標題: STM32F103C8T6的姿態傳感器源程序 [打印本頁]
作者: 沐浴    時間: 2019-10-13 17:58
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "usart.h"
  4. #include "serial.h"
  5. #include "led.h"
  6. #include "motor.h"
  7. #include "cap.h"
  8. #include "timer.h"
  9. #include "mpu6050.h"
  10. #include "mpuiic.h"
  11. #include "inv_mpu.h"
  12. #include "inv_mpu_dmp_motion_driver.h"
  13. extern u16 ADV[128];
  14. extern u8 CCD_Zhongzhi;
  15. extern u8 CCD_Yuzhi;
  16. extern u16  TIM2CH1_CAPTURE_STA;
  17. extern u16        TIM2CH1_CAPTURE_VAL;
  18. extern u16  TIM1CH1_CAPTURE_STA;
  19. extern u16        TIM1CH1_CAPTURE_VAL;
  20. u8 count_flag=0;
  21. int main(void)
  22. {
  23.         u8 num;
  24.         float pitch,roll,yaw;                 //歐拉角
  25.         short aacx,aacy,aacz;                //加速度傳感器原始數據
  26.         short gyrox,gyroy,gyroz;        //陀螺儀原始數據
  27.         short temp;                                        //溫度
  28.
  29.         SystemInit();        //初始化RCC 設置系統主頻為72MHZ
  30.         delay_init();             //延時初始化
  31.         uart_init(115200);
  32.         MPU_Init();                                        //初始化MPU6050
  33.         mpu_dmp_init();
  34.         while(mpu_dmp_init())//初始化dmp,初始化不過報錯
  35.         {
  36.                 printf("%d",mpu_dmp_init());
  37.         }
  38.
  39.         while(1)
  40.         {
  41.                         if(mpu_dmp_get_data(&pitch,&roll,&yaw)==0)
  42.                         {
  43.                                 temp=MPU_Get_Temperature();        //得到溫度值
  44.                                 MPU_Get_Accelerometer(&aacx,&aacy,&aacz);        //得到加速度傳感器數據
  45.                                 MPU_Get_Gyroscope(&gyrox,&gyroy,&gyroz);        //得到陀螺儀數據
  46.                         }
  47.                 num++;
  48.                 if(num == 50) //每500msLED0閃爍一次
  49.                 {
  50.                         num = 0;
  51. //                        printf("%d %d %d\r\n",gyrox,gyroy,gyroz);
  52. //                        printf("%d %d %d\r\n",aacx,aacy,aacz);
  53.                         printf("x:%3.3f y:%3.3f z:%3.3f\r\n",pitch,roll,yaw);
  54. //                        printf("temp:%d\r\n",temp);
  55.                         printf("\r\n");
  56.                 }
  57.                 delay_ms(10);
  58.         }
  59. }
串口.7z
245.13 KB, 下載次數: 12, 下載積分: 黑幣 -5
