NTC熱敏電阻溫度值獲取 ADC1 STM32單片機程序
sr861126
2019-7-15 10:03
* 文件名 :main.c
* 描述 :串口1(USART1)向電腦的超級終端以1s為間隔打印當前ADC1的轉(zhuǎn)換電壓值
* 實驗平臺:MINI STM32開發(fā)板 基于STM32F103C8T6
* 庫版本 :ST3.0.0
#include "stm32f10x.h"
#include "stdio.h"
extern __IO u16 ADC_ConvertedValue;
// 軟件延時
#define ADC1_DR_Address ((u32)0x4001244C)
/*配置采樣通道端口 使能GPIO時鐘 設置ADC采樣PA0端口信號*/
#define Res1 4700 //4.7K
#define BValue 3435 //10K
float Rt,Temperature,Voltage;
void ADC1_GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //GPIO設置為模擬輸入
GPIO_Init(GPIOA, &GPIO_InitStructure);
/*配置ADC1的工作模式為MDA模式 */
void ADC1_Mode_Config(void)
DMA_InitTypeDef DMA_InitStructure;
ADC_InitTypeDef ADC_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能MDA1時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); //使能ADC1時鐘
/* DMA channel1 configuration */
DMA_DeInit(DMA1_Channel1); //指定DMA通道
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;//設置DMA外設地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; //設置DMA內(nèi)存地址,ADC轉(zhuǎn)換結(jié)果直接放入該地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //外設為設置為數(shù)據(jù)傳輸?shù)膩碓?br /> DMA_InitStructure.DMA_BufferSize = 1; //DMA緩沖區(qū)設置為1;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE); //使能DMA通道
/* ADC1 configuration */
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //使用獨立模式,掃描模式
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //無需外接觸發(fā)器
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//使用數(shù)據(jù)右對齊
ADC_InitStructure.ADC_NbrOfChannel = 1; // 只有1個轉(zhuǎn)換通道
ADC_Init(ADC1, &ADC_InitStructure);
/* ADC1 regular channel11 configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5); //通道0采樣周期55.5個時鐘周期
ADC_TempSensorVrefintCmd(ENABLE);//開啟溫度控制寄存器
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE); //使能ADC的DMA
/* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE); //使能ADC1
/* Enable ADC1 reset calibaration register */
ADC_ResetCalibration(ADC1); //使能復位校準
/* Check the end of ADC1 reset calibration register */
while(ADC_GetResetCalibrationStatus(ADC1));//等待復位校準結(jié)束
/* Start ADC1 calibaration */
ADC_StartCalibration(ADC1);//開啟AD校準
/* Check the end of ADC1 calibration */
while(ADC_GetCalibrationStatus(ADC1));
/* Start ADC1 Software Conversion */
ADC_SoftwareStartConvCmd(ADC1, ENABLE); //開始轉(zhuǎn)換
/*初始化ADC1 */
void ADC1_Init(void)
ADC1_GPIO_Config();
ADC1_Mode_Config();
void Delay(unsigned long time)
unsigned long i,j;
for(j=0; j<time; j++)
for(i=0;i<12000;i++);
void USART1_Config(void)
USART_InitTypeDef USART_InitStructure;
/* 使能 USART1 時鐘*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
/* USART1 使用IO端口配置 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //復用推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空輸入
GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化GPIOA
/* USART1 工作模式配置 */
USART_InitStructure.USART_BaudRate =115200; //波特率設置:115200
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //數(shù)據(jù)位數(shù)設置:8位
USART_InitStructure.USART_StopBits = USART_StopBits_1; //停止位設置:1位
USART_InitStructure.USART_Parity = USART_Parity_No ; //是否奇偶校驗:無
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //硬件流控制模式設置:沒有使能
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收與發(fā)送都使能
USART_Init(USART1, &USART_InitStructure); //初始化USART1
USART_Cmd(USART1, ENABLE);// USART1使能
/* 描述 :重定向c庫函數(shù)printf到USART1*/
int fputc(int ch, FILE *f)
/* 將Printf內(nèi)容發(fā)往串口 */
USART_SendData(USART1, (unsigned char) ch);
while (!(USART1->SR & USART_FLAG_TXE));
return (ch);
int main(void)
// u32 AD_value;
u32 i,ADC;
/* 配置系統(tǒng)時鐘為72M */
// SystemInit();
/* 配置串口 */
ADC1_Init();
USART1_Config();
/* 初始化ADC1 */
// printf("");//打印電壓值初始化不能關閉
while (1)
// AD_value = 3300000/4096*ADC_ConvertedValue/1000;
ADC=0;
for(i=0;i<50;i++)
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));//等待轉(zhuǎn)換結(jié)束標志位
ADC=ADC+ADC_GetConversionValue(ADC1);//返回最近一次 ADCx 規(guī)則組的轉(zhuǎn)換結(jié)果
ADC=ADC/50;
printf("溫度 = %f℃\r\n",(1.43-3.3/4095*ADC)/0.0043+25);
// printf("ADC = %fv\r\n", ADC*3.3/4095);
Delay(3000);//延時不低于1s
admin
2019-7-15 17:26
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
donghuahu
2020-11-20 16:09
看的懂。不過這個算法比較粗暴。沒用數(shù)據(jù)表插值的方式。因為NTC本來就不是線性的。
所以準確性差一點。
衛(wèi)星路大鯉魚
2020-11-20 16:44
剛剛用完NTC 我是按照熱電阻的說明書直接把-40℃到+120℃分成320份做的,樓主這一份值得再改進一下
levies
2021-4-16 21:17
衛(wèi)星路大鯉魚 發(fā)表于 2020-11-20 16:44
能不能交流一下ntc的用法呀
