
數據采集器件用的是PCF8591測AIN0的值
為什么我的主函數這樣寫,在51液晶上按上下鍵沒有任何顯示,跪求主函數,開發板是金三角開發板
是Lcd如何通過按鍵進行翻頁操作,這個程序應該怎么寫,
跪求來個大神,寫下這個程序
#include <reg52.h>
sbit BUZZ = P1^6;
bit flag300ms = 1;
bit enBuzz = 0;
unsigned char T0RH = 0;
unsigned char T0RL = 0;
unsigned int CountDown = 0;
void ConfigTimer0(unsigned int ms);
unsigned char GetADCValue(unsigned char chn);
void ValueToString(unsigned char *str, unsigned char val);
extern void I2CStart();
extern void I2CStop();
extern void KeyScan();
extern void KeyDriver();
extern unsigned char I2CReadACK();
extern unsigned char I2CReadNAK();
extern bit I2CWrite(unsigned char dat);
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
EA = 1;
ConfigTimer0(10);
InitLcd1602();
LcdShowStr (0, 0, "moli");
KeyDriver();
unsigned char GetADCValue (unsigned char chn)
unsigned char val;
I2CStart();
if (!I2CWrite (0x48<<1))
I2CStop();
return 0;
I2CWrite (0x40 | chn);
I2CStart();
I2CWrite ((0x48<<1) | 0x01);
I2CReadACK();
val = I2CReadNAK();
I2CStop();
return val;
val = (val * 25) / 55;
str[0] = (val/10) + '0';
str[1] = '.'; //С????
str[2] = (val%10) + '0';
str[3] = 'V';
str[4] = '\0';
void KeyTaAction()
unsigned char val;
unsigned char str[10];
InitLcd1602();
LcdShowStr (0, 0, "TABANXINHAO");
while (1)
if (flag300ms)
flag300ms = 0;
val = GetADCValue(0);
ValueToString(str, val);
LcdShowStr(0, 1, str);
if (val >= 200)
enBuzz = 1;
if (enBuzz)
BUZZ = ~BUZZ;
BUZZ = 1;
void KeyAction (unsigned char keycode)
if(keycode == 0x26)
KeyTaAction();
else if (keycode == 0x28)
LcdShowStr (0, 0, "MAX");
LcdShowStr (0, 1, 2^5);
LcdShowStr (6, 0, "MIN");
LcdShowStr (6, 1, 0^0);
unsigned long tmp;
tmp = 11059200 / 12;
tmp = (tmp * ms) / 1000;
tmp = 65536 - tmp;
tmp = tmp + 12;
T0RH = (unsigned char)(tmp >> 8);
T0RL = (unsigned char)tmp;
TMOD &= 0xF0;
TMOD |= 0x01;
TH0 = T0RH;
TL0 = T0RL;
ET0 = 1;
TR0 = 1;
void InterruptTimer0() interrupt 1
static unsigned char tmr300ms = 0;
TH0 = T0RH;
TL0 = T0RL;
tmr300ms++;
if (tmr300ms >= 30)
tmr300ms = 0;
flag300ms = 1;
LCD程序
#include <reg52.h>
#define LCD1602_DB P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E = P1^5;
void LcdWaitReady()
unsigned char sta;
LCD1602_DB = 0xFF;
LCD1602_RS = 0;
LCD1602_RW = 1;
do{
LCD1602_E = 1;
sta = LCD1602_DB;
LCD1602_E = 0;
}while (sta & 0x80);
void LcdWriteCmd (unsigned char cmd)
LcdWaitReady();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_E = 1;
LCD1602_E = 0;
void LcdWriteDat(unsigned char dat)
LcdWaitReady();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_E = 1;
LCD1602_E = 0;
void LcdSetCursor(unsigned char x, unsigned char y)
unsigned char addr;
if (y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
LcdWriteCmd(addr | 0x80);
void LcdShowStr (unsigned char x, unsigned char y,
unsigned char *str)
LcdSetCursor(x, y);
while (*str != '\0')
LcdWriteDat (*str++);
void LcdAreaClear(unsigned char x,unsigned char y, unsigned char len)
LcdSetCursor(x, y);
while (len--)
LcdWriteDat(' ');
void LcdFullClear()
LcdWriteCmd(0x01);
void InitLcd1602()
LcdWriteCmd(0x38);
LcdWriteCmd(0x0C);
LcdWriteCmd(0x06);
LcdWriteCmd(0x01);
keyboard程序
#include <reg52.h>
sbit KEY_IN_1 = P2^4;
sbit KEY_IN_2 = P2^5;
sbit KEY_IN_3 = P2^6;
sbit KEY_IN_4 = P2^7;
sbit KEY_OUT_1 = P2^3;
sbit KEY_OUT_2 = P2^2;
sbit KEY_OUT_3 = P2^1;
sbit KEY_OUT_4 = P2^0;
unsigned char code KeyCodeMap[4][4] = {
{ '1', '2', '3', 0x26 },
{ '4', '5', '6', 0x25 },
{ '7', '8', '9', 0x28 },
{ '0', 0x1B, 0x0D, 0x27 }
unsigned char pdata KeySta[4][4] = {
{1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}
extern void KeyAction(unsigned char keycode);
void KeyDriver()
unsigned char i, j;
static unsigned char pdata backup[4][4] = {
for (i=0; i<4; i++)
for (j=0; j<4; j++)
if (backup[ i][j] != KeySta[ i][j])
if (backup[ i][j] != 0)
KeyAction(KeyCodeMap[ i][j]);
backup[ i][j] = KeySta[ i][j];
void KeyScan()
unsigned char i;
static unsigned char keyout = 0;
static unsigned char keybuf[4][4] = {
{0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
for (i=0; i<4; i++)
if ((keybuf[keyout][ i] & 0x0F) == 0x00)
KeySta[keyout][ i] = 0;
else if ((keybuf[keyout][ i] & 0x0F) == 0x0F)
KeySta[keyout][ i] = 1;
keyout++;
keyout &= 0x03;
switch(keyout)
case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
default: break;
I2C程序
#include <reg52.h>
#include <intrins.h>
#define I2CDelay() {_nop_();_nop_();_nop_();_nop_();}
sbit I2C_SCL = P3^7;
sbit I2C_SDA = P3^6;/
void I2CStart()
I2C_SDA = 1;
I2C_SCL = 1;
I2CDelay();
I2C_SDA = 0;
I2CDelay();
I2C_SCL = 0;
void I2CStop()
I2C_SCL = 0;
I2C_SDA = 0;
I2CDelay();
I2C_SCL = 1;
I2CDelay();
I2C_SDA = 1;
I2CDelay();
bit I2CWrite (unsigned char dat)
bit ack;
unsigned char mask;
for (mask=0x80; mask!=0; mask>>=1)
if ((mask&dat) == 0)
I2C_SDA = 0;
I2C_SDA = 1;
I2CDelay();
I2C_SCL = 1;
I2CDelay();
I2C_SCL = 0;
I2C_SDA = 1;
I2CDelay();
I2C_SCL = 1;
ack = I2C_SDA;
I2CDelay();
I2C_SCL = 0;
return (~ack);
unsigned char mask;
unsigned char dat;
I2C_SDA = 1;
I2CDelay();
I2C_SCL = 1;
if(I2C_SDA == 0)
dat &= ~mask;
dat |= mask;
I2CDelay();
I2C_SCL = 0;
I2C_SDA = 1;
I2CDelay();
I2C_SCL = 1;
I2CDelay();
I2C_SCL = 0;
return dat;
unsigned char mask;
unsigned char dat;
I2C_SDA = 1;
I2CDelay();
I2C_SCL = 1;
if (I2C_SDA == 0)
dat &= ~mask;
dat |= mask;
I2CDelay();
I2C_SCL = 0;
I2C_SDA = 0;
I2CDelay();
I2C_SCL = 1;
I2CDelay();
I2C_SCL = 0;
return dat;
bai_yun_123
2019-10-20 13:17
你的KeyScan()函數在主程序中都沒有出現,這個函數的意思是按鍵掃描,一般是用來檢測按鍵是否被按下的,同時一般的按鍵掃描是放在一個大概1s的for循環中的,當然,寫在while循環里就不用這個1s的for循環了。
wqd0829
2019-10-20 14:25
bai_yun_123 發表于 2019-10-20 13:17
你的KeyScan()函數在主程序中都沒有出現,這個函數的意思是按鍵掃描,一般是用來檢測按鍵是否被按下的, ...
嗯嗯,謝謝大哥的解答,我也發現了沒寫按鍵掃描了,我把按鍵掃描加上,現在lcd可以進行翻頁操作,電壓值都可以查詢,但按上鍵我查當前值的時候,每次進去都進入了KeyTaAction()這個函數的while死循環,但再摁下鍵查詢最大最小值就沒有任何反應,我想過把while改成do while 還是實現不了這個電壓值每300ms要檢測,所以,我想問下這個問題怎么解答,謝謝,萬分感謝
bai_yun_123
2019-10-20 17:30
不是while和do while的問題,這兩個循環只是執行條件的先后問題,我看了keytaaction的函數,while(1)是個死循環,只要進去了,沒有break,continue這種跳出循環的語句,那么就出不來,即死循環。把while括號里的條件改成你需要的條件, 比如:
while (flag300ms)
flag300ms = 0;
if (val >= 200)
enBuzz = 1;
if (enBuzz)
BUZZ = ~BUZZ;
BUZZ = 1;
當然,條件不一定對,因為后面有個flag300ms置零,所以這個循環只執行一次,至于執行多少次就得看你的條件了,還有,你的程序很多不對齊,也沒有注釋,看起來很麻煩
