標(biāo)題: 關(guān)于AD7193的驅(qū)動(dòng) stm8s單片機(jī)SPI代碼編寫問(wèn)題 [打印本頁(yè)]
作者: tyx623521553    時(shí)間: 2019-10-10 16:59
下了官方的驅(qū)動(dòng),但是spi初始化以及讀取自己寫的,出現(xiàn)了問(wèn)題,關(guān)于spi不太懂他的步驟看一下我哪里寫錯(cuò)了?
unsigned char SPI_Read7193(unsigned char slaveDeviceId,
                       unsigned char* data,
                       unsigned char bytesNumber)
  unsigned char byte = 0;
  if(slaveDeviceId == AD7193_SLAVE_ID)PMOD1_CS_LOW;
  for(byte = 0; byte < bytesNumber; byte++)
    while(SPI_GetFlagStatus(SPI_FLAG_RXNE) == RESET);
    *data++ = SPI_ReceiveData();
  if(slaveDeviceId == AD7193_SLAVE_ID)PMOD1_CS_HIGH;
  return bytesNumber;
unsigned char SPI_Write7193(unsigned char slaveDeviceId,
    while(SPI_GetFlagStatus(SPI_FLAG_TXE) == RESET);
    SPI_SendData(*data++);
  return bytesNumber;
這個(gè)是官方給的別的單片機(jī)的例子,我不太了解這個(gè)單片機(jī)和寄存器,你們可以參考一下
unsigned char SPI_Read(unsigned char slaveDeviceId,
    if(slaveDeviceId == 1)
        PMOD1_CS_LOW;
    if(slaveDeviceId == 2)
        ST7579_CS_LOW;
        SIO10 = data[byte];
        __no_operation();
        __no_operation();
        while(SSR02 & 0x0040);
        data[byte] = SIO10;
        PMOD1_CS_HIGH;
        ST7579_CS_HIGH;
    return bytesNumber;
* @brief Writes data to SPI.
* @param slaveDeviceId - The ID of the selected slave device.
* @param data - Data represents the write buffer.
* @param bytesNumber - Number of bytes to write.
* @return Number of written bytes.
unsigned char SPI_Write(unsigned char slaveDeviceId,
    unsigned char read = 0;
        PMOD1_CS_LOW;
        ST7579_CS_LOW;          // Assert CS low
        SIO10 = data[byte];
        __no_operation();
        __no_operation();
        read = SIO10;
        PMOD1_CS_HIGH;
        ST7579_CS_HIGH;         // Assert CS high
    return bytesNumber;
作者: f556    時(shí)間: 2019-10-11 09:23
同系列的SPI都會(huì)不同,如MSP430的F149 與F2553程序差異大,你問(wèn)題又沒說(shuō)清,沒人能幫你
