DHT11溫度模塊濕度模塊51單片機(jī)程序 串口發(fā)送溫濕度數(shù)據(jù)
[打印本頁(yè)]
mcu2
時(shí)間:
2019-9-28 12:39
DHT11溫度模塊濕度模塊溫濕度代碼
(17.38 KB, 下載次數(shù): 85)
2019-9-28 16:42 上傳
單片機(jī)源程序如下:
// DHT21使用范例
//單片機(jī) AT89S52 或 STC89C52RC
//功能 串口發(fā)送溫濕度數(shù)據(jù) 晶振 11.0592M 波特率 9600
//硬件 P2.0口為通訊口連接DHT11,DHT11的電源和地連接單片機(jī)的電源和地,單片機(jī)串口加MAX232連接電腦
#include <reg51.h>
#include <intrins.h>
typedef unsigned char U8; /* defined for unsigned 8-bits integer variable 無(wú)符號(hào)8位整型變量 */
typedef signed char S8; /* defined for signed 8-bits integer variable 有符號(hào)8位整型變量 */
typedef unsigned int U16; /* defined for unsigned 16-bits integer variable 無(wú)符號(hào)16位整型變量 */
typedef signed int S16; /* defined for signed 16-bits integer variable 有符號(hào)16位整型變量 */
typedef unsigned long U32; /* defined for unsigned 32-bits integer variable 無(wú)符號(hào)32位整型變量 */
typedef signed long S32; /* defined for signed 32-bits integer variable 有符號(hào)32位整型變量 */
typedef float F32; /* single precision floating point variable (32bits) 單精度浮點(diǎn)數(shù)(32位長(zhǎng)度) */
typedef double F64; /* double precision floating point variable (64bits) 雙精度浮點(diǎn)數(shù)(64位長(zhǎng)度) */
#define Data_0_time 4
//----------------IO口定義區(qū)--------------------//
sbit P2_0 = P2^0 ;
//----------------定義區(qū)--------------------//
U8 U8FLAG,k;
U8 U8count,U8temp;
U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8 U8comdata;
U8 outdata[5]; //定義發(fā)送的字節(jié)數(shù)
U8 indata[5];
U8 count, count_r=0;
U8 str[5]={"RS232"};
U16 U16temp1,U16temp2;
SendData(U8 *a)
outdata[0] = a[0];
outdata[1] = a[1];
outdata[2] = a[2];
outdata[3] = a[3];
outdata[4] = a[4];
count = 1;
SBUF=outdata[0];
void Delay(U16 j)
{ U8 i;
for(;j>0;j--)
for(i=0;i<27;i++);
void Delay_10us(void)
U8 i;
i--;
i--;
i--;
i--;
i--;
i--;
void COM(void)
U8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!P2_0)&&U8FLAG++);
Delay_10us();
Delay_10us();
Delay_10us();
U8temp=0;
if(P2_0)U8temp=1;
U8FLAG=2;
while((P2_0)&&U8FLAG++);
//超時(shí)則跳出for循環(huán)
if(U8FLAG==1)break;
//判斷數(shù)據(jù)位是0還是1
// 如果高電平高過(guò)預(yù)定0高電平值則數(shù)據(jù)位為 1
U8comdata<<=1;
U8comdata|=U8temp; //0
}//rof
//-----濕度讀取子程序 ------------
//----以下變量均為全局變量--------
//----溫度高8位== U8T_data_H------
//----溫度低8位== U8T_data_L------
//----濕度高8位== U8RH_data_H-----
//----濕度低8位== U8RH_data_L-----
//----校驗(yàn) 8位 == U8checkdata-----
//----調(diào)用相關(guān)子程序如下----------
//---- Delay();, Delay_10us();,COM();
void RH(void)
//主機(jī)拉低18ms
P2_0=0;
Delay(180);
P2_0=1;
//總線由上拉電阻拉高 主機(jī)延時(shí)20us
Delay_10us();
Delay_10us();
Delay_10us();
Delay_10us();
//主機(jī)設(shè)為輸入 判斷從機(jī)響應(yīng)信號(hào)
P2_0=1;
//判斷從機(jī)是否有低電平響應(yīng)信號(hào) 如不響應(yīng)則跳出,響應(yīng)則向下運(yùn)行
if(!P2_0) //T !
U8FLAG=2;
//判斷從機(jī)是否發(fā)出 80us 的低電平響應(yīng)信號(hào)是否結(jié)束
U8FLAG=2;
//判斷從機(jī)是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
//數(shù)據(jù)接收狀態(tài)
COM();
U8RH_data_H_temp=U8comdata;
COM();
U8RH_data_L_temp=U8comdata;
COM();
U8T_data_H_temp=U8comdata;
COM();
U8T_data_L_temp=U8comdata;
COM();
U8checkdata_temp=U8comdata;
P2_0=1;
//數(shù)據(jù)校驗(yàn)
U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8RH_data_H_temp;
U8RH_data_L=U8RH_data_L_temp;
U8T_data_H=U8T_data_H_temp;
U8T_data_L=U8T_data_L_temp;
U8checkdata=U8checkdata_temp;
}//fi
}//fi
//main()功能描述: AT89C51 11.0592MHz 串口發(fā)
//送溫濕度數(shù)據(jù),波特率 9600
U8 i,j;
//uchar str[6]={"RS232"};
/* 系統(tǒng)初始化 */
TMOD = 0x20; //定時(shí)器T1使用工作方式2
TH1 = 253; // 設(shè)置初值
TL1 = 253;
TR1 = 1; // 開始計(jì)時(shí)
SCON = 0x50; //工作方式1,波特率9600bps,允許接收
ES = 1;
EA = 1; // 打開所以中斷
TI = 0;
RI = 0;
SendData(str) ; //發(fā)送到串口
Delay(1); //延時(shí)100US(12M晶振)
//調(diào)用溫濕度讀取子程序
RH();
//串口顯示程序
str[0]=U8RH_data_H;
str[1]=U8RH_data_L;
str[2]=U8T_data_H;
str[3]=U8T_data_L;
str[4]=U8checkdata;
//讀取模塊數(shù)據(jù)周期不易小于 2S
Delay(20000);
}//elihw
}// main
void RSINTR() interrupt 4 using 2
U8 InPut3;
if(TI==1) //發(fā)送中斷
TI=0;
if(count!=5) //發(fā)送完5位數(shù)據(jù)
SBUF= outdata[count];
count++;
if(RI==1) //接收中斷
InPut3=SBUF;
indata[count_r]=InPut3;
count_r++;
RI=0;
if (count_r==5)//接收完4位數(shù)據(jù)
//數(shù)據(jù)接收完畢處理。
count_r=0;
str[0]=indata[0];
str[1]=indata[1];
str[2]=indata[2];
str[3]=indata[3];
str[4]=indata[4];
P0=0;
DHT11溫度模塊濕度模塊溫濕度模塊傳感器 DHT11傳感器(送杜邦線).rar
(2.3 MB, 下載次數(shù): 72)
2019-9-28 12:39 上傳
點(diǎn)擊文件名下載附件
kisszg
時(shí)間:
2019-10-24 21:19
可以,下載來(lái)學(xué)習(xí)
