51單片機利用藍牙傳輸數據代碼
GQL
2019-7-26 16:49
51單片機利用藍牙傳輸數據代碼
這是我在設計上設計的51單片機(stc98c52)與藍牙模塊(hc-08)連接,利用藍牙透傳模式做的相互通訊系統。
#include <reg51.h>
void UsartInit();
void Delay1ms(uint c) ;
uchar receiveData;
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,
0xf8,0x80,0x90};
UsartInit();
while(1);
void UsartInit()
SCON=0X50;
TMOD=0X20;
PCON=0X80;
TH1=0XFA;
TL1=0XFA;
ES=1;
EA=1;
TR1=1;
uint a,b;
for(a=c;a>0;a--)
for(b=112;b>0;b--);
void Usart() interrupt 4
receiveData=SBUF;
RI = 0;
SBUF=receiveData;
while(!TI);
TI=0;
if(receiveData=='0')
P0=table[0];
else if(receiveData=='1')
P0=table[1];
else if(receiveData=='2')
P0=table[2];
else if(receiveData=='3')
P0=table[3];
else if(receiveData=='4')
P0=table[4];
else if(receiveData=='5')
P0=table[5];
else if(receiveData=='6')
P0=table[6];
else if(receiveData=='7')
P0=table[7];
else if(receiveData=='8')
P0=table[8];
else if(receiveData=='9')
P0=table[9];
P0=~table[8];
Delay1ms(1000);
STC89C52與藍牙模塊HC-08互通信.zip
(38.9 KB, 下載次數: 59)
2019-7-26 16:48 上傳
例程
