STM32F4xx官方IAP源碼
rest665
2019-10-11 20:07
STM32F4xx官方IAP源碼
STM32F4xx官方IAP源碼
/* Includes ------------------------------------------------------------------*/
#include "menu.h"
#include "stm324xg_eval.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
extern pFunction Jump_To_Application;
extern uint32_t JumpAddress;
/* Private function prototypes -----------------------------------------------*/
static void IAP_Init(void);
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
int main(void)
/* Unlock the Flash Program Erase controller */
FLASH_If_Init();
/* Initialize Key Button mounted on STM324xG-EVAL board */
STM_EVAL_PBInit(BUTTON_KEY, BUTTON_MODE_GPIO);
/* Test if Key push-button on STM324xG-EVAL Board is pressed */
if (STM_EVAL_PBGetState(BUTTON_KEY) == 0x00)
/* Execute the IAP driver in order to reprogram the Flash */
IAP_Init();
/* Display main menu */
Main_Menu ();
/* Keep the user application running */
/* Test if user code is programmed starting from address "APPLICATION_ADDRESS" */
if (((*(__IO uint32_t*)APPLICATION_ADDRESS) & 0x2FFE0000 ) == 0x20000000)
/* Jump to user application */
JumpAddress = *(__IO uint32_t*) (APPLICATION_ADDRESS + 4);
Jump_To_Application = (pFunction) JumpAddress;
/* Initialize user application's Stack Pointer */
__set_MSP(*(__IO uint32_t*) APPLICATION_ADDRESS);
Jump_To_Application();
while (1)
* @brief Initialize the IAP: Configure USART.
* @param None
* @retval None
void IAP_Init(void)
USART_InitTypeDef USART_InitStructure;
/* USART resources configuration (Clock, GPIO pins and USART registers) ----*/
/* USART configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
STM_EVAL_COMInit(COM1, &USART_InitStructure);
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
STM32F4xx_AN3965_V1.0.0.7z
(1.07 MB, 下載次數: 60)
2019-10-11 20:56 上傳
middin
2020-7-2 15:17
這個實例是在官方哪兒下載的
qingyemurong
2020-9-11 15:00
middin 發表于 2020-7-2 15:17
這個實例是在官方哪兒下載的
https://www.st.com/content/st_co ... =IAP-t=tools-page=1
