精確到0.1秒的三位秒表單片機程序Proteus仿真(共陰極)
smyzy
2019-8-8 15:06
采用80c52單片機,精確到0.1秒的三位秒表(共陰極)。
(180.55 KB, 下載次數: 71)
2019-8-8 15:05 上傳
#include<reg52.h> //頭函數
#define led P0
typedef unsigned char u8;
typedef unsigned int u16;
sbit P20=P2^0; //位定義
sbit P21=P2^1;
sbit P22=P2^2;
sbit P23=P2^3;
sbit P27=P0^7;
sbit k1 = P3^2;
sbit k2 = P3^3;
sbit beep=P1^5;
static u8 min = 0;
static u8 sec = 0;
static u8 spot = 0;
u8 smgz[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f};
void delay(u16 i)
while(i--);
void display( )
P23=0;
P0=smgz[spot%10];
delay(1000);
P23=1;
P22=0;
P0=smgz[sec%10]|0x80;
delay(1000);
P22=1;
P21=0;
P0=smgz[min%10];
delay(1000);
P21=1;
P20=0;
P0=smgz[min/10];
delay(1000);
P20=1;
void Timer0Init()
TMOD |= 0X01;
TH0 = 0XFC;
TL0 = 0X18;
ET0 = 1;
IT0=1;//跳變沿出發方式(下降沿)
EX0=1;//打開INT0的中斷允許。
IT1=1;
EX1=1;
EA = 1;
TR0 = 1;
void BEEP()
beep=~beep;
delay(10); //延時大約100us
Timer0Init();
display( );
void Timer0() interrupt 1
static int Timer0_times = 0;
TH0 = 0XFC;
TL0 = 0X18;
Timer0_times++;
if(Timer0_times == 70)
if(spot < 9)
spot++;
else if(sec < 9)
sec++;
spot = 0;
min++;
spot = sec = 0;
if(min>=12)
BEEP();
Timer0_times = 0;
void Int0() interrupt 0 //外部中斷0的中斷函數
delay(1000); //延時消抖
if(k1==0)
TR0 = ~TR0;
void Int1() interrupt 2 //外部中斷1的中斷函數
delay(1000); //延時消抖
if(k2==0)
TR0 = 0;
min = sec = spot = 0;
精確到0.1秒的三位秒表(共陰極).rar
(46.22 KB, 下載次數: 47)
2019-8-8 15:06 上傳
