哪位大神幫忙看一下,我做的是TLC0834采集0-5V在數(shù)碼管上顯示兩位數(shù),但現(xiàn)在只顯示0.0
18699427623
時(shí)間:
2019-5-15 11:00
/********************************* 包含頭文件 ********************************/
#include <reg52.h>
#include <intrins.h>
/********************************* 端口定義 **********************************/
sbit CS = P1^4;
sbit Clk = P1^2;
sbit DATI = P1^3;
sbit DATO = P1^1;
sbit AD_SARS = P1^6;
sbit led2 = P2^1;
sbit led3 = P2^2;
/******************************* 定義全局變量 ********************************/
unsigned char dat = 0x00; //AD 值
unsigned char count = 0x00; //定時(shí)器計(jì)數(shù)
unsigned char CH; //通道變量
unsigned char dis[] = {0x00, 0x00, 0x00}; //顯示數(shù)值
unsigned char c=0;
/******************************* 共陽 LED 段碼表 *******************************/
unsigned char code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
函數(shù)功能 :AD 轉(zhuǎn)換子程序
入口參數(shù) :CH
出口參數(shù) :dat
unsigned char adc0834(unsigned char CH)
unsigned char i,AI_data;
CS = 1;
_nop_();
DATO = 1;
_nop_();
_nop_();
Clk = 0;
_nop_();
CS = 0;
_nop_();
//Start BIT
DATI = 1;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
_nop_();
//SGL/DIF BIT
DATI = 1;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
_nop_();
//ODD/EVEN BIT
if((CH == 0x00) || (CH == 0x02))
DATI = 0;
if((CH == 0x01) || (CH == 0x03))
DATI = 1;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
_nop_();
//SELECT BIT
if((CH == 0x00) || (CH == 0x01))
DATI = 0;
if((CH == 0x02) || (CH == 0x03))
DATI = 1;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
_nop_();
//讀取轉(zhuǎn)換的8位數(shù)據(jù)
for(i=0;i<8;i++)
AI_data <<= 1;
_nop_();
AI_data+=(uchar)DATO;
_nop_();
Clk = 1;
_nop_();
Clk = 0;
_nop_();
CS = 1;
DATI = 1;
return dat;
函數(shù)功能 :將 0-255 級(jí)換算成 0.00-5.00 的電壓數(shù)值
入口參數(shù) :i
出口參數(shù) :
void convdata(unsigned char i)
dis[0] = i/51; //個(gè)位
dis[1] = (i%51)*10/51*2; //小數(shù)點(diǎn)后第一位
dis[2] = ((i%51)*10%51)*10/51*2; //小數(shù)點(diǎn)后第二位
函數(shù)功能 :數(shù)碼管顯示子程序
入口參數(shù) :
出口參數(shù) :
void display(void)
P0=0xff;
switch(c)
case 0:led2=0;led3=1;c++;P0=tab[dis[0]]&0x7f;;break;
case 1:led2=1;led3=0;c=0;P0=tab[dis[0]];break;
default :break;
函數(shù)功能 :主程序
入口參數(shù) :
出口參數(shù) :
void main(void)
TMOD = 0x01; //設(shè)置中斷
TH0=(65536-50000)/256;// 定時(shí)器 1 初值定時(shí) 50ms
TL0=(65536-50000)%256;
IE = 0x82;
TR0 = 1;
while(1) //主循環(huán)
dat = adc0834(CH);
convdata(dat); //數(shù)據(jù)轉(zhuǎn)換
display(); //顯示數(shù)值
函數(shù)功能 :定時(shí)器中斷延時(shí)程序 這一段的作用時(shí)隔一段時(shí)間抽樣一次 否側(cè)顯示的最后一位
會(huì)不穩(wěn)定
入口參數(shù) :
出口參數(shù) :
void timer0(void) interrupt 1
count++;
if (count == 0x01)
count = 0x00;
dat = adc0834(CH);
zb123
時(shí)間:
2019-5-15 15:04
可以用仿真軟件看一下
