大家可以幫忙看一下一下代碼嗎? 我已經(jīng)看了將近一周了但達(dá)不到我的目的,每個(gè)獨(dú)立鍵盤控制不同頻率的聲音,求各位大師幫忙啊!
#include <reg52.h>
unsigned char i,j,key;
uchar table[]={63343,640,63330};
uchar hz;
sbit key1=P3^2;
sbit key2=P3^3;
sbit key3=P1^0;
sbit key4=P1^1;
sbit fenmingqi=P3^4;
void delay(uint x);
void program(uchar key);
void init();
void main(void)
init();
if(key1==0)
hz=table[0];
program(key1);
if(key2==0)
hz=table[1];
program(key2);
void t0(void) interrupt 1 using 0
TH0=(65536-hz)/256;
TL0=(65536-hz)%256;
fenmingqi=~fenmingqi;
TH0=(65536-hz)/256;
TL0=(65536-hz)%256;
if (key==0)
delay(2);
if(key==0)
TR0=1;
while(key1==0)
fenmingqi=1;
TR0=1;
void init()
TMOD=0x01;
ET0=1;
EA=1;
void delay(uint x)
uint y,i;
for (y=0;y<x;y++)
for(i=0;i<3;i++);
