標題: 【零知ESP8266】教程:OLED天氣時鐘 [打印本頁]
作者: roc2    時間: 2019-6-19 10:32
本文演示通過OLED顯示時鐘和天氣情況,主要利用的是openweathermap的免費天氣API。
1、硬件準備
(1)零知ESP8266開發板
(2)OLED SSD1306模塊(3)若干杜邦線
2、電路連接
接線很簡單,I2C接口對應連接即可:
接好后實物圖如下:
2、軟件代碼
使用零知開發工具,使用了OLED和WeatherStation相關的軟件庫,因此需要安裝對應的庫:
esp8266-weather-station-1.6.6.rar (885.92 KB, 下載次數: 190)
安裝完成后,我們新建工程:
  1. /*
  2. 2019年6月13日13:47:26
  3. by 零知實驗室
  4. */
  5. #include <ESPWiFi.h>
  6. #include <ESPHTTPClient.h>
  7. #include <JsonListener.h>
  8. // time
  9. #include <time.h>                       // time() ctime()
  10. #include <sys/time.h>                   // struct timeval
  11. #include <coredecls.h>                  // settimeofday_cb()
  12. #include "SSD1306Wire.h"
  13. #include "OLEDDisplayUi.h"
  14. #include "Wire.h"
  15. #include "OpenWeatherMapCurrent.h"
  16. #include "OpenWeatherMapForecast.h"
  17. #include "WeatherStationFonts.h"
  18. #include "WeatherStationImages.h"
  19. /***************************
  20. * Begin Settings
  21. **************************/
  22. // WIFI
  23. const char* WIFI_SSID = "xx";
  24. const char* WIFI_PWD = "xx";
  25. #define TZ              8       // (utc+) TZ in hours
  26. #define DST_MN          60      // use 60mn for summer time in some countries
  27. // Setup
  28. const int UPDATE_INTERVAL_SECS = 20 * 60; // Update every 20 minutes
  29. // Display Settings
  30. const int I2C_DISPLAY_ADDRESS = 0x3c;
  31. const int SDA_PIN = D3;
  32. const int SDC_PIN = D4;
  33. // OpenWeatherMap Settings
  34. // Sign up here to get an API key:
  35. // Pick a language code from this list:
  36. // Arabic - ar, Bulgarian - bg, Catalan - ca, Czech - cz, German - de, Greek - el,
  37. // English - en, Persian (Farsi) - fa, Finnish - fi, French - fr, Galician - gl,
  38. // Croatian - hr, Hungarian - hu, Italian - it, Japanese - ja, Korean - kr,
  39. // Latvian - la, Lithuanian - lt, Macedonian - mk, Dutch - nl, Polish - pl,
  40. // Portuguese - pt, Romanian - ro, Russian - ru, Swedish - se, Slovak - sk,
  41. // Slovenian - sl, Spanish - es, Turkish - tr, Ukrainian - ua, Vietnamese - vi,
  42. // Chinese Simplified - zh_cn, Chinese Traditional - zh_tw.
  43. String OPEN_WEATHER_MAP_LANGUAGE = "zh_cn";
  44. const uint8_t MAX_FORECASTS = 4;
  45. const boolean IS_METRIC = true;
  46. // Adjust according to your language
  47. const String WDAY_NAMES[] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};
  48. const String MONTH_NAMES[] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
  49. /***************************
  50. * End Settings
  51. **************************/
  52. // Initialize the oled display for address 0x3c
  53. // sda-pin=14 and sdc-pin=12
  54. SSD1306Wire     display(I2C_DISPLAY_ADDRESS, SDA_PIN, SDC_PIN);
  55. OLEDDisplayUi   ui( &display );
  56. OpenWeatherMapCurrentData currentWeather;
  57. OpenWeatherMapCurrent currentWeatherClient;
  58. OpenWeatherMapForecastData forecasts[MAX_FORECASTS];
  59. OpenWeatherMapForecast forecastClient;
  60. #define TZ_MN           ((TZ)*60)
  61. #define TZ_SEC          ((TZ)*3600)
  62. #define DST_SEC         ((DST_MN)*60)
  63. time_t now;
  64. // flag changed in the ticker function every 10 minutes
  65. bool readyForWeatherUpdate = false;
  66. String lastUpdate = "--";
  67. long timeSinceLastWUpdate = 0;
  68. //declaring prototypes
  69. void drawProgress(OLEDDisplay *display, int percentage, String label);
  70. void updateData(OLEDDisplay *display);
  71. void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
  72. void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
  73. void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
  74. void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex);
  75. void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state);
  76. void setReadyForWeatherUpdate();
  77. // Add frames
  78. // this array keeps function pointers to all frames
  79. // frames are the single views that slide from right to left
  80. FrameCallback frames[] = { drawDateTime, drawCurrentWeather, drawForecast };
  81. int numberOfFrames = 3;
  82. OverlayCallback overlays[] = { drawHeaderOverlay };
  83. int numberOfOverlays = 1;
  84. void setup() {
  85.   Serial.begin(115200);
  86.   Serial.println();
  87.   Serial.println();
  88.   // initialize dispaly
  89.   display.init();
  90.   display.clear();
  91.   display.display();
  92.   //display.flipScreenVertically();
  93.   display.setFont(ArialMT_Plain_10);
  94.   display.setTextAlignment(TEXT_ALIGN_CENTER);
  95.   display.setContrast(255);
  96.   WiFi.begin(WIFI_SSID, WIFI_PWD);
  97.   int counter = 0;
  98.   while (WiFi.status() != WL_CONNECTED) {
  99.     delay(500);
  100.     Serial.print(".");
  101.     display.clear();
  102.     display.drawString(64, 10, "Connecting to WiFi");
  103.     display.drawXbm(46, 30, 8, 8, counter % 3 == 0 ? activeSymbole : inactiveSymbole);
  104.     display.drawXbm(60, 30, 8, 8, counter % 3 == 1 ? activeSymbole : inactiveSymbole);
  105.     display.drawXbm(74, 30, 8, 8, counter % 3 == 2 ? activeSymbole : inactiveSymbole);
  106.     display.display();
  107.     counter++;
  108.   }
  109.   // Get time from network time service
  110.   configTime(TZ_SEC, DST_SEC, "pool.ntp.org");
  111.   ui.setTargetFPS(30);
  112.   ui.setActiveSymbol(activeSymbole);
  113.   ui.setInactiveSymbol(inactiveSymbole);
  114.   // You can change this to
  115.   // TOP, LEFT, BOTTOM, RIGHT
  116.   ui.setIndicatorPosition(BOTTOM);
  117.   // Defines where the first frame is located in the bar.
  118.   ui.setIndicatorDirection(LEFT_RIGHT);
  119.   // You can change the transition that is used
  120.   // SLIDE_LEFT, SLIDE_RIGHT, SLIDE_TOP, SLIDE_DOWN
  121.   ui.setFrameAnimation(SLIDE_LEFT);
  122.   ui.setFrames(frames, numberOfFrames);
  123.   ui.setOverlays(overlays, numberOfOverlays);
  124.   // Inital UI takes care of initalising the display too.
  125.   ui.init();
  126.   Serial.println("");
  127.   updateData(&display);
  128. }
  129. void loop() {
  130.   if (millis() - timeSinceLastWUpdate > (1000L*UPDATE_INTERVAL_SECS)) {
  131.     setReadyForWeatherUpdate();
  132.     timeSinceLastWUpdate = millis();
  133.   }
  134.   if (readyForWeatherUpdate && ui.getUiState()->frameState == FIXED) {
  135.     updateData(&display);
  136.   }
  137.   int remainingTimeBudget = ui.update();
  138.   if (remainingTimeBudget > 0) {
  139.     // You can do some work here
  140.     // Don't do stuff if you are below your
  141.     // time budget.
  142.     delay(remainingTimeBudget);
  143.   }
  144. }
  145. void drawProgress(OLEDDisplay *display, int percentage, String label) {
  146.   display->clear();
  147.   display->setTextAlignment(TEXT_ALIGN_CENTER);
  148.   display->setFont(ArialMT_Plain_10);
  149.   display->drawString(64, 10, label);
  150.   display->drawProgressBar(2, 28, 124, 10, percentage);
  151.   display->display();
  152. }
  153. void updateData(OLEDDisplay *display) {
  154.   drawProgress(display, 10, "Updating time...");
  155.   drawProgress(display, 30, "Updating weather...");
  156.   currentWeatherClient.setMetric(IS_METRIC);
  157.   currentWeatherClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  158.   currentWeatherClient.updateCurrentById(¤tWeather, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID);
  159.   drawProgress(display, 50, "Updating forecasts...");
  160.   forecastClient.setMetric(IS_METRIC);
  161.   forecastClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  162.   uint8_t allowedHours[] = {12};
  163.   forecastClient.setAllowedHours(allowedHours, sizeof(allowedHours));
  164.   forecastClient.updateForecastsById(forecasts, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID, MAX_FORECASTS);
  165.   readyForWeatherUpdate = false;
  166.   drawProgress(display, 100, "Done...");
  167.   delay(1000);
  168. }
  169. void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  170.   now = time(nullptr);
  171.   struct tm* timeInfo;
  172.   timeInfo = localtime(&now);
  173.   char buff[16];
  174.   display->setTextAlignment(TEXT_ALIGN_CENTER);
  175.   display->setFont(ArialMT_Plain_10);
  176.   String date = WDAY_NAMES[timeInfo->tm_wday];
  177.   sprintf_P(buff, PSTR("%s, %02d/%02d/%04d"), WDAY_NAMES[timeInfo->tm_wday].c_str(), timeInfo->tm_mday, timeInfo->tm_mon+1, timeInfo->tm_year + 1900);
  178.   display->drawString(64 + x, 5 + y, String(buff));
  179.   display->setFont(ArialMT_Plain_24);
  180.   sprintf_P(buff, PSTR("%02d:%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min, timeInfo->tm_sec);
  181.   display->drawString(64 + x, 15 + y, String(buff));
  182.   display->setTextAlignment(TEXT_ALIGN_LEFT);
  183. }
  184. void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  185.   display->setFont(ArialMT_Plain_10);
  186.   display->setTextAlignment(TEXT_ALIGN_CENTER);
  187.   display->drawString(64 + x, 38 + y, currentWeather.description);
  188.   display->setFont(ArialMT_Plain_24);
  189.   display->setTextAlignment(TEXT_ALIGN_LEFT);
  190.   String temp = String(currentWeather.temp, 1) + (IS_METRIC ? "°C" : "°F");
  191.   display->drawString(60 + x, 5 + y, temp);
  192.   display->setFont(Meteocons_Plain_36);
  193.   display->setTextAlignment(TEXT_ALIGN_CENTER);
  194.   display->drawString(32 + x, 0 + y, currentWeather.iconMeteoCon);
  195. }
  196. void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  197.   drawForecastDetails(display, x, y, 0);
  198.   drawForecastDetails(display, x + 44, y, 1);
  199.   drawForecastDetails(display, x + 88, y, 2);
  200. }
  201. void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex) {
  202.   time_t observationTimestamp = forecasts[dayIndex].observationTime;
  203.   struct tm* timeInfo;
  204.   timeInfo = localtime(&observationTimestamp);
  205.   display->setTextAlignment(TEXT_ALIGN_CENTER);
  206.   display->setFont(ArialMT_Plain_10);
  207.   display->drawString(x + 20, y, WDAY_NAMES[timeInfo->tm_wday]);
  208.   display->setFont(Meteocons_Plain_21);
  209.   display->drawString(x + 20, y + 12, forecasts[dayIndex].iconMeteoCon);
  210.   String temp = String(forecasts[dayIndex].temp, 0) + (IS_METRIC ? "°C" : "°F");
  211.   display->setFont(ArialMT_Plain_10);
  212.   display->drawString(x + 20, y + 34, temp);
  213.   display->setTextAlignment(TEXT_ALIGN_LEFT);
  214. }
  215. void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state) {
  216.   now = time(nullptr);
  217.   struct tm* timeInfo;
  218.   timeInfo = localtime(&now);
  219.   char buff[14];
  220.   sprintf_P(buff, PSTR("%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min);
  221.   display->setColor(WHITE);
  222.   display->setFont(ArialMT_Plain_10);
  223.   display->setTextAlignment(TEXT_ALIGN_LEFT);
  224.   display->drawString(0, 54, String(buff));
  225.   display->setTextAlignment(TEXT_ALIGN_RIGHT);
  226.   String temp = String(currentWeather.temp, 1) + (IS_METRIC ? "°C" : "°F");
  227.   display->drawString(128, 54, temp);
  228.   display->drawHorizontalLine(0, 52, 128);
  229. }
  230. void setReadyForWeatherUpdate() {
  231.   Serial.println("Setting readyForUpdate to true");
  232.   readyForWeatherUpdate = true;
  233. }
注意代碼里面填寫自己的APIkey和要查詢的城市名稱,這里填寫的是深圳-shenzhen。
3、驗證測試
將代碼驗證并上傳到零知-ESP8266上面,打開串口調試工具,可以看到如下結果:
獲取返回結果代碼為:200,即表示成功了;如果是錯誤碼,可以把地址粘貼到瀏覽器里看看是什么原因。
成功后OLED就會顯示天氣情況:
更多詳細資料可到零知實驗室免費獲取。
作者: 798365837    時間: 2020-2-28 21:30
庫安裝失敗
作者: rain_2015_long    時間: 2021-6-16 17:26
編譯錯誤,不能用
作者: 1836114456    時間: 2021-8-28 21:29
頭文件不足發出來也沒用
作者: 海南釣魚王    時間: 2023-6-6 15:53
求完整資料
