程序大致可以實現定時刻PWM輸出功能,但有一個缺點:輸出的波形不穩定,在數碼管上顯示是不是出現跳碼。跪求大神指點。
#include<reg51.h>
sbit PWM=P2^1;
sbit alarm=P1^7; //高電平時鬧鐘響
sbit selecta=P2^4;
sbit selectb=P2^5;
sbit selectc=P2^6;
sbit select=P2^7; //只需要第一段,第二段和第六段亮,即
uchar Keystate;
uchar buffer[]={0,0,0,0,0};
uint a,b;
uchar table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共陰數碼管代碼
uchar Overflow=0;//定時溢出次數
uchar minute,second;//定義倒計時變量
//ms延時函數
void delayms(uint x)
uint i;
while(x--) for(i=0;i<1000;i++);
void delay(uint x)
uchar j;
while(x--)for(j=0;j<5;j++);
//數碼管顯示函數
void display()
uchar s,k;
buffer[0]=minute/10;
buffer[1]=minute%10;
buffer[2]=second/10;
buffer[3]=second%10;
buffer[4]=b%10;
for(k=0;k<5;k++)
s=k;
switch(k)
case 0:selecta=0;selectb=1;selectc=0;
break;
case 1: selecta=1;selectb=1;selectc=0;
break;
case 2: selecta=0;selectb=0;selectc=1;
break;
case 3: selecta=1;selectb=0;selectc=1;
break;
case 4:selecta=1;selectb=1;selectc=1;
break;
P0=table[buffer];
delay(3);
}//要實現動態顯示
//本程序需要用到兩個定時器,兩個中斷
void KeyScan();
P2=0x00;
a=0;
b=5;
minute=30;
second=0;
RD=0;
select=1;
TMOD=0x11;
TH0=(65536-10)/256;
TL0=(65536-10)%256;
EA=1;
IT1=1; IT0=1;
EX1=1; EX0=1;
PX1=1;
KeyScan();
TR1=1;
ET1=1;
display();
delay(10);
void X1_INT()interrupt 2
if(b>0) b--;
else b=9;
void X0_INT()interrupt 0
b++;
if(b>9) b=0;
void time1() interrupt 3
TL1=(65536-10)%256;
TH1=(65536-10)/256;
a++;
if(a==10) a=0;
if(a<b) PWM=1;
else PWM=0;
void timer0start()//定時器初始化函數
TH0=(65536-50000)/256; //定時器定時為50ms,晶振的周期為12MHz
TL0=(65536-50000)%256;
ET0=1; //定時器1中斷開
TR0=1; //定時器1開
//鬧鈴函數 需要輸出聲音悅耳
void beef()
uchar x=100;
while(x--)
alarm=!alarm;
delayms(10);
alarm=0;
//定時器0中斷函數程序
void time0()interrupt 1
if(Overflow==20)
Overflow=0;
if(second==0)
if(minute==0)
beef();
minute=0;
second=0;
while(1);
else minute--;
second=59;
else second--;
else Overflow++;
//按鍵掃描函數
void KeyScan()
uint x=1000;
while(x--)
P1=0xff;
Keystate=P1&0x03;
display();
delay(50);
if(Keystate!=0x03)
delayms(2); //去抖
if(Keystate!=0x03)//去抖后再確認一下
delayms(1);
switch(Keystate)
case 0x01:minute++;
if(minute==60)minute=0;
break;
case 0x02:minute--;
if(minute==0)minute=59;
break;
default:break;
while(P1!=0xff)display(); //松手檢測并保證可以從循環中出來
timer0start();
