標(biāo)題: 光立方4✖4✖4程序 [打印本頁(yè)]
作者: 1098928119    時(shí)間: 2019-5-17 18:25
int layer[4]={A3,A2,A1,A0}; //初始化和聲明LED層
  int column[16]={13,12,11,10,9,8,7,6,5,4,3,2,1,0,A5,A4}; //初始化和聲明LED行
  int time = 250;
void setup()
  for(int i = 0; i<16; i++)
    pinMode(column[i], OUTPUT);  //setting rows to ouput
  for(int i = 0; i<4; i++)
    pinMode(layer[i], OUTPUT);  //setting layers to output
  randomSeed(analogRead(10));  //seeding random for random pattern
void loop()
  turnEverythingOff();
  flickerOn();
  turnEverythingOn();
  delay(time);
  turnOnAndOffAllByLayerUpAndDownNotTimed();
  layerstompUpAndDown();
  spiralInAndOut();
  turnOnAndOffAllByColumnSideways();
  delay(time);
  aroundEdgeDown();
  randomflicker();
  randomRain();
  diagonalRectangle();
  goThroughAllLedsOneAtATime();
  propeller();
  spiralInAndOut();
  flickerOff();
  delay(2000);
//turn all off 全部關(guān)閉
void turnEverythingOff()
     digitalWrite(column[i], 1);
     digitalWrite(layer[i], 0);
//turn all on 全部打開(kāi)
void turnEverythingOn()
    digitalWrite(column[i], 0);
  //turning on layers
    digitalWrite(layer[i], 1);
//turn columns off 關(guān)閉列
void turnColumnsOff()
//flicker on 閃爍
void flickerOn()
  int i = 150;
  while(i != 0)
    turnEverythingOn();
    delay(i);
    delay(i);
    i-= 5;
//turn everything on and off by layer up and down NOT TIMED 按層上下打開(kāi)和關(guān)閉所有內(nèi)容,不定時(shí)
void turnOnAndOffAllByLayerUpAndDownNotTimed()
  int x = 75;
  for(int i = 5; i != 0; i--)
    turnEverythingOn();
    for(int i = 4; i!=0; i--)
      digitalWrite(layer[i-1], 0);
      delay(x);
      delay(x);
      delay(x);
      digitalWrite(layer[i-1], 1);
      delay(x);
//turn everything on and off by column sideways 按列橫向打開(kāi)和關(guān)閉所有內(nèi)容
void turnOnAndOffAllByColumnSideways()
  int x = 75;
  //turn on layers
  for(int y = 0; y<3; y++)
    //turn on 0-3
      delay(x);
    //turn on 4-7
    for(int i = 4; i<8; i++)
      delay(x);
    //turn on 8-11
    for(int i = 8; i<12; i++)
      delay(x);
    //turn on 12-15
    for(int i = 12; i<16; i++)
      delay(x);
    //turn off 0-3
      delay(x);
    //turn off 4-7
      delay(x);
    //turn off 8-11
      delay(x);
    //turn off 12-15
      delay(x);
    //turn on 12-15
      delay(x);
    //turn on 8-11
      delay(x);
    //turn on 4-7
      delay(x);
    //turn on 0-3
      delay(x);
    //turn off 12-15
      delay(x);
    //turn off 8-11
      delay(x);
    //turn off 4-7
      delay(x);
    //turn off 0-3
      delay(x);
//up and down single layer stomp 上下單層移動(dòng)
void layerstompUpAndDown()
  int x = 75;
  for(int y = 0; y<5; y++)
    for(int count = 0; count<1; count++)
        delay(x);
      for(int i = 4; i !=0; i--)
        delay(x);
      delay(x);
      delay(x);
//flicker off
void flickerOff()
  turnEverythingOn();
  for(int i = 0; i!= 150; i+=5)
    delay(i+50);
    turnEverythingOn();
    delay(i);
//around edge of the cube down 沿著立方體邊緣向下
void aroundEdgeDown()
  for(int x = 200; x != 0; x -=50)
    for(int i = 4; i != 0; i--)
      digitalWrite(column[5], 0);
      digitalWrite(column[6], 0);
      digitalWrite(column[9], 0);
      digitalWrite(column[10], 0);
      digitalWrite(column[0], 0);
      delay(x);
      digitalWrite(column[0], 1);
      digitalWrite(column[4], 0);
      delay(x);
      digitalWrite(column[4], 1);
      digitalWrite(column[8], 0);
      delay(x);
      digitalWrite(column[8], 1);
      digitalWrite(column[12], 0);
      delay(x);
      digitalWrite(column[12], 1);
      digitalWrite(column[13], 0);
      delay(x);
      digitalWrite(column[13], 1);
      digitalWrite(column[15], 0);
      delay(x);
      digitalWrite(column[15], 1);
      digitalWrite(column[14], 0);
      delay(x);
      digitalWrite(column[14], 1);
      digitalWrite(column[11], 0);
      delay(x);
      digitalWrite(column[11], 1);
      digitalWrite(column[7], 0);
      delay(x);
      digitalWrite(column[7], 1);
      digitalWrite(column[3], 0);
      delay(x);
      digitalWrite(column[3], 1);
      digitalWrite(column[2], 0);
      delay(x);
      digitalWrite(column[2], 1);
      digitalWrite(column[1], 0);
      delay(x);
      digitalWrite(column[1], 1);
//random flicker 隨機(jī)閃爍
void randomflicker()
  int x = 10;
  for(int i = 0; i !=750; i+=2)
  int randomLayer = random(0,4);
  int randomColumn = random(0,16);
  digitalWrite(layer[randomLayer], 1);
  digitalWrite(column[randomColumn], 0);
  delay(x);
  digitalWrite(layer[randomLayer], 0);
  digitalWrite(column[randomColumn], 1);
  delay(x);
//random rain 隨機(jī)降雨
void randomRain()
  int x = 100;
  for(int i = 0; i!=60; i+=2)
    digitalWrite(layer[0], 1);
    delay(x+50);
    digitalWrite(layer[0], 0);
    digitalWrite(layer[1], 1);
    delay(x);
    digitalWrite(layer[1], 0);
    digitalWrite(layer[2], 1);
    delay(x);
    digitalWrite(layer[2], 0);
    digitalWrite(layer[3], 1);
    delay(x+50);
    digitalWrite(layer[3], 0);
//diagonal rectangle 對(duì)角矩形
void diagonalRectangle()
  int x = 350;
  for(int count = 0; count<5; count++)
    //top left
    for(int i = 0; i<8; i++)
    delay(x);
    //middle middle
    for(int i = 4; i<12; i++)
    delay(x);
    //bottom right
    for(int i = 8; i<16; i++)
    delay(x);
    //bottom middle
    delay(x);
    //bottom left
    delay(x);
    //middle middle
    delay(x);
    //top right
    delay(x);
    //top middle
    delay(x);
  //top left
  delay(x);
//propeller 螺旋槳
void propeller()
  int x = 90;
  for(int y = 4; y>0; y--)
    for(int i = 0; i<6; i++)
      //turn on layer
      digitalWrite(layer[y-1], 1);
      //a1
      turnColumnsOff();
      delay(x);
      //b1
      turnColumnsOff();
      delay(x);
      //c1
      turnColumnsOff();
      delay(x);
      //d1
      turnColumnsOff();
      delay(x);
      //d2
      turnColumnsOff();
      delay(x);
      //d3
      turnColumnsOff();
      delay(x);
  //d4
  turnColumnsOff();
  delay(x);
//spiral in and out 螺旋進(jìn)出
void spiralInAndOut()
  turnEverythingOn();
  int x = 60;
    //spiral in clockwise
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    digitalWrite(column[5], 1);
    delay(x);
    digitalWrite(column[6], 1);
    delay(x);
    digitalWrite(column[10], 1);
    delay(x);
    digitalWrite(column[9], 1);
    delay(x);
//spiral out counter clockwise 逆時(shí)針旋出
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
//spiral in counter clock wise 逆時(shí)針螺旋
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
//spiral out clock wise 按時(shí)鐘方向螺旋輸出
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
    delay(x);
//go through all leds one at a time 逐一檢查所有LED
void goThroughAllLedsOneAtATime()
  int x = 15;
    //0-3
    for(int count = 4; count != 0; count--)
      digitalWrite(layer[count-1], 1);
        delay(x);
        delay(x);
    digitalWrite(layer[count-1], 0);
    //4-7
    for(int count = 0; count < 4; count++)
      digitalWrite(layer[count], 1);
        delay(x);
        delay(x);
    digitalWrite(layer[count], 0);
    //8-11
        delay(x);
        delay(x);
    //12-15
        delay(x);
        delay(x);
作者: 杰瑤電子    時(shí)間: 2019-5-25 21:01
頂,樓主威武,感謝分享
作者: tensea    時(shí)間: 2020-6-29 12:37
樓主,有沒(méi)有原理圖
