單片機(jī)超聲波循跡小車(chē)源代碼(PWM版)程序錯(cuò)誤 求幫助
[打印本頁(yè)]
yangkainb
時(shí)間:
2019-7-29 15:02
Trig ------- P2^1;
Echo ------- P2^0;
VCC -------- +5v
GND -------- GND
請(qǐng)?jiān)谏想娭埃瑱z查好接線(xiàn)是否正確。
單片機(jī)源程序如下:
#include <reg51.h>
#include <intrins.h>
#include "lcd.h"
sbit Trig = P2^1;
sbit Echo = P2^0;
sbit IN1 = P1^0;
sbit IN2 = P1^1;
sbit IN3 = P1^3;
sbit IN4 = P1^4;
sbit EN1 = P1^2;
sbit EN2 = P1^5;
unsigned char PuZh[]=" Pechin Science ";
unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //顯示用指針
unsigned int time=0;
unsigned long S=0;
bit flag =0;
unsigned char disbuff[4] ={ 0,0,0,0,};
* 函 數(shù) 名 : main
* 函數(shù)功能 : 主函數(shù)
* 輸 入 : 無(wú)
* 輸 出 : 無(wú)
void delay(int In,int Out)
int i,j;
for(i=0;i<In;i++)
for(j=0;j<Out;j++)
void forward(void) //前進(jìn)
EN1 = 1;
EN2 = 1;
IN1 = 1;
IN2 = 0; //左車(chē)輪的正轉(zhuǎn)
IN3 = 1;
IN4 = 0;
} //右車(chē)輪的正轉(zhuǎn)
void backward(void) //前進(jìn)
EN1 = 1;
EN2 = 1;
IN1 = 0;
IN2 = 1; //左車(chē)輪的正轉(zhuǎn)
IN3 = 0;
IN4 = 1;
void stop(void) //停車(chē)
EN1 = 1;
EN2 = 1;
IN1 = 0;
IN2 = 0; //左電機(jī)不動(dòng)
IN3 = 0;
IN4 = 0;
void right(void) //向右
EN1 = 1;
EN2 = 1;
IN1 = 1;
IN2 = 0; //智能小車(chē)左車(chē)輪正轉(zhuǎn)
IN3 = 0;
IN4 = 1; //智能小車(chē)右車(chē)輪反轉(zhuǎn)
void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.7)/100; //算出來(lái)是CM
if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
flag=0;
DisplayOneChar(0, 1, ASCII[11]);
DisplayOneChar(1, 1, ASCII[10]); //顯示點(diǎn)
DisplayOneChar(2, 1, ASCII[11]);
DisplayOneChar(3, 1, ASCII[11]);
DisplayOneChar(4, 1, ASCII[12]); //顯示M
disbuff[0]=S%1000/100;
disbuff[1]=S%1000%100/10;
disbuff[2]=S%1000%10 %10;
DisplayOneChar(0, 1, ASCII[disbuff[0]]);
DisplayOneChar(2, 1, ASCII[disbuff[1]]);
DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void gogogo()
if(S>35&&S<1000)
backward();
delay(200,200);
stop();
else if(S<35&&S>=15)
right();
delay(200,200);
stop();
else if(S<15&&S>10)
forward();
delay(200,200);
stop();
stop();
void zd0() interrupt 1 //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
flag=1; //中斷溢出標(biāo)志
void StartModule() //啟動(dòng)模塊
Trig=1; //啟動(dòng)一次模塊
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
Trig=0;
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
void main(void)
TMOD=0x01; //設(shè)T0為方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1; //允許T0中斷
EA=1; //開(kāi)啟總中斷
InitLcd1602();
LcdShowStr(0,0,PuZh);
StartModule();
while(!Echo); //當(dāng)RX為零時(shí)等待
TR0=1; //開(kāi)啟計(jì)數(shù)
while(Echo); //當(dāng)RX為1計(jì)數(shù)并等待
TR0=0; //關(guān)閉計(jì)數(shù)
Conut(); //計(jì)算
delayms(80);
gogogo();
delayms(80);
delayms(80);
void zd0() interrupt 3 //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
超聲波循跡小車(chē)(PWM版).7z
(20.35 KB, 下載次數(shù): 16)
2019-7-29 15:02 上傳
點(diǎn)擊文件名下載附件
馮666
時(shí)間:
2021-7-28 14:18
程序錯(cuò)誤
