stm32 modbus通信程序 485觸摸屏、工控屏 開發很好用
yuguoyu123456
2019-7-23 20:27
stm32 modbus通信 觸摸屏、工控屏 開發很好用!!!
#include "rs485.h"
#include "SysTick.h"
#include "crc16.h"
#include "led.h"
* 函 數 名 : RS485_Init
* 函數功能 : USART2初始化函數
* 輸 入 : bound:波特率
* 輸 出 : 無
u8 USART2_RX_BUF[64]; //接收緩沖,最大64字節
u8 USART2_RX_CNT=0; //接收字節計數器
u8 flagFrame=0; //幀接收完成標志,即接收到一幀新數據
unsigned char regGroup[5]; //Modbus寄存器組,地址為0x00~0x04
void RS485_Init(u32 bound)
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG|RCC_APB2Periph_GPIOA,ENABLE); //使能GPIOA\G時鐘
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2時鐘
/* 配置GPIO的模式和IO口 */
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2; //TX-485 //串口輸出PA2
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP; //復用推挽輸出
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure); /* 初始化串口輸入IO */
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3; //RX-485 //串口輸入PA3
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING; //模擬輸入
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3; //CS-485
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP; //推挽輸出
GPIO_Init(GPIOG,&GPIO_InitStructure);
//USART2 初始化設置
USART_InitStructure.USART_BaudRate = bound;//波特率設置
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字長為8位數據格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一個停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//無奇偶校驗位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//無硬件數據流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收發模式
USART_Init(USART2, &USART_InitStructure); //初始化串口2
USART_Cmd(USART2, ENABLE); //使能串口 2
USART_ClearFlag(USART2, USART_FLAG_TC);
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//開啟接受中斷
//Usart2 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;//搶占優先級3
NVIC_InitStructure.NVIC_IRQChannelSubPriority =2; //子優先級2
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根據指定的參數初始化VIC寄存器、
RS485_TX_EN=0; //默認為接收模式
//1ms定時
void TIM2_Init()
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);//使能TIM4時鐘
TIM_TimeBaseInitStructure.TIM_Period=1000; //自動裝載值
TIM_TimeBaseInitStructure.TIM_Prescaler=72-1; //分頻系數
TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up; //設置向上計數模式
TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructure);
TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE); //開啟定時器中斷
TIM_ClearITPendingBit(TIM2,TIM_IT_Update);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;//定時器中斷通道
NVIC_InitStructure.NVIC_IRQChannelSubPriority =3; //子優先級
TIM_Cmd(TIM2,ENABLE); //使能定時器
//計算發送的數據長度,并且將數據放到*buf數組中
u8 UartRead(u8 *buf, u8 len)
u8 i;
if(len>USART2_RX_CNT) //指定讀取長度大于實際接收到的數據長度時
len=USART2_RX_CNT; //讀取長度設置為實際接收到的數據長度
for(i=0;i<len;i++) //拷貝接收到的數據到接收指針中
*buf=USART2_RX_BUF[i]; //將數據復制到buf中
buf++;
USART2_RX_CNT=0; //接收計數器清零
return len; //返回實際讀取長度
u8 rs485_UartWrite(u8 *buf ,u8 len) //發送
u8 i=0;
GPIO_SetBits(GPIOG,GPIO_Pin_3); //發送模式
delay_ms(3); //3MS延時
for(i=0;i<=len;i++)
USART_SendData(USART2,buf[i]); //通過USARTx外設發送單個數據
while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==RESET); //檢查指定的USART標志位設置與否,發送數據空位標志
GPIO_ResetBits(GPIOG,GPIO_Pin_3); //設置為接收模式
//串口驅動函數,檢測數據幀的接收,調度功能函數,需在主循環中調用
void UartDriver()
unsigned char i=0,cnt;
unsigned int crc;
unsigned char crch,crcl;
static u8 len;
static u8 buf[60];
if(flagFrame) //幀接收完成標志,即接收到一幀新數據
flagFrame=0; //幀接收完成標志清零
len = UartRead(buf,sizeof(buf)); //將接收到的命令讀到緩沖區中
if(buf[0]==0x01) //判斷地址是不是0x01
crc=GetCRC16(buf,len-2); //計算CRC校驗值,出去CRC校驗值
crch=crc>>8; //crc高位
crcl=crc&0xFF; //crc低位
if((buf[len-2]==crch)&&(buf[len-1]==crcl)) //判斷CRC校驗是否正確
switch (buf[1]) //按功能碼執行操作
case 0x03: //讀數據
if((buf[2]==0x00)&&(buf[3]<=0x05)) //寄存器地址支持0x0000~0x0005
if(buf[3]<=0x04)
i=buf[3];//提取寄存器地址
cnt=buf[5]; //提取待讀取的寄存器數量
buf[2]=cnt*2; //讀取數據的字節數,為寄存器*2,因modbus定義的寄存器為16位
len=3;
while(cnt--)
buf[len++]=0x00; //寄存器高字節補0
buf[len++]=regGroup[i++]; //低字節
break;
else //寄存器地址不被支持時,返回錯誤碼
buf[1]=0x83; //功能碼最高位置1
buf[2]=0x02; //設置異常碼為02-無效地址
len=3;
break;
case 0x06: //寫入單個寄存器
if((buf[2]==0x00)&&(buf[3]<=0x05)) //寄存器地址支持0x0000-0x0005
if(buf[3]<=0x04)
i=buf[3]; //提取寄存器地址
regGroup[i]=buf[5]; //保存寄存器數據
led3=0;
len -=2; //長度-2以重新計算CRC并返回原幀
break;
{ //寄存器地址不被支持,返回錯誤碼
buf[1]=0x86; //功能碼最高位置1
len=3;
break;
default: //其他不支持的功能碼
buf[1]=0x80; //功能碼最高位置1
buf[2]=0x01; //設置異常碼為01—無效功能
len=3;
break;
crc=GetCRC16(buf,len); //計算CRC校驗值
buf[len++]=crc>>8; //CRC高字節
buf[len++]=crc&0xff; //CRC低字節
rs485_UartWrite(buf,len); //發送響應幀
void UartRxMonitor(u8 ms) //串口接收監控
static u8 USART2_RX_BKP=0; //定義USART2_RC_BKP暫時存儲詩句長度與實際長度比較
static u8 idletmr=0; //定義監控時間
if(USART2_RX_CNT>0)//接收計數器大于零時,監控總線空閑時間
if(USART2_RX_BKP!=USART2_RX_CNT) //接收計數器改變,即剛接收到數據時,清零空閑計時
USART2_RX_BKP=USART2_RX_CNT; //賦值操作,將實際長度給USART2_RX_BKP
idletmr=0; //將監控時間清零
else ////接收計數器未改變,即總線空閑時,累計空閑時間
//如果在一幀數據完成之前有超過3.5個字節時間的停頓,接收設備將刷新當前的消息并假定下一個字節是一個新的數據幀的開始
if(idletmr<5) //空閑時間小于1ms時,持續累加
idletmr +=ms;
if(idletmr>=5) //空閑時間達到1ms時,即判定為1幀接收完畢
flagFrame=1;//設置命令到達標志,幀接收完畢標志
USART2_RX_BKP=0;
* 函 數 名 : USART2_IRQHandler
* 函數功能 : USART2中斷函數
* 輸 入 : 無
* 輸 出 : 無
void USART2_IRQHandler(void)
u8 res; //定義數據緩存變量
if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)//接收到數據
res =USART_ReceiveData(USART2);//;讀取接收到的數據USART2->DR
if(USART2_RX_CNT<sizeof(USART2_RX_BUF)) //一次只能接收64個字節,人為設定,可以更大,但浪費時間
USART2_RX_BUF[USART2_RX_CNT]=res; //記錄接收到的值
USART2_RX_CNT++; //使收數據增加1
* 函 數 名 : TIM2_IRQHandler
* 函數功能 : TIM2中斷函數
* 輸 入 : 無
* 輸 出 : 無
void TIM2_IRQHandler(void)
UartRxMonitor(1); ////串口接收監控
led2=!led2; //指示燈
//delay_ms(100);
TIM_ClearITPendingBit(TIM2,TIM_IT_Update); //更新中斷
ModBus-Master.7z
(201.85 KB, 下載次數: 304)
2019-7-24 04:47 上傳
stm32+RS485.7z
(179.63 KB, 下載次數: 328)
2019-7-24 04:47 上傳
admin
2019-7-24 04:48
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
zk115
2019-7-25 21:32
感謝分享。正好最近在做相關軟件
sishen00
2020-9-11 23:13
感謝分享。正好最近在做相關軟件
liangdong1
2020-9-12 15:15
感謝分享。正好最近在做相關軟件
51heixc
2020-9-13 10:29
感謝正在學習相關知識
ljfong
2020-10-31 22:55
其實程序不重要,重要的是理論知識
tianwudalu
2021-11-22 14:27
感謝正在學習相關知識
he200312
2021-12-9 13:35
感謝分享。正好最近在做相關軟件
1234578zqq
2024-7-27 15:45
感謝分享。正好最近在做相關軟件
huaishang
2024-7-28 18:50
感謝正在學習相關知識
秋風涼
2024-9-15 15:48
感謝正在學習相關知識
huaishang
2025-4-19 09:53
感謝正在學習相關知識
